Everything posted by Big Sioux Saddlery
Make a note of it cuz it don't happen every day! I'm usually the last one to "get" a joke. And I'm not even blond!
- 20 replies
- basketweave
- layout
(and 1 more)
Just messing with you. . . SD people have always poked fun at MN and IA people. And I'm not sure most of these eastern SD people really have any room to be making fun of anyone. Bunch of whiney-assed, welfare raised, self entitled corn farmers. And I was raised here! You're OK!
- 20 replies
- basketweave
- layout
(and 1 more)
Because you now live in MN!
- 20 replies
- basketweave
- layout
(and 1 more)
On projects where there is a left and a right, such as a saddle or pair of chaps, you end up doing both. One side mirrors the other, or at least that's how I do it.
- 20 replies
- basketweave
- layout
(and 1 more)
I've noticed that also, and it detracts from the look of the finished product. I don't know just when it happened, but it hasn't been terribly long ago that the rivet heads were smooth. The boxes they used to come in were labeled Clendenin Bros. The boxes they come in now are not. I don't believe there is a manufacturer's name on them at all, which leads me to believe they are manufactured in China, like most of the other hardware and findings on the market. I searched for Clendenin Bros. and they are still in business and still manufacturing nails and rivets, but there are no pictures and there isn't a lot of information on their website. They are based in Baltimore, Maryland. Might be worth a call.
Thank you Ferg. I did find that one also, but was hoping to get one for less than $40. It might end up my only option though if I want it soon!
Craftool made some of these in 1996. Prefer metal over Delrin. Need ASAP. Thank you!
Some pretty darn solid advice right there. I can think of a couple different things that I struggled with, until I decided to dedicate a day (or two) to doing nothing but making that one particular thing that was giving me trouble. This does several things; it gives you a chance to evaluate each step and what you may be doing wrong RIGHT THEN and gives a chance to fix the problem RIGHT THEN instead of waiting another month or year until that same project comes at you again and you can't remember exactly what went wrong or where you hit a snag last time. Doing something many times over in a short amount of time establishes the correct sequence and method more deeply in my mind. Kind of like muscle memory? If I do it enough times, until it becomes easy or at least there is no struggle at any step of the process, then the next time I do it, I almost don't have to think about it. If I learned it well enough, I can wait even a year and the process is still tucked away somewhere in my mind. (although as I get older, it becomes tucked further away!) Another thing I've done on something that is particularly difficult for me, is to make detailed notes of the process once I get it down. Then review the notes before I start on the same project if it's been awhile since I've done it. Saves my failing memory from becoming overloaded:-) Two specific things that this really worked well for me: making "rounds" or many people refer to them as "rolled" leather. The exact measurements of turnbacks and how much to skive off, how far to cut the channel, etc is super critical in doing a good job of these. The other thing that immediately comes to mind is buck rolls. If you aren't a horse person you won't know what these are, but suffice it to say they are a royal pain in the butt and I don't know anyone that likes to make them if they are trying to get paid for their time and are at all fussy about their finished product. Anyway, great advice from Bikermutt! Good luck!
That's interesting, Tom. I always wondered if #9 wire was the same as #9 rivets, but it seems like #14 rivets are a little heavier than #14 fence wire. Not that I've ever put the two side by side for comparison or measured with a dial caliper. Always learning something here! Thanks!
I don't know about Montana Leather, but Weaver has as small as a #14 copper rivet with burrs. They are pretty dang small, in fact I only rarely ever use them. They also have a #12, which I use occasionally. I can get measurements later if you want, or maybe someone else knows what the specs are on those.
Heavy and stiff, but not rawhide?
Big Sioux Saddlery replied to JimTimber's topic in How Do I Do That?
Yeah, I'd like to win that too! -
Do you use horses in the woods? Surprisingly, quite a few people still do. -
Ok, I'll see what I can do. -
How big of a piece, or pieces, do you need? I'm sure I have lots of stuff that would work. -
Wickett & Craig vs. Hermann Oak comparison!
Big Sioux Saddlery replied to zaynexpetty's topic in Suppliers
I will add to what Jeff said, that the HO looks spilt, and the W & C looks more like full thickness. In addition to that, the far right piece looks like it might have been cut from an area that will quite often have some loose flesh; flank or front pocket on the hide. These areas are thinner than the rest of the hide, so when they go through the splitter to be leveled at the tannery, that specific area might still be thinner than the splitter is set, so it doesn't get cleaned off. I use both HO and W & C, I've had less than stellar sides from both, but they are both good leathers and I wouldn't worry about what you're worried about:-) And depends upon what you are making, but if doing strap work, it's not that hard to clean off some loose flesh by pulling the strap through the splitter. Sometimes there'll be a little in the shoulder area because of the run-off in weight there. Ya just deal with it. -
I personally would use sole leather for this. Heavy skirting, maybe even some that is kind of "boardy" that wouldn't work for saddle parts would be good too. I think I have a couple sole bends somewhere. If you don't want to buy a large piece, and are not in a hurry, I could cut and sell you some off of mine. But the next couple weeks are going to be brutal here, so I don't know if I'd have time to get right to it. -
Get used to that if you stay in this craft. Been doing this for 40 years, 25 of that as a business, and it never does end. The only difference between now and in the beginning, is that now I know it DOESN'T end. Have fun and good luck!
Briefcase For My Brother
Big Sioux Saddlery replied to Equiplay Saddlery's topic in Satchels, Luggage and Briefcases
Did you use W & C's Traditional Harness or Show harness for this? Whatever it is, I like the look of it. I don't think I've ever used a side of their russet, although I've used a lot of their black. I'm toying with the idea of ordering some of W & C's burgundy Harness, as HO has stopped producing their Rosewood, which I thought was absolutely the prettiest leather. I like the cart buckles on the back pockets of the briefcase. -
I've recently tried using Weaver's clear Tuff Kote, in place of Resolene. So far, I like it better than anything else I've tried, which includes RTC, Neat Lac, Resolene, Tan Kote, Bag Kote, and years ago, Super Shene. A couple days ago, I used it as a resist under some Tandy Antique gel stain, and was very pleased with the results. However, I haven't put a final finish on yet, so there's still time for a disaster:-) I did use it on a dark saddle as a top finish and didn't have too much trouble. Applied with sheepskin, about anything seems to lift some antique. I'd had both the clear Tuff Kote and the Tandy stain around for I don't remember how long and kind of forgot I had them. The Tandy stain was a color I needed for this specific project. I'm sure Tuff Kote is an acrylic, but it doesn't smell anything like Resolene. I've been using the black Tuff Kote for years as an edge finish for black harness and also as a top coat, if I use one at all. I like it better than the other harness dressings I've tried. More often than not, I don't top coat finished black harness, as in a year or two it all flakes off due to the high wax and oil content in the harness leather. Then the customers freak out because "the finish is peeling off my harness". Anyway, I digress. Anyone else tried the Tuff Kote?
I always thought that Resolene and Supersheen were the same thing, just different brands. I have nothing to add to the above, but I would sure go through all the steps on a practice piece. After all these years, I STILL do not have the perfect finish sequence/combination figured out. What works on some things is a train wreck on others. Nothing pisses me off more than putting days into a project and ruining it with a poor job of finishing. Makes for a bad day.
Yes James, you are correct in thinking brass would wear faster, but I do have a collar with a stainless fastener that is worn bad enough to fall open also. I guess if you use any of them long enough, they'll wear. I'd be interested to hear if anyone that's been using them for a time on bag and case work have seen this. Just out of curiosity I was wondering how long this fastener has been around. I have a fairly old, very used collar that has this fastener made from steel. I searched some for patents, but didn't find anything on this one. I did find collar fasteners that were patented in the late 1800's that I have never seen on a collar.
- 6 replies
- stays latched
- no retainer strip
(and 1 more)
No, almost none, because the hames hold the collar together when it's on the horse. I think it's just the repeated fastening and unfastening that causes the wear. On one that's worn bad enough to come apart on it's own, all you have to do is pick the collar up and it unhooks and the collar falls open. Nevertheless, they're pretty popular and many people request that fastener on their collars as opposed to a buckle and billet. They are easy enough to replace IF some genius didn't rivet them to the straps holding them on. They are made to be adjustable and do not need to be riveted or sewn to the straps holding them on the collar. However, on bags or cases, I realize that it doesn't look as neat if they aren't sewn.
- 6 replies
- stays latched
- no retainer strip
(and 1 more)
When used on horse collars, those latches will wear to the point that they fall open on their own, and the wear isn't necessarily visible. There just comes a point where they don't stay fastened as well.
- 6 replies
- stays latched
- no retainer strip
(and 1 more)
Nobody seems to want to be the first, so I'm going to dive in. First of all, if you want to build saddles for others, I'd suggest you either get some instruction from an experienced, good saddlemaker, and/or expand your book/video library. A good place to start is the Stohlman books. Harry Adams' book gives some good practical advice on making patterns. Jeremiah's videos offer a lot of good advice. There is also information in all of those that I don't agree with or follow. That is something you will decide for yourself as you progress. One thing that happens, though, when starting out, is if you get TOO MUCH conflicting information, it's more confusing than helpful. Nearly all the books and videos out there will give you SOMETHING beneficial, but none of them give you everything. Stohlman's books will go the furthest toward helping you build a saddle that looks and rides good. There are things they do that I don't agree with, but if you follow them through the entire process, they don't leave many unanswered questions. I'm pretty sure I know the video and book you started with, based on the style of ground seat. I never have been able to understand how anyone, male or female, could stand to ride a saddle with a seat like that. You already stated that it has more rise than you'd like, so at least you are recognizing that changes need to be made. The first thing that really stands out to me, and you mentioned, is the fit of the jockeys, and the skirts. Part of that is the skirts don't appear to have blocked to the tree. This is visible not only at the rear, but the front as well, and you have not finished opening up the gullet by nailing the skirts to the gullet. Study well-made, finished saddles and you will see what I mean. It also looks like you didn't spike your jockeys down tight during final installation. They may need more trimming/fitting when you do this, but the process of spiking them down will help pull them tight against the skirts, as well as the cantle back. Getting a good fit on the jockeys for me is a time consuming process, and I still struggle with finding a better and faster way to get a good fit. As you mentioned, the skirts could be longer. Being able to make your own patterns for any style and size of saddle is part of the long learning process of building saddles. Better instruction, as well as experience, will help you with this. Your front rigging looks set back further than 7/8ths, and rigging position is a very subjective subject, or at least everyone has an opinion on where they like them set. The rear rigging is also set a little further back than I normally place them. Calf ropers want them back further than most others. Typically if the leading edge is about even with the point of the cantle, I feel that is about right. The cut of the top of the front ear of the front seat jockeys is too high. I don't like to see it higher than the top line of the skirts, and preferably a bit below it. Again, they don't look pulled in tight to the tree. Cantle bindings are tough. It took me years before I was happy with the way mine looked, and my rawhide bindings I'm still not always perfectly happy with. Your binding leather looks way too heavy. Either use lighter leather or do more skiving. Just that alone will make it easier to form at the ear. Don't be afraid to spend some time getting a good fit. Moisture content is important, just like swell covers. Too wet and it doesn't mold as well. Your stitching, from what I can see, looks better than about my first 5 saddles. I can't see it very well, but it looks fairly straight and evenly spaced for a first attempt. You swell cover welts don't look bad for a first attempt. When trimming a single welt, a tool called an English edger (I think) works well. It's kind of like a French edger, except the bottom is concave and there is curve to the blade. To my knowledge, they aren't made anymore, so they are expensive and you'll have to search to find them. It will leave a nicer profile to the trimmed welt: instead of being flat, it will have a slightly rounded finished surface. The turned-under front could have used more skiving. I can see a lump through the cover where the edge of the leather is. A common mistake is to not extend the front far enough ahead, but yours does come out past the rim of the fork. Some people may not like that look and prefer it back further, but I do like it out a bit. If you spiked the cover down tighter, you would get a tighter fit at the front. As far as the horn cover, yes it's not centered, but I would also like to see a little smoother overall look to it. I prefer a little bit of a "dome" to the cap, and this is determined when installing your filler. Lighter leather can be used here too, and that will help. The edges could be finished up a little more, which will add to a nicer finished look. A heavier edger as well as sanding and truing up your edges, and then rubbing like heck to get a burnish, will do a lot. In fact, better edgers and more burnishing on all the saddle parts will make you more pleased with the results. These are just a few things that really stand out as first glance. They are all very common beginning pitfalls, and there are more "pickier" things that I could point out, but I don't want to be overly critical or discourage you. I commend you on your desire and perseverance of starting AND completing the saddle. It's a big undertaking when you have virtually no instruction. Best thing you can do, short of going to study under a master, is buy better instructional material and look at lots of top-end saddles for hours on end, looking at the overall balance and flow of design. I'm not talking about tooling, I mean the parts fitting together and providing a balanced look to the saddle. One of the masters of the trade, Keith Seidel, will hopefully add to, or possibly correct, my advice. Best of luck!
