Members RoosterShooter Posted August 24, 2013 Members Report Posted August 24, 2013 I have a cheap bench grinder that I never use, and was wondering if there is a way to adapt the 1/2" arbor to accommodate a burnishing tool. Does anyone have any ideas? Quote
Members mikesmith648 Posted August 24, 2013 Members Report Posted August 24, 2013 The only main issue with that is the speed. Usually these grinders are 3000+ RPM and a burnisher needs to be between 1250 and 1750 RPM. Quote Emergency Room Nurse by profession.......Leatherworker at heart!! Hoping to reverse the order in that one of these days!!
Northmount Posted August 25, 2013 Report Posted August 25, 2013 Do a search here for burnisher and adapter and motor and see what you get. There was a thread running here for a while on building or converting a motor to a burnisher. Parts and sources were listed. Tom Quote
Members Dwight Posted August 25, 2013 Members Report Posted August 25, 2013 Here is how I did mine. If your motor is going too fast, there are speed controllers that would probably be a lot cheaper than a new motor. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members K-Man Posted August 25, 2013 Members Report Posted August 25, 2013 (edited) It's not necessary for a burnisher to have to run between 1250 and 1750 rpms. My bench grinder burnisher ran at 3000+ rpms. Here's a sample of the edges I got (with very little effort): Here's a pic of one side of the burnisher. It was modeled after the Weaver #9 tool and made to fit the 1/2" shaft: Here's a pic of the other side: Edited August 25, 2013 by K-Man Quote
Trox Posted August 31, 2013 Report Posted August 31, 2013 I agree with K-man it depends of the material used in the burnishing tool and method of edge burnishing (wax or not). You can also make a new shaft fixed in two bench mounted frame-bearings and a V belt drive (two pulley`s that make a gear). Then you will have a pro tool, and as long as you want to without stressing the motors bearings. Frequency controllers are generally more expensive than cheap bench grinders. Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Members Murf Posted September 10, 2013 Members Report Posted September 10, 2013 Here is how I did mine. If your motor is going too fast, there are speed controllers that would probably be a lot cheaper than a new motor. May God bless, Dwight Make sure the motor on the grinder can be used with a speed control, i just built a buffer out of a cheap garage sale find and realized AC motors need a VFD (variable frequency Drive) to be able to adjust rpms and not over Amp thus overheating the motor. A DC motor can use just a variating foot pedal an AC motor has to use momentary or on/off switch unless you drop the cash on a VFD or the other thing i cant remember the name of atm. Bearman makes dremel burnishers in the same concept as the grinder mods these gentlemen are using and i have my dremel mounted into a press that also has the ability to turn sideways. Quote I tried to draw comics for a few years... I was a medic for a few years... Using a wrench is in my blood forever. Somewhere in that mess I picked up a piece of leather and made a dog collar, I was finally satisfied with something I had done. Everyday I marvel at the things I have made, and I am happy...
