kgg
Content Count
2,519 -
Posts posted by kgg
1 hour ago, BigDogPaul1962 said:I'm a broke dude so I have to watch my expenditures very closely and this is something I usually do for myself before I buy anything.
Thank you for the comparison it is helpful and shows it pays to shop around. You maybe a "broke dude" but I'm a cheap "old geezer". Why pay more for the same item particularly these days.
kgg
10 minutes ago, Pink1977 said:What does mean this document please ?
It is a quick cross reference of the more popular machines that are or have similar operating specifications.
13 minutes ago, Pink1977 said:And i don t see mine i bought : Pfaff 145
If I'm not mistaken your Pfaff 145 is an older version of the 545 and the latest version being a Pfaff 1245.
2 hours ago, CowboyBob said:Thought some of you might like to see which machines compare to each other.
Thanks for sharing the quick cross reference.
kgg
6 hours ago, dikman said:One of my grand-daughters is sick
Sorry to hear that but she should really like the dragon. Nice work, great detail.
kgg
1 hour ago, DieselTech said:If nothing else I can chalk this up to a learning experience.
I haven't tried this myself but maybe an old fashion Singer 15 might be able to sew the wrench rolls if you use V92 and a basic sewing design. They can be had for very cheap might be worth a try.
kgg
3 hours ago, DieselTech said:What would be needed to do this?
I would suggest it would be easier to do on a flatbed like @Wizcrafts noted. I use my Juki 118n for 20 oz canvas. I would also suggest using V138 rather then V92 also the hole that the needle of your 441 makes maybe is going to be more noticeable then that of 135x 17 needle.
kgg
22 hours ago, bladegrinder said:$20,000 wow, how big of a generator were you looking to get?
37 minutes ago, Northmount said:10kW Generac at Home Depot $5000 CAN
In Ontario a 22kw(propane)/ 19kw (LG) Generac is about $7500 at Homedepot but...then it will cost another 10-12k for installation (site location /preparation) / approvals (electrical / propane / township / protected lands / insurance) / inspections (electrical / site / propane) for it to be allowed. Other then the site preparation most people are at the mercy of the certified electrical / propane contractors that will be needed. A neighbor last summer had one installed and said by the time it was all said and done you couldn't buy a pack of smokes out of the what was left over from 20K. The way around this for a lot of us is a portable 10kw multi fuel generator (gasoline/propane/LG) for about $2500 installed in a prefab 100 square foot shed for about $1000. The drawback is you don't get auto start / auto transfer.
kgg
1 hour ago, waynebergman said:have the option of buying a 281-21 for cheap. $100 and its seems in good shape.
This is a high speed machine made for sewing fabric and is only a drop feed with a max thread size of V92. It may very well sew very very thin leather but I wouldn't bother. The price is OK but adding a servo motor to get good speed control is going to add another $200 CAD which could go towards another machine made for leather. How thick of leather are you planning on sewing and in what thread size??
kgg
8 hours ago, bladegrinder said:Yep, one of the first things I did when I moved here was install a Generac 2200 KW whole house generator
Having a generator is a must when living out in a rural area. Last summer I had to replace my Briggs 10,000 watt whole house generator. I did look at the Generac generators but $20,000 wasn't in the cards. The old generator finally gave up the ghost and to repair it would have cost more then a brand new unit. The old one had 930 hours run time on it so I didn't feel to bad. This time I got smart and built a generator house with AC lighting, DC lighting and with my batteries on flood charge all the time. No more standing outside during a snow storm, wind storm or pouring rain. Open the shed door, turn the DC lights on, start the generator and way to go, comfort.
kgg
1 hour ago, Cumberland Highpower said:I contacted by phone and email every one of KGG's contacts, not a single reply or "getting back to you".
Well that was a waste of time mostly for you. Sounds like great consumer service, NOT.
kgg
6 hours ago, Southerngunner said:I did plan on adding another 1-1/2"x1/4"angle across the front but I ran out of material today .
I should clarify my suggestion on the front edge angle iron. I am assuming you are planning on cutting out a fairly large section with the base of the machine sat on the front to back edge just under the machine. That would mean the edge of the plywood would be unsupported. That is where I have seen sagging. I solved that potential problem when I moved to the 441 by adding a extra leg directly under the center of the machine.
6 hours ago, Southerngunner said:I need to decide what to mount for the go pedal and presser foot lift.
If possible go to a industrial sewing machine repair shop as they typically have old table setups. They usually sell the bits and pieces like the complete frame or individual parts like the pedal and cross member pretty cheap. I usually pay about $50 CAD for a complete frame.
kgg
9 hours ago, DieselTech said:Guys & gals I recently bought a new cobra class 4, I would like to have at least 1 spare shuttle hook assembly. In case something happens.
I would suggest that before you go installing another shuttle assembly first make sure the original setup sews properly first. When in the reverse the needle drops down into the same holes made in the forward motion. The best and simplest way is with a sheet of heavy paper and without the needle threaded.
kgg
7 hours ago, Southerngunner said:Also I have to pick up more metal,casters, and 3/4" plywood for the table top and side cabinet.
The metal frame looks really good. A couple of things to keep in mind:
i) Why are you installing casters?? Unless you are going to be moving it around a lot they maybe a waste of effort and if you decide to install them install the lockable style.
ii) The table top needs to be 1.5 inches thick so I would suggest doing your cutout for the machine base first in the top 3/4" piece of plywood then glue the bottom layer of 3/4" to the top layer. Remember the grain of the mating surfaces of the 3/4" plywood have to be 90 degrees to one and another to get max strength.
iii) You may want to consider welding a 3/4" x 1/8" tick angle iron stiffer across the front to prevent any table top sage along the front edge. I have see some tables that had a bow in the front.
kgg
14 hours ago, Tsiatko said:I’m also noticing that it’s really stretching my chrome tanned leather, is this just the nature of the compound feed or can I do something about that? Is chrome tanned just the wrong choice material?
A couple of questions:
i) What size of thread are you using??
ii) What size of needle are you using??
iii) How thick is the leather???
iv) Are you using an edge guide??
If I'm not mistake the Consew 206 RB has similar specs as the Juki 1541S (compound feed). My 1541S hates anything under say 4mm particularly soft items that can be pushed down into the needle plate opening. For those type of items I use my Juki 1181N (walking foot) but on occasion have placed a sheet of paper on the needle plate side of the item to help stiffen things up.
kgg
10 minutes ago, DieselTech said:When you step on the foot pedal release, it actually forces the disc's together instead of separating them.
I would try handwheeling so the thread arm is at the top of it's cycle. Looking at your photo I am thinking that some of your problem maybe the thread is not seated properly between the top tension discs. I would suggest looking at this video on threading a Cobra 4 ( https://www.youtube.com/watch?v=6tCzNuj4bvQ
Notice the difference in your thread in the top tension discs, yours is the first photo.
kgg
13 minutes ago, DieselTech said:What adjustments need to be made? Is there a actual # for the feed dog height above the needle plate?
I would suggest checking the engineering manuals that came with your machine. If none were supplied I would suggest 1) call Leather Machine Co. 2) refer to the Juki TSC-441 Engineering manuals or call the supplier of the needle plate / feed dog.
kgg
6 hours ago, toxo said:The drop down guide has defeated me.
I would email the company and ask for instruction.
kgg
3 hours ago, NatesLeatherGds said:Wrapping around then snapping together - with some foam glued inside for padding.
Have considered using Velcro rather then the snap???
kgg
51 minutes ago, MtlBiker said:For all the leather accents they said to apply Neatsfoot oil BEFORE the Fiebings Dye.
My limited experience is using a spray gun for dying. First we dyed allowing it to penetrate into the leather then oiling. Once you get it to the shade you want let it dry and then oil. Oiling first I think would only provide another barrier to the dye.
Just my experience,
kgg
9 hours ago, NatesLeatherGds said:continue free handing or go in for die cutters?
I can see a die cutter would be faster but like @AlZillaI also don't see how that will eliminated the stretch problem. Have you tried a slightly larger hole for the ring snaps and using a lever press???? What are the items going to be used???
kgg
33 minutes ago, Handstitched said:Thats all well and good in the cities, but out here in the bush, its very hit and miss.
I know what you mean when we moved from Newfoundland and at time we were rural we had fiber cable. Then we moved to Ontario to another rural area and it was like we were back in the dark ages even cell phones on the property were a hit and miss. We finally went point to point with our own dedicated connection where we do not share our bandwidth with anyone else but had to install a 100' tower. That was a chuckle and a half.
kgg
1 hour ago, toxo said:It's here. Putting it together as we speak. Haven't found any damage so far. Can't wait to sew something.
That is get news. Before you sew anything oil the hell out of it just in case there are any filings / dirt inside.
Was the delivered cost what you expected or were there any additional surprise costs like brokerage/duties/etc.
kgg
12 hours ago, ThomasBH said:Any suggestions or help would be appreciated!
I think you main problem is the type of binder you are using. The ones you show are all wide mouthed binders made for sewing edging onto thick material. As @nylonRigging has said getting the correct binder is a must and setup can be a pain sometimes. You need the item to fit through the binders mouth along with the binding tape and the tape to be fairly snugly wrap around the item to prevent slop / wander and provide better tracking. Finding a 90 degree binder with a smaller throat opening maybe difficult as this depends on what you are binding.
I do have the 90 degree binders but I never use them. I prefer the inline style for a couple of reasons. I can use the same binders on any of my machines flatbed or cylinder bed, cost, more readily accessible option like raw edge or double fold and I can easily bend the mouth open or close as needed. I also find the guiding the items edge through the binder easier as the inside edge of the binders body gives me a guide edge to follow. However the 90 degree binders do allow you to get tighter bends then the inline style.
Maybe try modifying something like this as they only cost about $15.
kgg
4 hours ago, DieselTech said:I'm trying to cheap out on a smaller machine. Something I can set up with 138 thread & not break the bank.
Like @dikman has suggested I would suggest you look at Class 341 machines for cylinder arms:
New: Class 341 clone machines ----- Cowboy CB341, Techsew 2750, Kobe LS-1341
Used: Juki LS-341, Juki LS-1341 or clones
kgg
3 hours ago, DieselTech said:What is the cobra class 26 machine based off of?
The Cobra 26 I think is sort of a clone of the Juki LS-1341 but with a Alder hook/ bobbin assembly. The 335 based machines are less capable then either the Cobra 26 or the Consew 227R.
kgg
Bought another laser engraver.
in 3D Printers and Lasers
Posted · Report reply
@dikman nicely done. Necessity is the mother of invention.
kgg
