AdamZ
Everything posted by AdamZ
...oh, and by the way I also considered (and still thinking about) making a short piece just underneath that covers the top of the handle, kind of like an axe guard/collar. It is probably pointless of course.
Glad the idea has inspired others to cover their ugly mallets! I almost didn't buy one because it was so ugly, but since I'm new to leather work and I lacked experience to know if it was worth buying a more expensive maul or rawhide mallet I just got this. I don't think I'll feel so uninspired seeing it anymore. Please post some pictures if you make them. I'd love to see what someone more skilled comes up with. There is plenty of opportunity to be a bit creative - I was going to have the stitches crossed over on the front like when I made my archery quiver hood, which I think would look good. I assume a baseball style stitch could work too. Then I guess more details on the leather than the few lines I gouged in with my dividers could look good too, especially if done with a better tool. Speaking of tools, tooling is probably another option - not something I've ever tried myself yet. And then plenty of colour options too...
Haha, thanks. I almost wish I'd used a piece of leather that wasn't damaged.
Long gun cases
AdamZ replied to DannyBoyCustomLeather's topic in Gun Holsters, Rifle Slings and Knife Sheathes
nice! -
I made this tonight with a rough bit of scrap leather because I really don't like the way these poly mallets look. As a bonus, while not a lot, the extra weight it adds is actually noticeable. I tried a few new things. Firstly I mixed the Fiebing's Show Brown Pro Dye, which I appled with one sponge, and some methylated spirits (rubbing alcohol?) with another sponge and worked at getting a different, perhaps aged look. Then I finished it by buffing in some bees wax. I'm not sure if doing a bees wax finish like this is normal, or if it is even a good or bad idea, but I figured an unimportant and small project like this is the best place to try new things. Anyway, here is the thing from start to finish... Prior to dyeing: After dying: I wasn't really happy, so decided after more work on the edges I would go back and add some more dye Here it is with the mallet before the second round of dye: Half way through stitching, you can see here the dye is much darker - I had also finished the edges as well as buffing the whole thing with bees wax:
Thanks Dwight, all very helpful! I'll definitely invest in some more and better tools as time goes by. It's a bit difficult right now with the virus lockdowns. I just gave the edges a sand with some fine grit paper (finished with 1200). since the sanding went through the dye layer in places and discoloured the stitching a bit (which I was already not thrilled with), I'm considering restitching after I re-dye. I wasn't happy with the dye around the holes anyway, so despite it being a bit of a pain I figure it will give me more stitching practice and I can be satisfied it is as good as it can look despite the problems I had along the way.
Lastly, and I hope it's ok to post a link, but this was the inspiration behind my design: https://www.bearsden.com/product14357.html
This is where I'm up to now. I need to sand and burnish the edges, and apply some sort of final finish. The fit is very tight and there's quite a bit of leather between the points of the pliers and the stitching in the bottom - I doubt they will ever make contact, especially as they are bent nose pliers. The fit is very tight, but will no doubt loosen a little with use. As the pliers are cheap, about $10 Australian, so even less than that in US$, and the sheath was made from scrap veg tan, I think it will be ok though I'd definitely like to improve on my next one. On a belt the worst of the back side of the stitching is covered... Thank you for your reply too Outfitr!
You can see there wasn't a massive amount of overlap, however I think I may have trimmed it a bit prior to glueing
When you mention the braces under the edges, do you mean the thing you made about 2/3 the plier thickness? Is this 3/8 wide piece different than the 2/3rd thick piece you mentioned above? If not, I'm a little unsure about things. Also, is this 3/8 wide piece essentially a welt that goes around the pliers to make more space and so the points don't rub the bottom of the sheath with wear? Anyway, this was a fantastically detailed response and very much appreciated. If I can fully understand it I may give it a go next time. I don't have any access to a belt sander, so unfortunately for now will have to hand sand. I've got some pictures now I've finished stitching - a big challenge for me was when punching holes because the back panel had the belt loop stitched I could not lay it flat to punch the holes near the top. I also had to re-dye after punching holes as the raw veg tan was visible - I didn't do a very good job and now the stitching doesn't look great. The holes near the top are much less straight on the back than those on the lower section because of my inability to lay it flat when punching those holes too. Keep in mind I am working on my dining room table and only have a few basic leather working tools and not an ideal working environment. Stitching was done on my couch with the sheath either in my hands or between my knees as I don't have a stitching pony. As can be seen, I had cut the back to size from the beginning and the front is slightly oversized and was trimmed to match the back once glued.
Thanks for the detailed reply. thanks. I might blunt down a point on my dividers before making the next one.
Thanks for the replies so far. Either way, if both pieces are larger, how do you then ensure you are centring and cutting everything evenly? do you just cut around the mould by eye? If so, I don't think that would be any more precise than how I did mine (back panel cut out to the finished size and the wet moulded piece a bit bigger and then glued onto the back once the moulding was finished and then trimmed to the same size as the back. I think a big issue was how hard/thick the leather was when I cut out the shape made it difficult to get really precise cuts around the tight bits on the centre. One side is a tiny bit higher than the other and one is more rounded than the other. Perhaps its just a tool and technique thing with the cuts. Lining up the back and front panels , perhaps theres some simple solution for that. Without getting both halves right when cutting the shape though, there is no chance of perfect symmetry anyway I guess.
I'm in the middle of making a wet moulded sheath for my fishing pliers and had some issues getting both sides of the cutout perfectly symmetrical, particularly on the sides in the middle where there is a little bump (see photos). Perhaps it was the type of knife I used, just the basic Stanley knife/box cutter type thing. Also, I found it difficult lining up the centre of the moulded front piece with the centre of the back piece and it looks like it is slightly off. Lastly, the belt loop is not quite centred. It looked right until I got the stitching in and now it looks off. How does everyone ensure things are lined up perfectly on pieces that should be symmetric? Obvioulsly there are various parts to this, from cutting to the process used for ensuring everything is lined up. Hopefully this makes sense, anyway, here is the pictures of the making up to this stage. I just need to get the main stitching in and finish the edges a bit better. Given this is for a cheap pair of pliers and for my own personal use I'm going to finish it and use it, but I'd like to get some nicer pliers later, and when I do it would be nice to get it right when I make a sheath for those.
Finished lever gun butt stock cover
AdamZ replied to Stetson912's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Looks great! -
Filigree knife sheath
AdamZ replied to Rolandranch's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Beautiful - the sheath not only looks great on it's own but really compliments that knife nicely. Would be nice if the red in the pin on the knife was a similar blue to that on the sheath though perhaps. -
Sheridan Tooled Belt
AdamZ replied to MLGilbert's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very nice! I might get around to trying some tooling work one day. I hope when I do it's half as nice as this. -
Gamber leather crafting
AdamZ replied to GamberLeathercrafter's topic in Boxes, Clocks and Game Boards
nicely done! -
First project, and perhaps something different
AdamZ replied to AdamZ's topic in Archery Quivers and Bow Cases
Thanks. With everything going on I can't go out to get what I need so it might be a while unfortunately. -
Thanks. The foam was just the densest foam I could get at a local place that sells foam and rubber products. I just cut it to fit as tightly as I could. The material in a pool noodle would have been better though I think, however they were not suitable because the ones I could get were all hollow and I needed solid foam. -
Some black alcohol dye and it was done. I wanted black thread but the only black thread they had in stock was more than I wanted to spend as I didn't know if this was going to work - that's why I dyed it after stitching. -
One stitch on the top pulled through the leather, it has not effected the functionality and is barely noticeable, especially since dyeing it. The rest of the stitching went surprisingly well. commercially made leather quiver hoods use a similar stitch but with a thicker thread or lace and less, but bigger holes. -
. Leather cut and holes punched ready for stitching. I had burnished the curved edges as best as I could with water and the handle of a wooden spoon
