Bought a grooving tool that came with a bit that only works on hard veg tan. It only scratches latigo leather but does not cut. Probably because it is ground but not honed.
Does anyone know a method for honing it?
Edited by DrmCa
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
You may have gotten a dull blade . . . Tandy sells the blades for the ones they sell . . . they are cheap . . . might try that.
The other thing to finish sharpening most any shop cutting tool . . .  a cotton polishing wheel with polishing compound  . . .  just have to work to figure what angle to hold the blade.
I can polish up my pocket knife and it'll do some serious cutting.  Just need the wheel and some polishing compound.
It'll also put a serious finish on most anything you cut with.
May God bless,
Dwight
www.dwightsgunleather.com
Cut some grooves across a thick piece of v-t. Rub some rouge of different grades into each groove. Then push the groover in each groove, working  from the coarsest rouge to the finest.
Edited by fredk
Nice! To push is the key. Gonna try that even though I can barely see the hole that I am supposed to hone around.
Cut the grooves really deep so the groover sits well down into the leather. Then all the surfaces around the hole will be getting rouged. Hold the groover at the same angle you would for cutting
