 Hi all,
I am new to the forum, and have newbie question. I am very new to leather crafting and have been reading a lot of posts on this forum but can't seem to find a post that relates exactly the this issue. There are some similar issues but I am not certain they are the same root cause.
Basically, I have made a belt from an un-dyed belt blank (double butt, 3.8m thick). I dyed it with a water-based dye. It came out looking great initially. The very smooth and glossy.
However, after wearing it two times, some hairline cracks have developed on about 1/2 of the belt (See picks). It's understandable that creases will develop in a belt like this (and to a certain extent it adds to the character of the piece over time), but I'm not sure what has happened here is really desirable.
My thoughts are:
- Dye didn't penetrate deep enough (not enough dye), so when the fibres are stretched, the lighter un-dyed colour is showing through.
- Leather is too dry .This blank was hanging up in an air-conditioned shop andI didn't oil it or treat it at all.
- Bad piece of leather. I feel this is less likely.
Would really appreciate your insights on what I might have done wrong here and whether it can be remedied in some way.
Thanks in advance!!!
D32C19C5-8F8F-42E8-B929-82040646927F.heic
23 minutes ago, Windrider said:
(See picks)
Oops. Can't see the pics. This is a .heic format file; on this forum .jpg format works best.
I Photoshopped the image and reduced the size.
Edited by LatigoAmigo
Added image
Thanks @LatigoAmigo for fixing the photo.  What process did you use to dye the belt?  Dipping, dauber?  Any top coat applied like Super Sheen?  I would think it's not enough dye or like you said, no NFO (neatsfoot oil) applied.
Welcome to the forum!
Couple things, Windrider . . . one is the oil thing . . . ALWAYS add one light coat to belts and holsters especially and things like purse straps . . . suspenders . . . anything that will be flexed a lot.
Second . . . I'm not "slamming" whoever you got your belt blank from . . . but my personal adventures with them is they are cut from second rate leather . . .  and although I might buy one for me . . . I'd never pass one on to a customer.
Too much of "premaide" blanks and stuff is cut from a less than optimum hide . . . which is of course the only way that they can be offered for the low prices they get.
May God bless,
Dwight
The same thing has happened to me using ' old leather ' thats been hanging around a bit too long in my workshop, using up scraps,  odds & ends of leather etc.  that may have dried out a bit.  A good dose of oil does help.
@Windrider welcome to the forum btw  , we're all pretty normal around here  :crazy::drum:
HS
Thanks for the insights everyone, much appreciated.
@LatigoAmigoThanks a lot for helping with the pic.
@PastorBobThe water based dye was just rubbed on using a sponge. Two coats only as the dye had dried out a bit and was a little viscous (which may also mean that it didn't saturate the fibres deep enough. No finish was applied.
Gotta source some NFO before my next project!!
Thanks again.
WR
