Everything posted by dikman
Redneck philosophy 101.
an alternative
dikman replied to chuck123wapati's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Who's a clever boy then? That's thinking outside-the-box. -
I made a horizontal spool holder with the shaft running on bearings to enable a smooth feed. It works but I don't use it (much) because I don't normally sew long runs so I rarely have twist problems. Braided thread - I have a spool, it's really nice stuff (came from a boot factory) but in "normal" walking foot machines it's a bit of a bugger as the needle has a habit of stabbing through the braid occasionally during sewing. I think the braid, being soft, opens up a little during sewing.
Try a fortune teller's crystal ball, I hear they're pretty accurate.
I would have just lined the jaws with thick leather, won't mark what you're clamping and has a little bit of give.
- 22 replies
- swiss leather tools
- swiss army leather
(and 2 more)
Singer double needle thread snagging and skipped stitch on one side
dikman replied to DMH's topic in Leather Sewing Machines
My first thought was a burr somewhere on that side that's catching the thread? -
Is this any help? https://www.usermanuals.au/duerkopp-adler/467/manual
Thinking about it I could probably make one out of pallet wood, some of that wood is pretty good stuff (and cheap) once it's cleaned up. The latching mechanism looks pretty easy to make, just a bit of welding required. The hardest part would be drawing out the pieces so it will actually work, then it's just lots of time!! I hope you're making scaled drawings of yours as you go, ClaimedVacancy (hint,hint).. It's looking good so far.
- 22 replies
(and 2 more)
Dyeing leather
dikman replied to Samalan's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Maybe you're just accident-prone? -
That's $1500 Australian!!!! Plus shipping!
- 22 replies
(and 2 more)
Looking good. It was on a facebook site by a guy called Slickbald (used to post on here once I think) and the photos were posted on there, so not for sale. I had a look at the website I mentioned but it's in German and I couldn't find the clam on there.
- 22 replies
(and 2 more)
You do some very nice work indeed Meelis.
I came across this on facebook so saved the photos but unfortunately there were only the two. The locking/release mechanism is interesting, could be an interesting project. It is marked www.swissleathertools.ch but I can't find out anything more.
- 22 replies
(and 2 more)
My first thought too, all those pointy bits sticking up made me cringe! I can guarantee I would stick myself!!
Chiappa Rhino 60DS drop holster (stange situation)
dikman replied to DoubleKCustomLeathercraft's topic in Show Off!!
Very nice. You did a good job of keeping it clean considering all the handling it would have gone through. Given that you have no idea what the other shop is going to do I think I would have gone with dark brown/black stitching? Certainly a strange situation, what sort of "custom" shop does Western-style gunbelts but not holsters? -
G'day cobber, good to see another Aussie on here. Which State are you in? The 132K6 is a good solid machine but be warned, an interest in sewing machines can lead to a very deep rabbit hole!
I checked some images on google and the model number would be next to the 211 on the front but yeah, not enough detail in the photo to see. Can you contact the seller for more information? It looks to be a later model 211 and as long as it's working should be a nice machine - depending on the price, of course.
The numbers are just numbers to use as a reference, you'll probably have to make up a sample with different stitch lengths and write the corresponding number next to them. I've had to do that before.
Mario, we'll need more information as 211 by itself doesn't mean a lot. There will be many model numbers after the 211 which will indicate exactly what they're for and where they were made. The 211 series of machines are good machines - but that's all that can be said without more info/photos.
Or you could go olde-school and use a copper rivet.
If the pan you've fitted is working at keeping the oil off you then I wouldn't worry too much about getting the correct one. As for oiling, you don't have to use the wick system, just oil it manually. Basically just give any parts that are rubbing/in contact/sliding etc a drop or two of oil. If you can master that clutch motor then well done but life will be easier if you swap it for a servo.
Well, that's different, and looks pretty neat. One potential problem you will have is the snap-down strap is stitched across and because the strap will have to be bent at a sharp angle to remove/insert the coin it will eventually tear at the "hinge point".
As Bruce said, a rubber mallet is probably the worst thing you could use as regards stamping efficiency. There are also many posts on here about people making their own.
I agree, very nice indeed.
