MarlinDave
Everything posted by MarlinDave
  1. https://www.amazon.com/Dipped-Galvanized-Square-U-Bolt-Trailer/dp/B06Y3XS19S/ref=sr_1_7?dchild=1&gclid=EAIaIQobChMI2cGQ-tnH7wIVZ_HjBx127wGoEAAYAiAAEgJ9VvD_BwE&hvadid=409940667309&hvdev=t&hvlocphy=9013241&hvnetw=g&hvqmt=e&hvrand=12634043513001628544&hvtargid=kwd-3097009597&hydadcr=24661_11410854&keywords=square+u-bolts&qid=1616546908&sr=8-7 These u bolts might make this simpler. Could use a wood 2x6 on each side and longer bolts I guess if you lack a drill press or steel. I guess I’m a metal guy.
  2. If one were starting from scratch, 1/2 inch bearings, shaft and pulleys would be plenty heavy. 1/4 x 6 flat bar on front and back, maybe 5 inch wide, would be cleaner. 4 inch bolts would leave room for lock nuts. Grey primer would match better than red oxide. And a sheet metal belt guard to save the knees would be a good idea. I just had all this Saturday and did not want to drive to town.I measured belts and used 2 online belt length estimators and still made 3 trips to Autozone to get a fit.
  3. Yes. The bolts go on each side of the table leg and through the holes in the flat plates behind the post. Creates 2 clamps similar to a u bolt. No holes or attachment to post except the bolts pull tight. The extra hole was in the plate from its last life. Loosen bolts to slide reducer up and down. I will get a picture tonite maybe.
  4. Thanks. Sure changed the personality of the machine.
  5. I have a Consew 225 on a Pfaff table. I thought I could make a speed reducer that clamped to the square tubing table leg (many sewing tables have these). To adjust I could slide the reducer up and down. Doing this, the clutch motor does not have to be moved, the belt slot in the table does not have to be widened. I did have to move the bobbin winder back, move the motor pulley all the way right, and remove the belt shield on the motor. I had a 3/4 bore by 7 inch and 2.25 inch pulley, some 3/4 shaft, and some 6 inch channel. I would have preferred flat bar but had none. I oredered 2 $12.50 pillow blocks from Surplus Center, got 4. 3.5 x 3/8 bolts and nurs, and 2 pieces of 2 x 1/4 flat bar to clamp the reducer. Would have preferred square u bolts but could locate none. My cost with belts around $50 plus shipping. Can quickly change back to full speed if needed.
  6. Constabulary was nice enough to post a utube for me in feb. on how to thread a Consew 225. I can’t seem to copy and paste the link but it is in the thread “maxing out Consew 225”. Might help.
  7. Been trying this thing all weekend. Broke one needle this afternoon. Got it sewing perfect on scrap. Same double shoulder as the 2 holster projects. Sew the holster, it wads up under feed dog, birds nest under bottom of project. Pulled stitches out and re sewed 5 or six times. Related to changing speed or direction. Finished the 2 projects. Will have to do something not leather for a week or 2. One holster for me, one for brother. His will do. Mine looks bad. At least it is for concealment.
  8. 135 x 17 (round) size 21. 135 x 16 ( leather) size 22. 138 on top, 92 on bottom, 135 x 16 needle is the problem. Just thought leather needles would perform better sewing leather.
  9. Will not penetrate leather at times, locking machine. Birds nest under walking foot. Birds nest on bottom of stitches. With 17 needle it does none of this. With 16 it does. It appears this is all it will do, with 138 on top, 92 on bobbin.
  10. I made a reinforcement panel for an Avenger type holster. Dyed it with vinegroon before stitching. Apparently hardened the leather. My machine won’t sew it, but sews un dyed scraps of the same hide fine.
  11. For some reason it will not sew leather with leather (16) needles. Sews leather with 17 needles.
  12. Treated something last week with the December batch. It is grey, not black, even with 2 heavy coats. Kinda charcoaley.
  13. Used to be a more industrial version called Devcon. Also Liquid Steel and Liquid Aluminum.
  14. What is the diamond-like stamp?
  15. No offense taken. My employees often say I don’t communicate well. Information was very useful. My machine is missing the same thread guide down next to the presser foot that was mentioned as missing on the guy’s Singer 111. Do I need to hunt one or is this how the machine came out.?
  16. No sir. MY machine is for sure threaded wrong based on video. No disrespect to your video or info. Have been using it threaded wrong for a year or so. That’s the beauty of this group - facts.
  17. Thanks. It is threaded wrong for sure.
  18. In College I bought a $50 guitar. Never learned to play it - action too stiff for a beginner. My roommate and friends had a fantastic bluegrass band and tried to teach me to play. I could play the fire out of one of the group’s $1200 Martin flattop. But never mastered mine. I still believe if I had that Martin then I would have learned to play. Beginners need good equipment more than old hands do. Frustration compiled with beginner stumbles can make you give it up.
  19. Ate supper, went back and reset tensions and thread length. Close to where I started on settings. Oddly enough I hav both operators manual and service manual and neither shows thread path.
  20. I tried a bobbin of 138 and locked things up. Wrapped up feed dogs, lots of pulling out tangles. Back with 92 bobbin, tension is all off. And thread length doubled.And then I also thought -25 degree leather in my unseated shop is probably tougher to sew than 60 degree leather.
  21. A seeder stamp or grind the point off on a nail.
  22. Thanks everybody.
  23. Kroil penetrating oil might. Or Bolt Buster. Might hold soldering iron against shaft.
