I’m going to try to make a 10ga shotgun belt, the one pictured above (and only picture that I could get to load because of file size limits) is for a 12 ga shot shell.  The main belt is 3 ¼ inches, the part that holds the shells is made from 1 inch 4-5 oz leather.  As you can see the holder is wet formed to hold 2 shells with a gap between them that is pushed down between the shells.  Then the holder is stitched down and the next loop is formed.
I’m not sure about the order I should use.  My first thought was to take the 1 inch holder by boiling it in water then wet molding around the shells but leaving it loose enough that I could use a nail (or maybe a wooded dowel) placed over the leather and between the shells to make the indent.  If I did that then I’d have to clamp the holder down between the loops to leave room for stitching.
Another thing that I recently read was not to burnish the edges before molding because it keeps the water from entering the edges of the leather.
Am I doing things in the right order?  Is there a better way that I haven’t thought about?  Belts like this are pretty common in Cowboy Action Shooting so I thought someone might have made one or two.
Never put veg tan in boiling water, warm water at best. theres several threads on here for making bullet loops. you don't need to wet mold them. Just search here for a thread and follow it. If you make the loop the correct size the shotgun shell will slide down into it and the rim of the shell will keep it from falling thru.
resize your pictures. free program called fotosizer, download it easy to use  its free addition and you'll beable to upload all your pic's
  • CFM
cool project
Edited by Frodo
Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
D.C.F.M
I figured out how to get the pictures in a size that I can post so here are a couple of more.
9389A49F-816C-451C-ACBA-5B27139DCBE9.thumb.jpeg.5ae74d85447056ec97bf511b9235486f.jpegA75328F2-2718-4204-914A-774E9F9A2B9F.thumb.jpeg.18f28e173278d049edd4a2e3fc645d91.jpeg
The little diamonds on the loops are stamped.  So would the order be stamp, then burnish, then wet mold, then stitch?
  • CFM
you shouldn't need to wet mold them. Stamp burnish then sew it on. 10 gauge, you may need suspenders too lol.
I’m not sure it shows up very well in the pictures, between where the shells sit in the loop there is an indentation.  Maybe I should do a trial run without the indentation.
  • CFM
word of advice,  position the strap so the lip on the rim of the shell does not ''bow'' the strap causing it to stretch the leather
loop length for a 12 gauge strap is 2 1/2'''   I imagine a10 gauge would fit that same loop???????
If looping, use a 1''' oblong punch at 1'' center to center on spacing, sew loop to belt in that center
the drawing, i found that out the hard way
D.C.F.M
  • CFM
it shows up a bit on a couple. Take two shells lay them on a table take your strap and tightly push it down both sides till it touches the table. mark where it touches move the shells lay it flat and measure it that is how much leather you need for each loop you can then stamp in the right places. you can wet form that indentation if you want it in after its sewn on just wet it and run a burnisher up and down  the shells i would be careful though you could stretch the leather and make the loops to loose. Very cool old belt! also if you make it exactly the same stitch around those corners up to the main belt farther so the liner doesn't curl up on the ends but dont stitch all the way
lol. Man shoots a biiiiiig gun!
  • CFM
DAMN IT MAN.   I have never shot  a 10 gauge
Man measurement was way off but it will give him a starting point to get to the right number
D.C.F.M
