SARK9
  • Content Count
    390
Everything posted by SARK9
  1. The Juki LU-563 should have reverse, plus the way larger *U* bobbin. The 225 is ....without reverse. I'd go with the 563 myself. -DC
  2. Hi CD- I've mounted several shop-made reducers to similar machines with few issues. The troubles I've run into were simple location issues. With the large (8-9") driven pulley on the reducer, I have encountered some clearance issues with the larger diameter motor pulleys- the two will actually interfere when you locate the reducer mount so that its small pulley is aligned with the sewing machine pulley. You may need to switch out the motor pulley for a smaller one to gain some room closer to the motor for your mounts. The other issue is just to be able to shift the motor towards the "right" toward the nearer K-leg so that the motor pulley is aligned with the large driven pulley's offset. We have a chain of stores in my area called "Tractor Supply" that has a good selection of 3L belts in the usual size ranges... They usually have the smaller motor pulley you need as well...but not the 15mm bore type I need on servos. I have a picture of one of mine mounted under a Chandler CU-563 which is similar to your Consew.
  3. Various torque multipliers I've banged together
  4. From the album: DIY Speed Reducers & accessories
    I hate the amateurish binding I am getting.... If I get the 251 set up like I want it it will STAY set up!
  5. SARK9
    Reducer W 251 21
    Another view of the latest reducer.
  6. From the album: DIY Speed Reducers & accessories
    Someone is in the "practice making little pouches" stage of their sewing evolution.
  7. SARK9
    Don Val
    Some old guy that likes to run up and down mountains with his little dog.
  8. SARK9
    251 21 W reducer
    The completed torque multiplier next to its intended victim
  9. SARK9
    9inReducer
    Finishing up the 9.2" reducer pulley....
  10. Steve and Bob -Thank you both for your replies, and my appologies for taking this long to respond. Part of the conflicting info I've been a bit stumped by is this excerpt from the 251-21 PARTS manual- And some very different information from other sites such as ISMACS.
  11. New guy to the forum here. I'm having a bit of a time finding much info about this particular machine...I am wanting to set this up as a dedicated binder for edging a couple of layers of 1000D Cordura, but I'm finding conflicting info as to even which needle system is correct for this variant. I did find a parts list specific to this machine, but no general operating manual with the specs. I was pretty much given the machine and stand with not so much as a spare bobbin, let alone the paperwork. Has anyone here used of of these and/or maybe seen a copy of the manual? Thanks! -DonC.
  12. SARK9
    speedr_01
    Shop made torque multiplier/speed reducer on a Chandler CU-563 (rebadged Juki?).
