Wizcrafts
Moderator
  1. I will do that next time I go into the shop.
  2. Bob; Will your pot and resistor mod plug into my rotary switch on my FS550s? Or, would it replace the switch completely? Does this extend the slow speed below stock and still have enough torque to turn the machine over at under 60 rpm (at the motor)? Right now my FS 550, attached to a long body Singer 139 walking foot machine, bottoms out at 1 stitch per second, with 2.5:1 gear reduction from motor to flywheel. I cannot give up my top speed. Whatever mod I might use, it must still allow full speed when needed (3500 rpm?).
  3. For a while, about a year ago, I had a problem with the top thread moving away from the center of the upper tension disks. I ended up using a drastic fix. Normally, you feed the top thread around a triple eyelet part, then into and around the tensioners. Since this wasn't hold that particular thread down all the way, I actually fed it under the steel spring pin on the right side of the tension disks, then up on the right and over. That absolutely cured the top tension problems. I had to back off significantly to compensate for the added tension from that sharp turn. Maybe this will help the O.P. Other things to check are scratches on the hook and the area that is beveled behind the point. Also, make sure the hook is very tightly mounted. Any looseness can cause issues. Check for thread remnants under the hook, in the shuttle area, or even underneath.
  4. I have tested the Family Sew fs550s at work, mounted to a long body walking foot machine, having a 2.5:1 ratio between the motor and machine pulleys. The best steady slow speed was quicker than 1 per second; probably around 1.5 per second. The Sew Pro 500 definitely sews slower at a controllable pace, in a oranges to oranges comparison. If your motor has a 2" pulley and the machine has a 4 or 4.5" pulley, your results may be similar to mine. But, if the machine phulley is under 4" your minimum steady speed may be higher. Note: it is trivial to stop the needle up or down on the FS550 to do single stitching. I do that all the time around sharp corners and inside curves.
  5. I researched the NakaJima 380 a bit and found these facts: It is a triple feed, light to medium duty, walking foot machine. It has reverse. It will sew with #138 thread top and bottom. It has limited sewing capacity under the lowered feet; just under 1/4 inch In contrast, a Consew 206RB-5 can sew into 3/8 inch of material
  6. There are several members here that are modifying their FS 550 motors for better slow speed control. One person has plans to market the components after optimizing them. This would allow one to sew from 1/10th, all the way up to 50 or more stitches per second, with one dial setting on the motor. As for the Sew Pro 500GR, it has become hard to find.
  7. I have a walking foot machine at home and a similar machine at work with each of those motors. The one at home has the Sew Pro 500GR motor and sews into denim jeans at about 1 stitch per second, steady pace. It drops out into single stitching when I try to sew slower. This is with the speed knob on full. It sews slower at about the 50% position on the pot, but loses top end. It groans loudly at the slower speeds, at 50% or under rotation. I am worried about its future. I'll try the same piece of denim at work, tomorrow, on the Family Sew 550s equipped machine. That motor is only one year old. I'll be back tomorrow afternoon with my findings. I have another FS 550 under my big Cowboy CB4500. It feeds a 3:1 reducer system, up to the flywheel. It can plow through hard leather at the astounding rate of 1 stitch every 5 or 6 seconds. Sometimes I hold it at that rate just to amaze myself and my customers. Watching thee needle move that slowly is like watching grass grow. The overall speed reduction from the motor to the CB4500 is about 9:1. On the walking foot machine it is 2:1.
  8. You can buy a Family Sew 550s for $135.00 shipped.
  9. To your knowledge, will your pot mod substitute for the rotary switch currently installed in my FS-550s? I already have great slow speed control, especially with the 3:1 reducer in the chain.
  10. That Neel's number 5 is a good machine for saddlery, like you want to do It sews just under 1/2 inch, depending on how dense the leather is. It uses heavy bonded nylon and bonded polyester thread, definitely up to #346. The machine is bottom feed only, with aggressive feed dogs. As long as the bottom appearance isn't critical to your work, this machine is a decent alternative to a CB4500. What you will lack is a walking foot that climbs up and down new layers, triple - needle feed and a 16.5" arm. Those things exist on the model CB3200 and up.
  11. My FS-550s has a rotary switch, not a pot. The slowest setting is full clockwise. It speeds up the wrong way, CCW. On the pot mod, is the slowest speed at the lowest resistance (~10 - 12k)?
  12. Bob; Are these mods for the Family Sew FS-550 motors? What is the mod to the magnets? Re the 100k pot. Is it a 10% center, log taper clockwise, carbon pot?
  13. I thought you were looking for a zig-zag walking foot machine to sew shoe leather. Are you rather looking to sew sails and small upholstery items? If so, the Sailrite portable will work for those canvas and vinyl jobs.
  14. That would be the best type of walking foot machine for sewing bags, purses, pouches and cases, or arm holes on vests and heavy garments.
  15. I once had a Pfaff 138 zig-zag machine. It was very quiet and smooth to operate. I remember that the width of the zig-zag wasn't very wide, in my estimation. I believe it maxed out at about 5 mm or so. The feed was good, although bottom only. They are great machines for cloth and sail repairs. The teeth on the bottom get a good grip and move the material along nicely. The 138 was not very good at feeding soft garment leather, which is basically sticky on top. The thread capacity was #69, if I recall correctly. It didn't do what I wanted it to do and I traded it for something else. That said, sailors love these machines for repairs to canvas or building new items made of sail cloth.
  16. As for the motors, try out various machines that are equipped with different motors. When you find happiness, ask how much that motor will be with the machine head you are going to buy. The whole package will be assembled for you and setup. You should ask for basic starter instructions, so you don't jam the machine or sew your fingers together. It may turn out that the motor you like best costs more than the one they normally sell on out the door machines. Pay the extra money to get the better motor.
  17. Sproggy; You can see my National 300N walking foot machine in close up action, on YouTube (link). All real walking foot machines work like this one. The feed dog on the bottom (not shown) works in concert with the moving needle and inside "vibrating foot" to move the material, as the outside presser foot lifts to let it go. When you go to the dealer to look at machines, this is the action you want. They may try to steer you towards a less expensive machine that has dual feed: feed dog on bottom and claw teeth on outside presser foot. Avoid it like the plague if you intend to sew leather that would be ruined by tooth marks on top.
  18. Check out the zig-zag walking foot machines on this page
  19. What I would do in your situation is buy a walking foot machine to sew the leather parts together. Then buy a good quality domestic sewing machine, new or used, to sew the linings and cloth interiors together. Join the already sewn interiors to the leather edges on the w.f. machine. You may be able to do the interiors with a straight stitch machine, which could be an old iron Singer with the motor on the back. I have three domestic machines at home that are only used for light duty flatwork cloth sewing. When business picks up you can buy an industrial straight stitch machine.
  20. I think that the Singer 292 is just another high speed, straight stitch, garment factory machine. Expect to sew at 5000 stitches per minute (83/second) to keep the oil circulating to the extremities. The stitch length will be about 8 to the inch, using #46 bonded, or T50 cotton thread. It is meant for flat work cloth.
  21. There are ways to "dumb down" a walking foot machine, to allow it to sew thinner cloth. It will never be as smooth at it as a bottom feed only garment machine. But, a garment machine cannot be smartened up enough to sew real leather. In reality, you may need two different machines: one for leather; one for cloth. Try a walking foot first and see if it can sew your cloth bags.
  22. I just learned that Toledo Industrial Sewing Machines also sells a table attachment for their CB227R cylinder arm, walking foot machine.
  23. Techsew sells a cylinder arm walking foot machine and has an optional table attachment for it.
  24. I'd sure could use a hand cranked curved needle sole stitcher in my business.
  25. Yes, the Techsew 3650, aka GA5-1, aka CB2500, all based upon the Singer 45k, will do what you want. They all sew up to 7/16" of leather, with up to #415 thread, using bottom feed only from aggressive teeth on the feed dog.They use an oddball needle system, 328, which is typically only available in sizes 23 through 27, in leather point. These needles are shorter than the type 794 needles used in the aforementioned 441 clones and Adler 204 and 205 machines. I recommend that you send some stacks of your horsehide strips to several dealers and ask them to sew them together with heavy thread, on the best, most economical machine that can do the job. Compare the stitches and bottom appearance and pick the machine that looks best.
