Darren Brosowski
Everything posted by Darren Brosowski
  1. This material can be a bugger to feed and in my experience a CB2500/GA5-1/Singer 45k25 will work fine if fitted with a roller foot. The three machines have the same presser foot diameter so the 45k roller foot fits all.
  2. I am saving up for a small lathe so I can make the bobbins. Have not looked closely at the bobbin case but think the 29k version could be ground into submission.
  3. Have you considered core spun PolyCotton or High Tenacity Polyester (AMANN Serafil)?
  4. Lots of machines are used in shoe making. The Singer 17/18 class (Seiko TE/TF) are very handy.
  5. Singer used them too and some were up or down speed units with a clutch
  6. A lot of 205 look to that machine. Suspect it is an East German copy.
  7. I have sold over 600 of these babies in the last three years but my primary market is not leather work. There are a number of problems with the basic machine in part because they test them with monofilament: - the needle bar height will probably need adjustment to avoid damaging multi strand thread - the take up lever needs adjustment for the same reason - the bobbin winder is only about 50% likely to work - the instructions are very funny but otherwise useless - toss out the needles that come with it and buy good ones - drill out the needle plate to 2.5mm and chamfer top and bottom - file and grind off the rough edges - polish the hole in the take up lever - grind off the sharp edges on the foot and coat in a rubber compound - etc. -etc. That is why I sell these for $AU295
  8. As an importer of machines I would suggest you take it back to the dealer and jam it straight up his arse. Chinese clones of the 29k are mostly crap and take a lot of tuning to get working properly. If you bought it second hand then the seller wanted to get rid of it as it is a boat anchor. I refuse to work on these for people as to fix them I need to strip them back to the bare body, flush out the metal shavings, replace all springs with equivalents from Taiwan and then rebuild. For the cost of the labour to get the piece of rubbish working I can airfreight a new machine in from Taiwan.
  9. Reminds me of the 20U class feed dogs and needle plate.
  10. Just to confuse the issue........ Consew was (or maybe is) a marketing name for Seiko machines in the west. Most Consew machines were rebadged Seikos which were derived from older Singer models. Most of the Cylinder bed machines were the top half of a 211 but Seiko had this new fandangled idea of putting reverse on everything!
  11. LOL, during the war it is a certainty that Singer would have been making weapons or parts for them! I'll have one too - a matched pair would be better
  12. I think I need to work on my technique Bob as I tend to use a bloody big hammer on most old machines.
  13. Minor issues with both machines. 45k bobbin winder is readily available and I suspect that a 29k (or Chinese equivalent) bobbin winder will fit the ADLER. The 45k appears to have a reduction pulley set so speeds should be good. Both machines are a great addition to any leather shop but as is from a private seller I would not pay more than $1000 for the pair.
  14. Would be using a 20g needle with #92 for a start If the machine uses a 794 needle then it is a long thin needle for the job.22g or lower I would be using a machine with 135X16 needle.
  15. There are two types of bonded nylon - internal and external bonded - and I would not use either as they damage the thread path over long periods of time. High Tenacity or Bonded Polyester are mush less abrasive and have better UV protection
  16. Based on the Seiko CW8B which is the Consew 227R.
  17. ADLER are not interested in the hobby guys like most on this forum. I hope I do not offend Bob, Steve, Ronnie or others but if I was running a machine 8 or more hours a day, 6 days a week then I would buy the Adler. The Chinese machines are good but I am not convinced they are at full production quality yet. Even dedicated saddlers rarely use the 205/441 class machines for more than a few hours per week and mostly that is at LOW speed which limits wear on load bearing surfaces.
  18. I saw an SD28 today - the Pederson version - and as always it was a joy to behold. If I had the money I would seriously consider having a modern version made in Taiwan using a commercially available needle and shuttle.
  19. Bill they are not reproductions. These machines are made from original Singer/Pfaff tooling and drawings. The problem is that sloppy Indian practices have led to everything becoming corrupted over time...... There is something of a revival of interest in old machines in Australia and I would like to think I am helping it along by supplying new parts.
  20. Anyone who has been watching my posts over the lasts couple of years knows that I like to stir things up and get people asking questions. For portability the Boss has no equal. My concern is the huge number of problems that crop up on this and various other forums.
  21. Often when picking between dealers it comes down to whoever is closest amongst the suggested dealers and this is no reflection on the others. In the rare event that things go seriously wrong then the closest dealer is the lowest cost shipping option. A good businessman is not just interested in the machine you buy today. We all know that you are going to have numerous machines over the life of your hobby/business so they want to build a long term relationship to supply needles, parts, motors, etc. It may sound a bit mercenary but we want to build trust both ways.
  22. For the relatively small numbers that are out there I am constantly astounded by how often users are posting problems with the Tippman machines. On the other hand people are buying machines then adding servo motors and reduction pulleys to get them to run at low speed. To make any speed adjustment you need to lean under the table while the machine is active to press a set of buttons. If you want reliability, simple speed control and two handed control of the work then buy the machine you need and mount it on an industrial treadle base. I have watched Jim Beaton run an Adler 205 clone on a Singer treadle going slower than the best servo motor and then flat out. No playing with buttons - just perfect operator control
  23. Anything made in Germany will have labeling to proudly and loudly announce the fact so no label = made in China. Made in EU could be Poland, Czech republic or elsewhere. Some Adler machines are made in the old Minerva factory in the Czech republic and this is not necessarily a bad thing as the old Minerva machines I have are every bit as good as the Pfaff 30. The Pfaff 30 is about the best straight stitch domestic machine ever built so this is high praise.
  24. The machines I have brought in are brand new and my business partner and I specialise in vintage machines. The Indian 130 has been modified from the original design to do excellent (we hope) free motion embroidery so it has potential if the machine quality is ok. Dozens of companies are importing shit quality plastic domestic sewing machines so why can't I throw a couple of new build cast iron machines into the mix?
  25. I think I have the Frankenstein of all Singer 45k25 Machines. It is about 75% Singer but it also has a bunch of parts from India, China and a couple of my own adaptations. You are probably wondering why but it is an exercise in finding parts to keep these wonderful machines running on for another 100 years.
