Everything posted by Tim Schroeder
@Dwight Do you have any problems with kinking or getting bent/folded and not be able to flatten it back out?
Help completing sheridan style pattern
Tim Schroeder replied to jstern's topic in Floral and Sheridan Carving
That’s looking good. -
Also when using Pro Resist and the Wyosheen I would use a damp/wet cloth around a block of wood to wipe off the excess followed by a dry cloth around a block of wood. This wallet was done with Pro Resist with no dye. The block helps leave the antique in any depression It just has one coat of antique and the antique is not near as dark
Sheridan Brown I wipe it on with trimmed sheepskin thin and fast in circles against the flow of the tooling and wipe off immediately with a cotton cloth wrapped around a block of wood. I did this piece in 5 different sections. I like the color the antique finish turns it but after you buff it out it still comes out pretty light.
The antique finish is always going to tint it a little bit. This piece has NO resist at all. I usually use Wyosheen for resist and topcoat. This piece has NO resist at all and I antiqued it three times to get the tooling dark enough.
Thanks @YinTx Never sold any but have given a few away. If anybody wanted something I already have I would be happy to share with them. If somebody needed a certain size pattern to fit something I would help them no problem. I would just be glad someone thought my pattern was good enough to use. I always have an issue somewhere in the pattern I don't like. I am getting ready to make my wife a new purse and I have redone the drawing a couple of times. Working on a wallet pattern as well for myself. They are finished but I need to go have them mirror imaged. You can see in some of those drawings I draw one side and then get a mirror image and put them together. On a tote bag or purse, anything with two opposite sides I will mirror image the whole pattern and one side is a mirror image of the other side. My 20 yr old printer can shrink and enlarge but no mirror image. I did notice just now I failed to mirror image the basket weave. The cats love these things. -
Didn't think about that. Good idea @chuck123wapati I'm pretty sure my metal working buddy has a sheer and the Guy I'm working for right now I know has a break and a sheer for sure at the work shop. I did find some 1 1/4" metal strapping at HD but just need to see how thick it is. This Nexbelt is only .150 thick. Two pieces of 3/4 oz and .028 Kydex comes out about the same. Curious how stiff it might be if I glue all three pieces together.
Thanks for all the input. The Nexbelt I am using has the .028 Kydex (SHC) with a ratchet buckle. I think the Kydex stops at the ratchet track. I can buy that on EBAY. I was thinking of metal flashing. I would be looking for something 1 1/8" wide. Really thin. Not sure how to cut a nice straight piece. I was looking at using two pieces of 3/4 oz. Horween strap leather. The SHC runs the entire length of the belt with the ratchet track set in the SHC. Doesn't really look all that great on the front of the belt. This belt has a 12" ratchet track. I will probably cut it down to 6" or so.
I need to build a concealed carry belt with a stiffener sandwiched in the middle. I have a Nexbelt that I am going to use the ratchet buckle from but need a stiffener. I was planning on using two pieces of 4/5 or 5/6 oz leather which ever keeps it from getting to thick. Any suggestions would be greatly appreciated. Thanks
We’ve been iced in since Saturday so decided to practice a little. Made this cover for my daily planner. 3/4 oz Hermann Oak with a pig skin liner. It’s just dyed black and Sheridan Brown antique finish over natural leather, no resist. I haven’t put a topcoat yet. Want something I’ll be able to clean and oil later. I usually Wyosheen everything and I don’t like the way water base finishes look. Oil just seems to sit on top of the Wyosheen. Any recommendations.
dyeing larger leather item
Tim Schroeder replied to stampingdelight's topic in Leatherwork Conversation
Thanks @Northmount -
I use a gravity fed HVLP no matter what size the piece is. 12" pattern means just two passes on pieces that big. I spray very light coats in all four directions. Full control of amount of dye, air and pattern. You can dial it down to the size of a quarter if you need to. The blue backgammon board in my profile albums is the best example I have to show. I don't know how to get the picture from there to here. https://leatherworker.net/forum/gallery/image/11173-braves-board-003jpg/?context=new -
Thanks again everybody. MERRY CHRISTMAS to everybody. WUTA 3.85. I bought these from PacoLeathercraft on Etsy.
Thanks for the kind words everybody. I was checking the inside veg tan and it is only .8 mm. I have found some Kangaroo to make the insides out of again. The Kangaroo is really soft and has a matt finish. I think I will make myself a new wallet after Christmas.
Thanks, I spray the whole piece brown then cut in the black. I have a small brush I have trimmed down to just two bristles at the end. Trimmed sheepskin for the black. The brown is Fiebing's light brown and chocolate brown 50/50 and then thinned 50/50 with thinner. Sprayed thru a HVLP spray gun. I don't oil after dying, just after tooling. After dye two light coats of Wyosheen then Sheridan Brown antique finish to high light all the cuts followed by two more light coats of Wyosheen. The inside pocket with his name was pretty tough. I had to do it three times to get it right with out cutting thru. That stuff is very thin. It's about half as thin as that 2/3 W&C. Makes nice wallet interiors and you can dye any color you want.
Made this for one of my wife’s coworkers. 2/3 oz. W&C. outside cover. The inside is some 1.5 mm veg tan from Frogjelly leather. All handstitched with .6 mm Tiger thread. Except the ID window.
This is for a make up bag for my wife’s co worker. Tooled on some W&C American Vachetta 2/3 oz. The second one is for wallet. Also on the W&C.
Nice set up. I really want an airbrush and the knowledge/skill to use it. I spray all my dye thru a DeVilbiss Finish Line HVLP auto paint gun. Just a great big airbrush. 55-60 lbs pressure. Any less it wants to get spotty when spraying really light. Tried the spray bottles and little sprayers at Home Depot. Not even close. I do understand what Dwight is saying about it being more like a topcoat. I use sheepskin for black and many coats usually. Everything I do is the same dye with black around it. I started spraying the dye when I made those backgammon boards in my albums. I was using veg tan for the fields, so I made a template 1/32" bigger than the points/pips and taped the stencil to the raw veg tan. Sprayed very light probably 10 coats at least so it wouldn't bleed past the stencil. No cuts in the fields. The guy was professional player. The blue on the outside of the Braves board is sprayed and it turned out pretty even. I get up to a 12" pattern if I want and total control how much dye. Almost everything has a coat in all for directions and then some. I haven't really noticed the sprayed dye being a problem with all the stuff my wife and daughter have. I still understand what Dwight is saying.
No but you can adjust the needle bar distance/needle from the hook. When I was working on my 441 I thought you would need to adjust this when going from a #19 needle to a #27. I think maybe you commented on this issue. Cowboy Bob sent the directions on how to do it.
Thanks, Yes I agree with you. I love the way the HO tools better than the WC but I don't do much so I buy just what I need for any project. Nice to be able to order by the foot. I ordered double what I needed for a wallet and these two panels and the piece I received wouldn't dye right. I tooled two of those wallet covers to match these (8 hours each) and the dye just looked like hammered crap. I still have that piece of HO but it doesn't dye good. I spray all my dye so I thought the first one was something I did wrong but the second one came exactly the same. I've never had a problem with HO where I get it but the last couple of pieces just weren't usable.
Panhandle Leather
Johanna already told us it was for the people with access to the political section. But the moderators only give it to people that support Trump. @Northmount @Johanna please take this off my profile and list me as a contributing member or put it on every members profile who had access to that section. Why only Chuck, Frodo Tsunkasapa myself and two others.
Only Chuck Frodo Tsunkasapa myself and a two other have this Title.
Just curious why only @chuck123wapati, @Frodo, @tsunkasapa, myself and two others are the only ones with CFM under their title. How come @Constabulary, @mikesc, @toxo @Sheilajeanne, @Retsweb or anybody else in the political section doesn't have the CFM. Is it only the people who was supporting President Trump? @Northmount LeatherLady takes $25 out of my bank account every year. I am a Contributing Member, but nobody would know that from the CFM title.
