        timesofplenty
                Posts106
Everything posted by timesofplenty
	Bought this new in i think 2014. Had hopes of using it but never did, it's been sitting covered in my garage. Cleaning house so it's going to need a home. Complete with extras. Also comes with a bunch of thread not shown. $2700 picked up in Monrovia CA 91016 u can text me at six1nine3four71159 thanks, scott
	This MUST be a Joke!! ...Nope!timesofplenty replied to JazzBass's topic in Leatherwork Conversation how about leaving lame political comments off the forum
	make sure the face of the cobblers hammer is polished smooth, no dents, dings, etc
	Ladies' Card Wallettimesofplenty replied to Boondoggle's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items Dig can we get a “like” button?
- 11 replies
		- bridle
- handstitched
					(and 2 more)
	Thanks everyone, 'zacly what I thought. The person quoted in the OP has repeatedly claimed that there is "danger" in wet forming "vegitan" leather, that "moisture becomes trapped" and causes the leather to "rot from the inside out" if the piece isn't "dried correctly". Never have I had a problem nor heard that from anyone experienced in leather working. dude is such a loudmouth about it and says it so often that I wanted to get some other opinions....I guess hearing bs over and over can make us question what is true
	This 1930s bicycle saddle was recovered in the 1990s, the person that covered this one passed away many years ago. Originally these saddles were formed veg tan top and bottom, with a layer of canvas between the leather and (felt or sponge rubber) padding on top and leather and metal pan underneath. This saddle was not reupholstered as original: the leather was wet formed then glued to neoprene padding. Here's what someone has suggested as to why the leather cracked in this way: "Although I do like the looks of veg tan leather...which is typically soakedso that it can be 'formed' to the contours of an object or seat pan, the inherent problemswith the process is the soaking. The leather...has a tendency to'rot' or decay from the inside out, the side of the leather that comes in contact with the seatpadding etc. I have seen a number of...saddles that have had the 'cracking fromwithin' occur. bummer. You are looking at the result of the process when it goes south. Thorough drying once covered is key to avoid thepotential for what you're seeing in the pix, but still no guarantee." I've done a fair amount of wet forming, talked to many leatherworkers, and have read many articles and books on leather and leatherworking. Never have I encountered anything to support the assertion that what said above is true. Can anyone shed some light on this?
	Source for 4-5 oz veg tanned pigskin?timesofplenty replied to timesofplenty's topic in Leatherwork Conversation Thanks, just buzzed them and it's a no, and no leads. Anyone else? sure would like to find some. It used to be made in this weight, seems like someone might still do it.
	Anyone know where I can get thick veg tanned pigskin? thanks Scott
	Source for USA-Made Cast Brass D-Rings?timesofplenty replied to timesofplenty's topic in Leatherwork Conversation Will do now, thanks! edit: "They are made at our factory overseas" I'm looking for this because I've had requests, no other reason
	You might look into photoengravers near you, should be able to make "deep etch" stamps for leather.
	Looking for #12 rivets/burrs in aluminum. founds some from packerdirect.com (credit pic below) but would like to find some in the US for cheaper freight. thanks, Scott
	I don't think it's so much a problem with "modern technology", but more with outdated forum software, and outdated file size restrictions. I'm on many much more active forums and uploading pics from mobile devices is simple.
	Need help finding this piece of hardware pleasetimesofplenty replied to timesofplenty's topic in Leatherwork Conversation Thanks, @JD62, that's close! Footmans loops are surface-mount, meant to screw into a solid surface, the ones I'm looking for are thinner and taller. The flattened ends are much thinner, and th metal rod fits into a bag punch slot, or pokes thru a slit with holes punched at the ends.
	Howdy all, looking for a metal loop like this that will fit through a bag slut in a flap with a strap that goes through it as a closure. I only have this flat metal one as an example, I need some made of round stock with flat ends, to be riveted to a bag. If anyone can help with what they're called and/or a place to buy I'd be very happy. Thanks
	Oh, and if anyone has any used ones I'd sure like to put them back into service
	Thanks folks! Yes, I think if I could find the name for this it might be easier to source. Entirely possible though that it's not made anymore also. Will try the folks you suggested. If anything surfaces I'll post here.
	Does anybody have a name for this, or hopefully a source? It's approximately 1 inch tall closed. Thank you, scott
	...and when can we get a "like" button
	problem with dropbox, photobucket etc: your pics are gone
	Will Nickel Silver Create Green Waxy Build-Up?timesofplenty replied to timesofplenty's topic in Leatherwork Conversation well heck, I'll try it and see what happens...will report back
