Members Leescustomleather Posted March 30, 2022 Members Report Posted March 30, 2022 Apply barge cement or other contact cement to the already formed sheath and the snakeskin, let the cement dry at least a couple of hours until it feels totally dry. lay the snakeskin over the sheath use spring clips or tape to hold the snakeskin in place, when you are satisfied with your placement use a heat gun at a distance from your work to gently heat the surface, it will activate the contact cement and you will get a strong and permanent bond. Quote
Members Bert03241 Posted April 2, 2022 Author Members Report Posted April 2, 2022 On 3/29/2022 at 8:37 PM, Leescustomleather said: Apply barge cement or other contact cement to the already formed sheath and the snakeskin, let the cement dry at least a couple of hours until it feels totally dry. lay the snakeskin over the sheath use spring clips or tape to hold the snakeskin in place, when you are satisfied with your placement use a heat gun at a distance from your work to gently heat the surface, it will activate the contact cement and you will get a strong and permanent bond. I think that would make it very difficult to sew Quote
Members Leescustomleather Posted April 3, 2022 Members Report Posted April 3, 2022 20 hours ago, Bert03241 said: I think that would make it very difficult to sew I think perhaps I didn't explain the process properly, What I tried to describe is the same as adding a liner except letting the glue dry completely instead of tacky where it will adhere instantly. When it is completely dry you can move it until you have it exactly where you want it then a little heat will reactivate the glue, I discovered this process accidently, but it works very well. Quote
CFM chuck123wapati Posted April 3, 2022 CFM Report Posted April 3, 2022 On 4/2/2022 at 1:13 AM, Bert03241 said: I think that would make it very difficult to sew just wondering where did you get that hide? It is the belly of the snake you have shown most folks use the other side, the back. How was it tanned? Lees gluing method is top notch but i dont see how it will help in preventing cracking or wrinkleing when opened but i have never tried to put snake on a flap. now if your putting it around the sheath you will have to form the sheath then glue as lee says. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Bert03241 Posted April 3, 2022 Author Members Report Posted April 3, 2022 I got the skin off Esty no idea how it was tanned. I understand how this gluing works. still not sure how I'm going to punch my sew holes after its formed . hmmmm I'll have to think about this. Quote
Members Dwight Posted April 3, 2022 Members Report Posted April 3, 2022 2 hours ago, Bert03241 said: I got the skin off Esty no idea how it was tanned. I understand how this gluing works. still not sure how I'm going to punch my sew holes after its formed . hmmmm I'll have to think about this. Use veggie tanned fake snake skin . . . End of that problem . . . Ain't enough folks out there who could tell the difference anyway . . . May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Bert03241 Posted April 3, 2022 Author Members Report Posted April 3, 2022 yep thats what I'm going to do Quote
