A cheaper alternative to those fancy pins is a mapping pin into a small block of cork
Besides all the previous comments, your clamps are too strong and have too narrow a surface area. Have a look at this video. You can see that Ian has used less powerful clamps, and also wrapped them in thinner leather to cushion them
Or you could try clothes pegs/clothes pins
But there's something I do -- the plastic clothes hangers for ladies' skirts often have clips or clamps on them to hold the skirt, and those clamps have a larger surface area; I just saw them off with a junior hacksaw, and use those
Making a Leather Knife Sheath - YouTube
Edited by zuludog
  • CFM
I don't use clamps on leather that's what contact cement is for, glue it, hammer it then i sew it up and its clamped for good.
  • CFM
7 minutes ago, zuludog said:
Besides all the previous comments, your clamps are too strong. Have a look at this video. You can see that Ian has used less powerful clamps, and also wrapped them in thinner leather to cushion them
man he is good with that awl !
We're in danger of going OT here, but yes, he is; also watch videos by JH Leather. She uses pricking iron  + awl for most of her sewing, and she's excellent. IMO her video on doing the saddle stitch is one of the best
In the most recent issue of leather crafters Leather Crafters and Saddlers Journal an article was written about how you can easily take apart those office binders and taking some scrap leather that's long enough to wrap the inside of the clamp, punching a couple of holes for the levers (or whatever you want to call it) and put it back together.  I've made a bin of different sizes of these.  Works great.
I also found this on the omnicientweb:    https://www.instructables.com/Leather-Workshop-Binder-Clips-two-Minutes-Hack/
  • CFM
There are clamps that are non-marring. Irwin Quick-Grip come to mind.
The only time I use bulldog clamps is when I'm wet-moulding and the stitch line will go right along and over the marks left by the clamps.
Some time ago someone from Japan joined the forum and his YT channel had a tutorial on how to make leather covered bulldog clamp jaws, to prevent this problem, but I didn't bookmark the video, alas.
___________
Hah! What you know... I found it.
Edited by Hardrada
