NWBicketLeatherCollc
Everything posted by NWBicketLeatherCollc
Weighted Split Reins
NWBicketLeatherCollc replied to NWBicketLeatherCollc's topic in How Do I Do That?
Thanks Bruce- Question for you. Did you stitch them together? I'd be slightly concerned they would come apart over time. If so did you stitch then dip or did you dip then stitch? Maybe after a day they won't be so oily to run through my machine and stitch?!?- 13 replies
Cobra Machines & Tiger Thread
NWBicketLeatherCollc replied to NWBicketLeatherCollc's topic in Leatherwork Conversation
Thanks for confirming- I was leaning towards "when in doubt- don't." -
I'm coming along- wouldn't consider myself a newbie but far from a master. I've been punching size 207 and 277 pretty consistently through my Cobra C4 machine with good luck thus far. I am getting ready to put in an order with Weaver and want to make sure I get everything I need in order to take advantage of their best buy pricing and free shipping... it pays to put in those big quarterly orders. I have been purchasing Nylon thread by the pound from Weaver My question is... has anyone had luck with Tiger thread through 22/24/26 size needles? I don't currently use Tiger thread but have heard that it is really high quality. Can anyone attest to this? My concern is the "Lightly waxed" bit... will this gum up my rollers/ thread guides/ needle bar? What do I need to know- if anything- about this whole "Braided Polyester" business? Does is sew differently than Nylon? Would the size 207 nylon be size .5mm tiger? 277? Primarily, I am interested in the large availability of colors. I guess I should add- I make mainly tack so heavy/ thick stuff generally doulbled up HO Harness or Latigo but I have been making a lot of belts/ chaps etc and have been looking to invest in another machine more capable of handling the thinner/ softer oil tan/ chap sides. Any suggestions? I am weighing pros and cons of the Cobra C26 and Cobra C20. Thanks in advance.
Where in the heck can I find a "Round Rein Attachment?" That sounds like a tool that needs to be on the hot list in my shop!!! Will it fit the Cobra Class 4?
I am curious as to what everyone is using for edgers... make and model, size? I am looking to upgrade and there are so many sizes and different manufacturers. Would anyone mind going through what you're keeping in your shop as far as sizes and tool maker? Is a strop board worth the investment? Thank you in advance.
- 9 replies
- common edger
- bissonette edger
- (and 5 more)
https://dgsaddlery.com/tag/sewing-machine/ This is a pretty nice little intro into rational behind the different types of machines and their uses... at least a good place to start. I also recommend calling the guys at leather machine co. or Weaver... they are all super knowledgeable and will be able to answer even the most specific of questions and help you tailor your decision to what you are making. I would definitely go with a nicer machine that isn't used... there's nothing harder than working on a machine that other folks have had their hands on. Last thing I would recommend is go with Cobra or Adler.
Ear loop for headstall/ bridle
Awesome! Thank you- what is the width from outside to outside?! -
Ain't that the truth- in this modern world of passwords, I can hardly ever remember username/ passwords for each site. No rush, I really appreciate your help! -Nick -
Any luck on figuring this style?! -
Anyone else having difficulties opening the link? It takes me to a "Sorry we could not load this page."
Harness for Draft Team
Welp- I guess that particular book is no longer in print. Wouldn't it be my luck. If you happen to come across a copy anywhere, give me the heads up!!! Happy New Year- 6 replies
- tack
- draft horse
(and 2 more)
Now that’s the way I like to do it- direct and to the point. Thanks pats.- 6 replies
- tack
- draft horse
(and 2 more)
Does anyone have patterns/ schematics for draft harnesses/ bridles/ and lead lines?!
- 6 replies
- tack
- draft horse
(and 2 more)
I am currently using old sink cut outs... I scored both free from guys redoing their kitchens but you have to ask for the drop in advance because I think it's a big annoyance going through the buyer/ supplier/ installer grapvine... that being said, the sizes work well. Both of my slabs are probably 1.5"- 2" thick and nice and wide with 1 bull nosed side which is super nice when moving them around. That being said, I freaking love the quartz- its quite, solid and just feels a little more like a "dead blow" when tooling on it. That being said, it is white which is a real doozy after staring at it all day under bright light. I'd like to find a 4"-6" or maybe even thicker slab about 1.5' x 4' in size and darker to permanently set into a laminated bench- I'll probably cut up an old stall mat and put that between the wood and the stone just to further deaden the noise... I am still on the hunt though!!! I'd be interested to see if anyone else has tried quartz before. The Russian fellows that gave it to me said it takes impact way better than granite or marble and after tooling a lot on it, I would certainly agree!
The end that hangs down- 13 replies
Thanks for the response! I agree with the grading rule of thumb- I guess it's nice to hear other folks confirm! I'll get some pictures up once I get this batch made and go from there! Cheers!- 13 replies
BigSiouxSaddley- Awesome intel- thank you very much. I am curious- are you talking about HO's "Old World Harness- Russet "English"?" Is it possible to get away with lower grades? Or do you recommend Grade A and to use the rest of the side to maximize inventory? I'm thinking maybe breast collars or working headstalls/ bridles? HO's website has an "English" option with an adder of $13- I assume this is the one I am looking for? The issue is I wouldn't say I am in the market for a 5 side minimum though... Do you have any recommendations for a supplier that deals by the side?! You're using pure neats foot I am assuming? Would you mind maybe going into a little detail on your oiling/ conditioning process? Again, thank you very much.- 13 replies
That would be awesome! Thank you! -
Does anyone have any good tips- with legitimate reasoning why you use one or the other for the type of leather you use to make 8' split reins with water loops? I have used both- latigo seems to be easier to get heavier sides (thicker reins) and I am always impressed by the durability, but I like the way bridle/ harness finishes and is much more pliable. I have thought about doubling up lighter weight latigo and stitching but together but I also feel this is a somewhat unnecessary step especially when there isn't much of a return for spending a lot of time on reins. If I were to double and stitch say something in the ball park of 7/8 oz. H.O. latigo- should I apply barges in between? Or add anything in the ends for weight? Do you hot dip? What temp do you like to put your oil at? Thanks in advance
- 13 replies
looking to make a few single ear loop headstalls- nothing fancy but sturdy and clean for everyday ranch use. I have been thinking of using H.O. 7/8 oz. Bridle leather doubled up and stitched for strength then buttered and hot oiled for feel and durability. I am getting stuck on the ear loop. It seems your general store-bought options are "ok" and functional but I saw a couple in Vegas last year that were rolled, almost hiding the stitching. I really liked this because it was really really well-made. The extra steps to round off and roll the loop made it less stiff but almost seemed stronger- if that makes sense? In addition, I really like how it would lay on the horses head as opposed to the general flat,strap-like generic ear loops. Now my issue is I should have just bought it so I could dissect it and see how it was done. Has anyone seen a loop like this? Do you have any processes for making them? What kind of leather do you prefer for headstalls/ bridles and how do you oil yours for that supple yet durable feel? Thank you all in advance.
Flower Center Tips
Looking back, the first image I posted probably is just a stamp- here is another image, I believe off of a Don King fender... I don't think this one is a stamp but more a cluster of individual seeder imprints done with extreme patience and craft... what do you think? I have been messing around with this sort of technique and found that doing it with a heavier (say 48 oz) maul and starting from the center and working outward has seemed to make a similar impression. Also, not swivel cutting the flower center border makes for a more natural look......IMO?! I don't think this is a stamp simply because of the shape and how perfect the fit is- I think it has to be single hits?! Give this a look and see if you have a better way of doing it! I just think it looks super professional and very clean. Thanks for the responses! DK Flow Cent.docx- 6 replies
- tooling
- flower center
(and 4 more)
Flower Center Tips
I gotcha- I have a few Tandy tools but haven't been extremely impressed by the quality of the impression the leave. I attached an image of a little more of what I am going for! Thanks again! Flo Cen.pdf- 6 replies
- tooling
- flower center
(and 4 more)
High Quality Buckle/ Concho Supplier
NWBicketLeatherCollc replied to NWBicketLeatherCollc's topic in Old/Sold
Thank you all- I have also reached out to a couple of silver guys/ engravers. High price but also high quality. -
Does anyone have any tips for getting really tight/ uniform flower centers using a very small seeder? I've had OK luck with it but I see some other craftsman absolutely killing it on this. Is this an actual one hit style of stamp or is it a series of multiple hits on a "one seed" style seeder. How do you get the layout so uniform especially in such a small space as a flower center? Start in the center and work your way out or vice versa? Any tips or tricks are much appreciated.
- 6 replies
- tooling
- flower center
(and 4 more)
Does anyone have any good- moderately priced but high quality Concho & Buckle suppliers? Looking for 1/2"; 3/4"; & 1" size buckles and larger conchos: say 2" and larger? I specifically do not want them to look like the cheap Tandy stuff. Thanks
