I know there is an adjustment somewhere. I bought this machine used and didn’t get a manual with it. I’m sure it’s a simple thing.
 There is the big screw on top, which way makes the feet have less pressure and for the walking foot in the middle, is there a tension adjustment.
video would be nice. But!!!
There is only one foot pressure screw on the 441 clones. It affects both feet If the pressure spring is too stiff after backing off the top screw, order a softer spring from any dealer who sells these machines. Our supporting dealers are Leather Machine Company (Cobra), Techsew (Your brand) and Toledo Industrial Sewing Machines (Cowboy). All have banner ads in rotation on top of each page. Reloading the page loads a new set of 6 banners. The cost of a softer or harder pressure action spring is trivial.
Posted IMHO, by Wiz
First undo the lock nut then turn anticlockwise to loosen the pressure. This is the foot pressure adjustment screw to turn -
If you want to change to a lower pressure spring just screw it right out while you have the feet down. That makes it easier and when you have the screw out, lift the foot lever and you can then grab the spring out easily.
This is what the larger and softer springs look like
As a general rule I like to back off my foot pressure until I can just lift the feet up with my thumbs. If you get it too loose you will see the job start to lift when the needle comes out and you will then get the thread knot showing up on the underside.
Just a tip ...put a couple of drops of oil down into the cup shape part of this screw occasionally to keep the pressure shaft running up and down smoothly.
YouTube Channel
Instagram
Thanks for the info.  I did contact Techsew and they sent me a pdf manual for my machine and servo motor.
 Really helpful folks.
 I’ll try the adjustments first.
 I got one of aussies new feed dogs and narrow cover and a left side presser.  I also got 1 of the drop down guides and watched ewu’s video on how to drill and tap for the bracket.
 I’ll get her set up and stitchen the way I think it should soon.
Wiz you were correct when you said the cost was trivial. I just got a low pressure spring just in case
You may or may not be lucky there. Some of the later clones are coming pre drilled for that these days like this Cowboy one as delivered here in OZ.
YouTube Channel
Instagram
@RockyAussie
Thats very handy to know. I've always wondered about that. I was so worried that if I backed  off too much, it would  fly off so fast  and make a hole in my workshop roof.  I got the pressure just right now anyway. My machine came from ' Qstitch' in QLD. They don't supply the clones anymore .
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
one other tip when you tighten the locknut on the foot pressure spring don't make it to tight it can jamb that rod from going up and down so just light pressure on that nut.
