Members Gunnarsson Posted November 24, 2021 Members Report Posted November 24, 2021 10 hours ago, Wizcrafts said: Metric measurements in answer to a question asked by an American member using the US inches system are not useful in this case. It converts to inferior, sorry, IMPERIAL, easily enough. I'd say that when taking and saving a bunch of measurements it's better that the person taking them works with the system he/she is used to, and if anyone needs the numbers in another system they can convert it themselves. Because if the person taking them in the first place makes a mistake in the original measurement/conversion the original saved data is corrupt and useless, while the risk of such mistakes is far smaller when working with familliar systems, and the original saved data is more reliable. Anyone who get their hands on the original data can then convert it to whatever system they like, and if they make a mistake that will only affect themselves, not everyone who try to use the original data. Quote
Members jrdunn Posted November 24, 2021 Members Report Posted November 24, 2021 Thanks for the info! Quote
kgg Posted November 24, 2021 Report Posted November 24, 2021 40 minutes ago, Gunnarsson said: while the risk of such mistakes is far smaller when working with familliar systems, Good advice. The problem in North America is the US is sort of using imperial measurements while in Canada we are supposedly using metric. In Canada it's hard to find metric nuts / bolts and when you can they are more expensive while it is easy to find imperial ones at the hardware stores. In Canada we buy meat and such measured in both lbs and kilograms but priced by the kilogram at the grocery store yet milk and fuel (gas/ diesel / propane) are in liters. Wood is sold in the Imperial system. The US when it comes to liquid measurements like quarts and gallons they are smaller then the British / Canadian Imperial system for quarts and gallons by about 20 percent. The US quart is 32 oz while the British / Canadian Imperial is 40. To add to the confusion horsepower for motors like for our sewing machines where the US and British systems use 745.7 watts being equal to 1 hp while in the metric system it's equal to 735.5 watts. So those servo motors they advertise as 3/4 hp are probably measured using the metric system. Me, I was raised, schooled, trained and worked most of my career using the British / Canadian Imperial system and today the system of measurement I use depends on what I am trying to do. When Canada became metric it drove a lot of us nuts to say the least and is still a chore. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members shoepatcher Posted November 28, 2021 Members Report Posted November 28, 2021 I have the drawers for the short arm Singer treadle patchers. I had a an Amish company in Ohio build them to original Singer specs. Drawer sides are thicker than the singers were and they have dovetail joints on them. $28.50 US plus shipping. The long arm drawers are longer and wider. never had them made.. glenn On 11/23/2021 at 7:26 PM, kgg said: This is the small plain face drawer in my 1949 Singer 29k 71 case iron base. The tracks that are attached to the base for the drawer I painted black to match the rest of the base. Dimensions of the drawer: A) The length i) front to back, outside to outside, is: 205.34mm ii) inside length is 177.33 mm iii) thickness of back is: 8.13mm iv) thickness of front is: 19.88mm The width, i) side to side, outside dimension is: 97.03mm ii) side to side, inside dimension is: 80.09mm iii) thickness of sides are: 8.47mm C) The height, i) front and sides are: 70.43mm ii) back of drawer is: 56.87mm D) The bottom i) bottom of the drawer is 177.33mm x 84.33mm x 2.23mm thick and slides into a track cut in the sides E) The track i) Track for sliding in and out of drawer are 7.92mm wide, 3.45mm deep and are down 9.2mm from the top of the sides kgg Quote
Members shoepatcher Posted November 28, 2021 Members Report Posted November 28, 2021 Not an original Singer drawer. Looks more like an Adler drawer. glenn Quote
kgg Posted November 29, 2021 Report Posted November 29, 2021 53 minutes ago, shoepatcher said: Not an original Singer drawer. This maybe true that the drawer isn't original as I can only go back about 20 years of ownership. I did get the original manual, original table top and can only assume the base and drawer are also original. The Singer's did come with more ornate front designs similar to that of the 127/128's treadles on models prior to the 29k-70 series but they seemed to have changed to the plain face design on the earlier 70 series. I have never seen a Alder Patcher from the 40's or 50's and can't comment on the drawers that they came with. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members shoepatcher Posted November 29, 2021 Members Report Posted November 29, 2021 If it works, that's all that counts. I have never seen a plain drawer on any Singer shoepatcher that was original. They all had a front that was milled with a knob in it. glenn. Quote
kgg Posted November 29, 2021 Report Posted November 29, 2021 31 minutes ago, shoepatcher said: They all had a front that was milled with a knob in it. As an quick example: Singer 29k70 and 73 ( ismacs.net/singer_sewing_machine_company/model-29-leather-stitching-sewing-machine.html ) Singer 29k71 ( youtube.com/watch?v=0LPAtMRN5ZU ) kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members jrdunn Posted December 11, 2021 Members Report Posted December 11, 2021 On 11/28/2021 at 5:35 PM, shoepatcher said: I have the drawers for the short arm Singer treadle patchers. I had a an Amish company in Ohio build them to original Singer specs. Drawer sides are thicker than the singers were and they have dovetail joints on them. $28.50 US plus shipping. The long arm drawers are longer and wider. never had them made.. glenn I ordered and recieved one of @shoepatcher's drawers. It is a quality wooden drawer and fits my 29K71 perfectly. Thanks Glenn! Quote
Members jimi Posted December 11, 2021 Members Report Posted December 11, 2021 On 11/29/2021 at 3:28 PM, shoepatcher said: If it works, that's all that counts. I have never seen a plain drawer on any Singer shoepatcher that was original. They all had a front that was milled with a knob in it. glenn. Hi Glenn, I have a plain drawer on the 29k171 also and have seen a few of them on the newer 29k´s, you must have missed them Quote
