Susan Kennedy
Everything posted by Susan Kennedy
Hi Bootleg! I saw your post from 2016 about sewing neoprene compression sleeves. I wanted to ask you which machine you ended up with? I have the same problem. I'm looking for a machine to sew k9 training sleeve protectors aka compression sleeves, , out of 6.5mm and 10 mm neoprene. Any input or ideas would be greatly appreciated. Thank you in advance.
Hi,
I am looking at getting a foot press for punching holes and riveting Biothane. I saw your post about you being able to custom set up Beiler's foot press. What would be the advantage of using a Beiler's foot press vs the self centering punch from Weaver's other than the price? I make heavy duty K9 collars and leashes from Biothane.
Thank you! Susan
Good Morning Susan,
I spoke with Beilers and they confirm that the spot setter can also do center punch holes as well. You only need to change the die and then flip over the L hinge in the back (to give you more force to cut through biothane ).
I'm not on this site a frequently as I'd like so please send any questions and/or concerns to my email address. tim@sxindustries.com
Thank you !
Tim
Hi Colt!
Thanks for your posts about the MT900. I am about to make the plunge thanks to you. Wanted to ask you how you punch holes for the buckle prong to go through, and also what do you use to finish the ends? Weaver recommended the Self Centering Punch, but that is way more $ than I want to spend right now. Thanks for any help you can give. I make dog training equipment and wanted to make things look more professional.
Hello Susan,
You probably wont like my answer, but I bought the self centering punch Weaver sells. It has my holes and english points built into the die. Prior to that, I was using oblong punches, and that was pits if you are doing more than one at time. Plus, you are constantly pounding all the time. I routinely make 30 Cattle collars at a time. I can build the collars in less than hour with the rivet press and centering punch.
Thank you Colt! I appreciate you taking the time to reply to me. It's hard to get first hand info about making things with Biothane. I will definitely consider buying both, as time is money. I am also looking at Beiler's catalog which has some of the same types of machines but are less expensive. Beiler's has a self centering Guide to be used on a foot press, but not a self centering punch like Weaver's. I can definitely see the advantage of Weaver's self centering punch. I have a Cobra Class 4 sewing machine so I could survive without the MT900 for a while, and just sew things, while I save up for a MT900 to do the riveting : ) Thanks a zillion!! Susan
I also added a lube pot to my Cowboy 4500( same machine as a Cobra Class 4) That darn biothane is hard to sew, especially when I am making multiple collars. The thread and needle heats up quickly. The lube pot really helps, but it is messy - splashes a lot of silicone around. Not good if you are painting or glueing in the same area.
