Wanting to know the right way to adjust this, can't find any internet help so far..... The hook is barely striking the needle right now, but it is.
Sorry that I can't help with the adjustment but if you haven't already put in a new needle, I suggest that you do so in order to be sure that the issue isn't a bent needle.
Lance
Current machines: Consew 226R-1, Consew 227, Necchi BU Mira in an industrial table with an antique Atlas clutch setup.
The issue is the #24, #25 needle that needs to be used. Heavy thread. Those needles are fat enough the hook tip just ticks the scarf. There is an adjustment screw at the right end of the shuttle shaft, on the outside of the machine base. I think it is just for removing play, and doesn't provide for movement of the shaft at all.
Edited by Wyowally
more info
Well - a #24, #25 needle is IMO out of the comfort zone of a light duty leather machine like the class 17. IMO #22 is the max needle size for a machine of this type. Yes, I know the manual says up to #25 but still. The very small spools do not hold much of the thick thread anyway, not talking about higher foot pressure you may need for a #25 needle.
my 2 cents
EDIT:
Seiko still makes clones of the Singer class 17 (their model is TE-6) and they recommend needles up to #19.
Beside of that - IIRC the class 17 shuttle runs in a race like the CB kooks and I do not think you can move the race further the to the right to allow a larger needle.
Edited by Constabulary
According to a previous discussion, you cannot run thicker thread than #135 (Tkt 20), or sew material over ~1/4 inch in a Singer 17-23. In fact, they may not even handle Tkt 20 thread.
Posted IMHO, by Wiz
Here is a manual for the Singer 17-22 and 17-23. The last page's details show the needle and thread sizes. The larger needles are for use with linen thread, not bonded nylon or bonded polyester. There wasn't any bonded synthetic thread on the market when thisw machine was released. These threads are too strong and less flexible, compared to the softer linen. So, if you want to sew with large needles, use unwaxed linen thread only.
17-22&17-23-manual.pdf
Posted IMHO, by Wiz
I found a YouTube video by Alexander Dyer showing him cleaning and adjusting a Singer 17-23. There are many comments from viewers. He revealed in another place that he was using Tex 105 thread, which he thought was about the maximum size bonded thread it could handle.
Here is his webpage explaining his work on the machine, complete with close up photos, which was listed for sale. Note, that his website's security certificate was expired and not yet renewed on November 17, 2021, when I visited the page. I had to bypass a browser security warning to open the page.
Posted IMHO, by Wiz
Is there some safe way to do this Wiz??
YouTube Channel
Instagram
Yes. I am a mighty Wizard and I uttered magic words, while opening the page first in WGET Online, after first removing the S from https. This rendered the HTTP page's source code. There wasn't anything suspicious. So, I simply removed the S and it opened as an http website. If the warning persists, simply use Firefox and ignore the warning, accepting the risk. It helps to have the Malwarebytes Browser Plugin installed too. Contact me privately if you need more info about Firefox and Malwarebytes.
Many of the current browser security warnings are due to an expired SSL Certificate that either is late being auto-renewed, or hasn't been paid for automatically by a cert buyer who has a dedicated, semi-dedicated, or VPS server account. It is easy to miss an email notice to authorize the payment if a card on file expires before the renewal takes place.
Posted IMHO, by Wiz
Wiz, thanks for the replies.  I already had the manual (published 1919!) and have watched his video.  He apparently made a shim in order to move the hook and race closer to the needle - the opposite of my issue with the hook kissing the needle scarf. Pretty creative on his part, and perhaps indicative that no real provision was made for adjusting hook-to-needle.
I discovered that it was only the  #25 needle it was touching. My #21's (Organ leather point) don't touch.  Still wondering what the last operator was using it for, or how he was even able to use it. The little curved arm inserted above the upper tension was missing. The check spring was bent to a new shape. He was using - pre-wound bobbin spools with some strange thread. There was a bag tucked into the base with more of the same spools - I found I had to pull considerable thread off in order to fit in the bobbin case.  Such are the adventures when taking on an older neglected machine last run by somebody who had (or chose) to just make do.
I appreciate your comments, will let you know how this turns out.
Edited by Wyowally
fixing typos
