Thread size for sewing machines, can someone explain the numbers?
Like the title says, can anyone give some sort of explanation about the thread size used for sewing machines? I have tried searching the forum, but still haven't found an answer.
I read about #504 and#207, #74 etc, and I have to admit that I don't understand any of it. Apparently someone uses a thinner thread for the bobbin than for the upper thread, but again without the knowledge I'm just using the same size in both which might not be the optimal solution. The thread that I buy doesn't even have those numbers put on them, so I just try to guess my way.
So far I use the Serafil 10 on the old harness stitcher, and Serafil 40 for the patcher.
But I would like to know if anyone has got a chart that would compare the European sizes with the # sizes.
Or if someone can link to an old thread that will explain it :-)
  • Replies 27
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I good chart can be found at (https://www.tolindsewmach.com/thread-chart.html) also you should normally use the same size thread on the top as you use in the bobbin. The strength of the seam will be limited to the strength of the smallest thread size. Sometimes this is done for the look that a larger top thread gives or sometimes you can fool a machine into using a larger top thread then the machine is rated for by using the smaller machine rated bobbin thread.
kgg
kgg
Thanks a lot :-)
That was just what I was looking for.  When I bought needles for my machines, I just sort of picked different sizes so I had some of both ends of the specter, not knowing if a size 80 needle was bigger or smaller than a size 110.
The smaller bobbin thread thing I have never tried, I have just seen it mentioned here a couple of times and thought that I most likely missed out on something. But I think I'll just keep on using the same size thread for top and bottom.
Again thanks for helping.
Brgds
Jonas
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
14 minutes ago, DrmCa said:
Thanks, those are great links as well. Especially the one about the needle information.
Whenever I tried to Google for some answers, mostly regular sewing machines turned up.
Brgds
Jonas
69 thread, T70 and Ticket 20 are all the same size, in Europe many sewing supplies mark this as 20s, size 92 as 30s and size 138 as 20s
Edited by chrisash
Mi omputer is ot ood at speeling , it's not me
@chrisash Thanks, It's just so overwhelming when I read another thread with some information that I could benefit from, and then it translates to pure gibberish in my head because I don't understand what is meant with the sizes mentioned.
Brgds
Jonas
Hello Jonas
Amann Serafil thread got good quality, and I have used it a lot, and it is easy to buy in Denmark. It is a polyester thread. On the Amann website you can find the recommended needle sizes for it. Nylon thread is a bit thicker and almost the same thickness as the polyester thread for the same weight, because the density of polyester is a bit higher than nylon.
https://www.amann.com/products/product/serafil/
I think the link proposed by kgg to Toledo provides a good table to you as to the thread size specifications most used on this website. But there is more systems to define thread sizes than that, and some of them can be quite difficult to figure out.
/Viggo
 Sorry my Mistook it should read
69 thread, T70 and Ticket 40 are all the same size, in Europe many sewing supplies mark this as 40s, and size 92 as 30s and size 138 as 20s
No problem, ;-)
Being an engineer I really need to get my head into gear to compute anything that isn't just a diameter measurement.  (Not that it would do any damage to once in a while challenge the brain)
Cheers
Jonas
