Members Rickard Posted August 23, 2021 Members Report Posted August 23, 2021 Hello, are there eny machines that can handle from 5 mm up to 15 mm leather? Or do i need two different machines. I live in Norway so i think i need to import from UK or Poland. Im locking for a one needle walking foot flatbed or cylinderarm machine. Used or new. Quote
kgg Posted August 23, 2021 Report Posted August 23, 2021 19 minutes ago, Rickard said: Hello, are there eny machines that can handle from 5 mm up to 15 mm leather? Yes something in the 441 class maybe similar to the Cowboy CB 3500 but... If you are doing 15mm regularly you will have to dumb the machine down to do the thin stuff. This is going to be frustrating and time consuming. You would be better off with two machines, one setup for the thinner and one setup for the thicker. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted August 23, 2021 Moderator Report Posted August 23, 2021 6 hours ago, kgg said: Yes something in the 441 class maybe similar to the Cowboy CB 3500 but... If you are doing 15mm regularly you will have to dumb the machine down to do the thin stuff. I wrote the blog article about dumbing down a Cowboy, Cobra, or similar harness stitcher on my R&W Custom Leatherworks website. It explains what is involved in getting a heavy duty leather stitcher to sew thinner work than what it was built to handle. It takes no more than 20 minutes to learn this and make the changes as needed. Afterward, the changes are reversed when one needs to sew thick leather. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Handstitched Posted August 23, 2021 Members Report Posted August 23, 2021 (edited) G'Day , Heres an example of what the 441 clones can do. I just wanted to know if it could do what the ad in the magazine said it could do, and sure as eggs, it did . However, I did go slowly .I have never had a job that required that thickness, but its nice to know I got what I paid for There was a ' chunk' of leather of that thickness under the foot when I unpacked the machine. The leather is x5 layers of 4mm veg tan, the thread is 277 M10 , needle 180/24. Heavy duty tool belts & dog collars etc. about 5mm in thickness are some of the items I sew . The thickest I've sewn on my machine is around 10mm. As for the thinner stuff, I have a Seiko STW ,mostly used for horse rug repairs, but will quite easily go through 2-3mm leather . Having more than one machine does help. HS Edited August 23, 2021 by Handstitched Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
RockyAussie Posted August 23, 2021 Report Posted August 23, 2021 (edited) Better yet.... with a narrow foot and needle plate combo we now make you can get down to this thickness shown here with 138 thread on single layer upholstery leather. Also means you can get the guide right up to the centre foot and it stitches fine at less than 3mm from the edge. Also made for the CB3200 and CB3500 CB4500. $120 AUD +freight if you want a set. Edited August 23, 2021 by RockyAussie another picture Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Moderator Wizcrafts Posted August 23, 2021 Moderator Report Posted August 23, 2021 5 hours ago, RockyAussie said: Better yet.... with a narrow foot and needle plate combo we now make you can get down to this thickness shown here with 138 thread on single layer upholstery leather. Also means you can get the guide right up to the centre foot and it stitches fine at less than 3mm from the edge. Also made for the CB3200 and CB3500 CB4500. Tell me more about the width and hole size of the narrow feed dog and needle plate. I have a cb4500. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Rickard Posted August 24, 2021 Author Members Report Posted August 24, 2021 23 hours ago, kgg said: Yes something in the 441 class maybe similar to the Cowboy CB 3500 but... If you are doing 15mm regularly you will have to dumb the machine down to do the thin stuff. This is going to be frustrating and time consuming. You would be better off with two machines, one setup for the thinner and one setup for the thicker. kgg Thanks for your answere. I have been locking on the Cowboy brand, but i think maybe it can be a problem if i need a repear on a machine like that where i live. I have found this shop in UK https://www.ebay.co.uk/str/castlesewingltd?_pgn=2 and they have several different Juki machines like Juki LS 1341 , Juki 245 and Juki 441. Enyone having experience with Castle sewing in UK England? will a Juki Ls 1341 or Juki 245 be good for leatherthickness 5-10 mm ? i think i read here some place thar Juki 441 are mostly set for fabrick/heavy canvas and not for sewing leather? Quote
Members Rickard Posted August 24, 2021 Author Members Report Posted August 24, 2021 17 hours ago, Wizcrafts said: I wrote the blog article about dumbing down a Cowboy, Cobra, or similar harness stitcher on my R&W Custom Leatherworks website. It explains what is involved in getting a heavy duty leather stitcher to sew thinner work than what it was built to handle. It takes no more than 20 minutes to learn this and make the changes as needed. Afterward, the changes are reversed when one needs to sew thick leather. Thanks alot for this info , im sure gonna have a look into it. I think i probbably start with a machine who can sew ca 4-10 mm range and move on later with a havier machine. Quote
RockyAussie Posted August 24, 2021 Report Posted August 24, 2021 9 hours ago, Wizcrafts said: Tell me more about the width and hole size of the narrow feed dog and needle plate. I have a cb4500. I figure to answer that best I would do a few pics to explain better the overall advantages. This picture shows that the whole plate is different to the original in order to improve the distance from the outer edge for gussets and such and reducing the curve at the same time. This is the original needle plate and feed dog (near to 9mm) This is our new version Here as you see I now have no problem getting just 10th of an inch from the edge Over the next 2 weeks I will do up a video to post showing how I can go from upholstery leather up to 3/4" veg with very little adjustments . A little top tension and maybe foot pressure. PM me your address details caus I reckon you should have a set Wiz. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
RockyAussie Posted August 24, 2021 Report Posted August 24, 2021 27 minutes ago, Rickard said: Thanks for your answere. I have been locking on the Cowboy brand, but i think maybe it can be a problem if i need a repear on a machine like that where i live. I have found this shop in UK https://www.ebay.co.uk/str/castlesewingltd?_pgn=2 and they have several different Juki machines like Juki LS 1341 , Juki 245 and Juki 441. Enyone having experience with Castle sewing in UK England? will a Juki Ls 1341 or Juki 245 be good for leatherthickness 5-10 mm ? i think i read here some place thar Juki 441 are mostly set for fabrick/heavy canvas and not for sewing leather? Juki is a great brand and many other brands clone them as best they can. The Cowboy 4500 and many others are clones of this machine. The Cowboy CB 6900 (1341 in the USA I think is a clone of ......the Juki LS 1341 and will handle work up to 10mm very well. This is a video I did on one a couple of weeks back. There are several other ones showing some light stitching as well if you check my you tube channel. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
