I put a separate thermometer in the oven and it barely registers 110. Not sure it got to that really. But it does have a fan that circulates the air and I believe that does as much as the temp. Before that, I just put it in there with the light on overnight.
Not so retired RN. Living on the Washington Peninsula.
My drying box will heat up to 140 in the very top . . . they hang a bit lower . . . in the 130 to 135 range . . .
They dry fairly quickly . . . and dry hard.  Much harder than if I just let them air dry in my 73 degree shop.
Depending on what I am wanting  . . . sometimes use the box . . . sometimes don't.
May God bless,
Dwight
www.dwightsgunleather.com
I have a shoe rack in my dryer that I use.  2 holsters get an hour.  Single holster 40-50 minutes.  The way I do holsters the heat can change the mold a bit so I put weights on the sides to keep them flat.
