4 hours ago, Handstitched said:
You've done an excellent job restoring that, well done , love to see the old become new again  :thumbsup:
I have had difficulties  in the past  trying to set rivets on ' round' projects . So on some projects I have used a small piece of steel pipe around the same size, fit the rivet post through the hole, , slide the pipe in gently,  put the cap on,  and use it as an anvil .
HS
Thank you. Good tip also.
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
Great work on bringing a classic piece back to life. Id like to mention how i cut old rivets or messed up rivets. Sometimes i drill them out but i have found if you take a metal putty knife or even a cheap skiving knife. Thin it down and make it sharp. And you can slide it between most objects and rivet. Give it a smack with mallet and it slices right threw rivet. On something like your old belt this trick would have worked real good.
On 10/11/2021 at 10:25 AM, JWheeler331 said:
Here is a link to the finished project. Thanks for any info you helped with.
I hope that you will check out the link.
JWheeler331: Pooler & Jones Boss Shotshell Cartridge Belt Restoration
Nice
Putting the article and the photos together looks as much work as the restoration itself!
6 hours ago, Spyros said:
Nice
It was a lot of work also. Thanks for checking it out.
