Grey Drakkon
Posts posted by Grey Drakkon
  1. "As I could understand of the owner of the stallion station, the halter sits more like a neck strap and less like a halter (if that makes any sense?). So it should sit further from the ears than a regular halter as far as I have understood, but I can see your concern.  The noseband seems very large to me, I can't remember the circumference, but I think it was around 32"
    Actually that makes sense, some places actually use a neck strap rather than a halter, and having the nose band higher up ensures that the nasal bone doesn't snap if things get dicey (on horses that bone is very long and thin, and I"ve heard of more than one case of them getting broken).
  2. First off I can say I would never be worried about that halter giving way!  The only quibble I can find with it is the poll strap (area that's behind the ears, where the neck joins the head) has a buckle that seems awfully high up, and might run the left ear.  Who knows though, maybe that's how the original halter was?
       Like I said, very sturdy looking work!
  3. So I made my first full box (I've made small ones with wooden lids before). I was originally hoping to have it so the top and bottom hinged together, but I would have needed to use thicker leather for it to work well (or glue another layer inside), and more importantly, take into account that all that surface tooling on the lid would significantly expand it. Turns out it made it the perfect size to slide over the bottom, so it's not a complete loss.
    Next time I'm doing all the lid decorations, *then* cutting the sides and bottom.  Also made the sides out of one long strap, and it would have been easier on me if I had just cut each side separately and done a tiny bit more stitching.
    If I had more time, I would have lined the interior, but as it was I ended up waxing it the day it was given out.  I included a pic of the sides before I stitched them, I'm sure you'll recognize some standard stamps.  ;)
  4. Very neat!  My only quibble would be the rings clinking against the axe, but I imagine some people would actually enjoy that (like spurs jangling).  Clever use of the vacuum sealer, and good on you on anticipating the texture being an issue.  That does however give ideas for placing items in when forming it to see if you can get some neat effects, like using tulle for a delicate scaley texture.
     I really dig that little kidney bean sheath, looks useful!
    There's issues either way when it comes to tooling, shaping it after tooling can mar the pattern, but tooling after shaping will warp the shape.  From what I've seen different people have different preferences, and it may depend on just how much tooling is being done as well.  That was helpful, wasn't it?  ;)
  5. Hey can someone help me out?  I'm trucking along with this pattern and have everything cut out/holes made and I'm about to stitch down the closure strap when I see that the placement of the Sam Brown button makes no sense on the pattern.  When I look at the finished bag, it looks WAY lower but in the pattern it's literally one inch from the top.  Am I reading it wrong/is it accurate and it will look fine in the end/is the pattern not right?  Wish I hadn't made that hole now if it's the last case.  :( Maybe I'll put a decorative rivet there if it is a misplaced hole.
