JLSleather
Contributing Member
Everything posted by JLSleather
  1. I change the needle more than needed, probably. They're $1/apiece, so Watch for the hole in the back to start blowing out more, and swap it out. Keep in mind that on this site, you're talking to people who sharpen disposable razor blades (not me, but some) so FWIW... For a buck apiece, needles just aren't my top priority. And I stitch continuous whenever possible. If you look at the design for a minute, I'm sure you'll see a way. If nothing else, stitch around back to the start hole, and then step over (sideways) and continue. There is always a way ...
  2. Maybe the question should be... is that 50% by WEIGHT, or 50% by VOLUME?
  3. I don't recommend boiling leather in anything. I suppose it depends on how hard you'd like it to end up... somewhere between 'firm' and 'crispy'. I form leather with warm (almost hot) water. No temp guage, just if i can't stick my hand in it it's too hot. With good leather, a holster will harden to where you don't need the gun.. just whoop an attacker with the holster
  4. You can tighten the stitch (down) with a modeling tool (or anything else that wont cut) but it may help avoid it in the future if you step the needle down one size (16) or I would likely bump up the thread size one notch -- 92 top and 69 under.
  5. OH, I see where my reply could be taken wrong.... David, when i said lacing done by somebody ELSE, I meant somebody NOT ME Yours looks great! ETA: I do it, but I don't love it.
  6. I keep a "sample' of the types of material I sew most often right at teh machine. So if I make a change, from 2 layers of 9 oz leather to one layer of 8 and a layer of 4, or to a layer of 6/7 backed with 3 oz chrome suede, etc. Takes a minute (maybe) to stitch a couple inches in scrap and adjust if needed instead of 'hoping' it will work on the project Oh, speaking as one who has made that mistake -- - I generally also check how much thread is on the bobbin before I start a project.
  7. That looks good. Personally, I like lacing better when someone ELSE does it but that DOES look good.
  8. Cut out and stitched. Then dipped in saddle tan dye (to dye the matching thread). Then wet formed. Then edges dyed chocolate. Leather cut out and dyed Fiebing's black oil dye. Allowed to set overnight and then stitched (red). Then wet formed after glue and stitch. Stamped Dyed (Fiebing's black alcohol) Formed and stitched.
  9. Bob K has a video, shows how it should go in that machine. http://www.youtube.com/embed/boZOA4MTu2Y You can fast forward to about 2:30 on that video. My machine doesn't say cowboy, and the video for this one shows the bobbin going in the other way. Likely, it can be done either way, but it WOULD change the tensions One more thing about that bobbin area. You likely have two small screws on that bobbin case, which set the bobbin tension. If one is loose, that could cause it to move on you. And if you have top thread laying on the top of the leather, then you have either too much top tension, not enough bottom tension, or both. Before you start moving dials, did you change the weight of the thread you were using? That alone can change the tension(s) needed. Still, first things first... this is the order I would do it.... Step 1.) Make sure your bobbin is in the right way. Step 2.) Test on a scrap piece of leather (upload a pic for us, that might be something we'll recognize) Step 3.) Get a cold drink, and bitch that for $2500, you'd think a simple manual wouldn't be too much to ask. Dealers are paying MAYBE half of that price? Certainly a simple sketch is possible.... If that didn't fix it, THEN move to other issues.
  10. LOTSA ways that could be done. Look in the right place, you might find entire cow sides already dyed like that.
  11. If youre wondering if the color will bleed when forming? The alcohol dyes will NOT bleed, as long as they penetrate the leather.
  12. Unless you saturate the leather with it, the neatsfoot should return to natural color once the oil has evened out (usually a day). Good to see a guy testing though! I've never used bag-kote. Thought about it a few times over the years, but ... does it shed water?
  13. Did you mean the 3200, or the 4500? The FIRST thing I would check is that your bobbin is in the right way. Anybody got a picture showing the end of this machine? I think with the 4500, pulling on the bobbin thread should cause the bobbin to turn counterclockwise. It may be you simply need to take out the bobbin, flip it over, and put it back in. Other words, with the bobbin case extended out (to put in or take out), the bobbin goes in with the thread coming off of the BOTTOM of the bobbin. Somebody with a 4500 correct this to be certain ... Oh, correction .. I see from your info under the picture that you have the 4500
  14. As a rule, the dark background on my dyed belts is done with a brush. Red sable hair, actually -- just personal preference. Reason is, there's quite a bit of relief in the belt carvings -- pretty good depth. It would be very time consuming to dye those background areas with an airbrush, while keeping the dye off of the raised carving areas. You can AIM the airbrush, but there will always be some "blow back" that really isn't well suited to depressions. It CAN be done, but considerations need to be made. By way of example, turn on the kitchen sink, just a little. When the liquid hits something solid, there WILL be some splash back ... Another example? Put a little sand on the table. Blow it off. No problem, since the concern is not where it's ending up. Now, put that same sand in a bowl, and blow in the bowl ... and there you have the problem And in the case of a tooled belt, this "overspray" would be on the sides of the carved surfaces.
  15. Not that impressive. Ever tape off the window trim to paint the walls? Same deal ...
  16. There's definitely something to be said for easy access. That Hobby Lobby store is why I stuck with the Paasche as long as I have (plus, Im cheap enough I dont like to replace what isn't broken). I put a new security light on the front of the house, which it turns out needs a simple box adapter. That little box thing is available over the counter in many stores. But not the one here - special order only. So now I have an entire project waiting on a $2 box. But this goes for many things. Wherever possible, PICK your own. Go see the leather you're getting. Test the tool they're selling. Any time you get the chance. The compressor I use came from Menard's with a stanley finish nailer. I've used those "airbrush" compressors, but fact is they'll cost twice as much and perform less. They were always kicking on trying to keep up. Just be sure you have a regulator to set the pressure (usually, I spray alchohol dyes between 15 and 30 pounds, depending). Double action definitely the way to go. You'll see people talking about it's harder to learn - pay no attention to this. I've used both single action and double action (and I've seen some STUNNING work done with both) and the double is easier to use. Oldtoolsniper mentioned aerosol spray cans. This, basically, is a single action -- one button you can push to spray paint and air. Push down half way, you get less air, but the same amount of paint (causing a different look). The double-action allows you to also control the amount of paint with that same button. Simple. In fact, that's ALL good information. Only thing I wouldn't agree with, is that you CAN paint a picture This is part of the stuff I had hoped to have up on the site by now... getting closer, though! http://www.jlsleather.com/wp-content/uploads/2015/04/rose_paint.gif
  17. Oh, I meant maybe you had a design you did in AC and morphed (or translated, or copied, or exported, or used the force) into .ai like they were talking about. Don't worry about it. Purdy much what I expected.
  18. Agreed. I see people all the time, talking about "B" or even "C" grade leather. Even if the price difference was $1/ft, you're only talking about $25 per side. My wife does the same thing. Somebody advertise gas at 10¢ off a gallon, and she'll run out $5 worth driving across town to get it. Course, that .10/gal in a 20 gallon tank saved her $2.00, so I guess it was worth it? Sometimes, when making these, I wet it a bit at the fold -- just to MAKE the bend. Won't hurt anything to do it, assuming you'll wet the entire thing later to form.
  19. I used to know a little AutoCad. Maybe you could show us some of what you mean?
  20. That's why I put that little note on the first page... "It’s recommended the user view all photos before beginning." I've done that myself! Glued a panel on the front piece of a Glock 41 holster and set it aside with some others to set up a bit. came back later, glued the parts and had it half way around the stitchin' machine when I realized the front panel was glued, but not stitched.
  21. If you are looking for one or two sides of leather, then I would recommend Wickett $ Craig. They will split the leather to the thickness you want, in natural or drum dyed. I buy backs instead of sides, so I don't pay for the bellies. Most recent purchase was $9.96 per foot (split, holstered, drum dyed). If you have demand enough that leather won't sit for long periods where you have to control sunlight and humidity, then Hermann Oak leather is quite good also. I mention the conditons because the tannery has a minimum order requirement of 20 sides. This works out well, though, if you have a couple people in the area and one of you would be responsible for splitting an order between a couple guys. HO runs a little different pricing depending on thickness. I use a lot of 7/8 oz -- "A" grade currently $7.22 for sides ($8.52 for backs).
  22. Welcome. Thanks for taking a minute to say thanks (many don't). That pattern WILL fit the Colt 5". And I don't mind seeing pics of projects made from those patterns
  23. When he was 5, one of my boys used a Paasche VL, a piece of 12 x18 vellum, and some grey dye (reduced Fiebings black) to paint a sky-scape. Clouds and sky and such. Never touched an airbrush before, but he had watched, so he put his paper on the easel, and swapped out different masks n stencils for different effects. Looked good - in like half an hour. Airbrushing - from the voodoo side -- is much like leather work. There are some who will spend their day telling you how terribly difficult it is. Probably not the case EVERY time, but i suspect that story is told so you won't try it, and become their competition! And, there will always be small men who think (or would like to think) that they can sucker ^talk customers into paying more if it's "hard".
  24. Yeah, I think I'm going to look for a new airbrush, or two. They're almost indestructable, but not entirely. These have been around a good while, and I see that Paasche has changed the design of the VL series, and not for the better. So, I'll be thinking about other models. These still work for that "fade" thing I think people do for their boyfriends ... no precision or talent or time investment required there... Some of us did HUNDREDS of ladies' handbags like that years ago. I think the big advantage of the airbrush in leather is speed. Fill the cup, and off you go. You get to skip a lot of trips back to the jar because the brush is empty. There are of course many more advantages, but until I see someone actually using one of them, maybe that's a topic for a different forum. I haven't had the time to commit to it I would like to have, but there are a couple of 'starter' images over here. That animation is a pattern from a gal on this site (sketch) done with a Paasche VL-1 (no tooling, just FIebing's dyes). And the holster is one of those things that any dummy can do in under a minute.
