Can Acetone be used in place of deglazer? I think someone told me that once.
Yes it can as can alchol, both isopropyl aka rubbing alcohol and denatured, and oxalic acid aka wood bleach.
The commercial deglazer is a mix of denatured alcohol and citric acid according to the MSDS - you can make your own with a quart of denatured alcohol and 1/8-1/4 cup pure lemon juice.
Two roads diverged in a wood, and I,
I took the one less traveled by,
And that has made all the difference.
I'd start with alcohol to see if it removes the finish first. If that doesn't work then try the acetone after the alcohol dries out. Acetone is slightly more harsh on natural materials and will pull more of the color out than alcohol will.
Chris
Three Mutts Customs Leather - http://www.threemuttscustoms.com
  • 5 months later...
I was a Tandy today and the label said it was Ethylene Acetate or something like that. Is smelled like Toulene/Xylene and Lemon
Has anyone ever tried MEK?
Anything to that?
Tom
I use denatured alcohol. It takes care of most cleaning/deglazing jobs. Oxalic acid works better if you need to remove some stubborn stains.
Well, I answered my own question <g>.... From Fiebings MSDS sheet:
Ingredients (Specific) %
Ethyl Acetate 70 - 90 %
Ethyl Alcohol 10 - 30 %
Tom
Tom
Well crap, thats 120 percent :head_hurts_kr:
Tom
20% variance in their mixture?! They must have lost their measuring cups and just eyeball it.
I went back and read the whole thing and don't see anything to indicate why that range. And Fiebing's site only shows a #12 Deglazer. MAybe they had different strengths at one time or other??? Who knows....
Tom
