On 1/3/2022 at 9:01 PM, Dwight said:
Here is a short video of what I d
Thass sum purdy good learnin's fer ya rot cheer ;)
Not exactly the way I do it, but close.  NOTE that you don't need a "closure" for your bag... if you fold it over and set a light weight on it it will work - in fact i sometimes just fold it over and hold for a second, since once it creates a vaccuum theres no need to hold it any more.
I also do not use a cutting board - or anything - along with the process.  My holsters are already measured, cut, sewn together before they go in the bag, and they are NOT flat... they are actually CURVED BEYOND FLAT, so a board would  be in the way of the form.
STILL -- this is pretty good, CLEAR INSTRUCTION.
5 leather patterns
  • Replies 34
  • Created
  • Last Reply
Top Posters In This Topic
1 hour ago, JayEhl said:
Hi -- when you were using the hydraulic press what did you use to form the holster?  was it foam padding or rubber pads or???
I bought 4 pads of latex leather . . . each about 2 inches thick and about 16 or 18 inches square.   I used two above the holster and two below it . . . stacked of course . . . and a 6 ton press.
I just started getting antsy when I really started getting a lot of Glocks . . .
May God bless,
Dwight
www.dwightsgunleather.com
Thank, pal . . .  I went with almost all flat backed holsters . . . for me I found they were more comfortable . . . have not had a customer come back and complain they were too flat yet . . . lol
Seriously . . . I built a 50/50 pancake . . . did my best to get used to it . . . finally just put it on Ebay . . .  took what I got for a used holster . . . went down the road . . . have not made one since.
May God bless,
Dwight
well, i don't mean 50/50s .. I mean curved PAST flat.  A board would prevent getting the right "wrap around" ;)
5 leather patterns
2 hours ago, 327fed said:
Do you think the hydraulic press is safe for SA revolvers ( won’t crush them)?
i have a couple of presses available.
I can only say that I did not have any problems with the hydraulic press . . . other than being scared I was going to crush somebody's plastic fantastic lover pistol
Wood and steel guns never were a problem for me and the latex rubber pieces I used to get the forming done.
I do think though that the vacuum press does a better job . . . quicker . . . and I can see what it is doing . . .
With the hydraulic press . . . if something gets out of alignment you will not know it until you lift the press.  With vacuum bag system . . .  you look thru the bag and you can see what is going on all the time.
And for the price I paid for the latex rubber pieces . . .  I could have bought the whole vacuum system . . . complete. (IIRC)
May God bless,
Dwight
Dwight,  Do I detect a little Jefferson Airplane?
Jim
Jim
He-he . . .
May God bless,
Dwight
  • 9 months later...
Dwight,
Thanks for sharing your knowledge. I finished my bag today with 12 gauge (12 mil) plastic from JoAnns. I have the same pump from Harbor Freight that you linked above, though I bought it before I saw the link. I made the bag fitting with parts from Lowe's. After this photo was taken,  I drilled a hole through the bushing on the inside to keep the bag from blocking the vacuum. Thanks again for sharing.
Randy
1 hour ago, rktaylor said:
Dwight,
Randy
You are more than welcome, Randy . . . have fun with it . . .
I did a couple of intricate radio boxes last spring and summer . . . would have been some kinda tough without the vacuum help.
May God bless,
Dwight
