optimusprimestamp
Everything posted by optimusprimestamp
  1. It's great that you're working to restore the old WM Johnson rotary hole punch! Dealing with rusted and stuck parts can be challenging, but there are a few additional steps you can take to try and loosen the tubes. First, consider using a penetrating oil like PB Blaster or WD-40 and allowing it to penetrate for a longer period, even up to a week, occasionally tapping the tubes lightly to help the oil work its way in. You could also try a mixture of vinegar and baking soda as a natural rust-removing solution – apply it to the rusted areas, let it sit for a while, and then gently attempt to twist the tubes out. If these methods don't work, you might want to visit the official website of the National Park Service's Conserve O Grams (https://www.nps.gov/museum/publications/conserveogram/cons_toc.html), a resource that provides practical instructions for conserving various types of artifacts. While not directly related to your rotary hole punch, these guidelines offer valuable insights into dealing with rusted and stuck objects and could help you find the right approach. Remember to be patient and use gentle methods to avoid damaging the antique tool during the restoration process. This website is helpful in checking someone's credential if in case you decided to hire someone who can do this task for you: https://backgroundcheckrepair.org/background-check-connecticut/
  2. It's great that you found a new product for rebuilding your fishing rod. The paste-like epoxy you discovered sounds like a convenient option, especially if you prefer working with that consistency. Dealing with gelled epoxy tubes can be frustrating, so finding a reliable alternative is always beneficial. JBWeld and Devcon are well-known brands, but exploring other options can be a good way to discover new and cost-effective solutions. It's always exciting to come across products that suit your preferences and offer good value. Enjoy rebuilding your fishing rod with the new epoxy paste!
  3. The weight of vegtan leather you should use for a sling seat depends on various factors, including the desired durability, comfort, and aesthetic appeal. For sling seats, it is generally recommended to use a medium to heavyweight leather that can withstand the weight and stress of sitting while providing sufficient support. A weight range of 3 to 5 ounces (1.2 to 2.0 mm) could be suitable for a sling seat, as it strikes a balance between strength and flexibility. Thicker leather may offer more durability and rigidity, while thinner leather provides greater flexibility and a lighter feel. Consider the specific requirements of your sling seat, such as the intended usage, user weight, and desired comfort level, to determine the most appropriate weight of vegtan leather for your project. Additionally, consulting with leather suppliers or experienced craftsmen can provide valuable insights and recommendations based on their expertise.
  4. Here's a step-by-step process to create a punched pattern for stitching on your Pampeano belt: Determine the Pattern: Decide on the pattern you want to create with your stitching. Common patterns for Pampeano belts include geometric designs or traditional motifs. You can find inspiration from existing Pampeano designs or create your own unique pattern. Measure and Mark: Use a ruler or measuring tape to measure and mark the desired spacing and alignment of your stitching holes. Ensure that the marks are evenly spaced and aligned along the length of the belt. Punch the Holes: With the leather punch, align the desired hole size with each marked point and punch through the leather. Apply steady pressure to create clean and even holes. Repeat this process for all the marked points along the belt. Check and Adjust: Once you have punched all the holes, check the spacing and alignment to ensure consistency. If needed, make any adjustments by adding or repositioning holes. Stitching: After punching the holes, you can proceed with stitching your Pampeano belt. Use a waxed thread or strong nylon thread and a leather needle to sew through the punched holes, following your desired stitching pattern. There are various stitching techniques you can use, such as saddle stitching or whip stitching, depending on the look you want to achieve.
  5. As long as the picture shows that they're in pretty good condition to be used for your project, I think you should go and purchase it.
  6. How can I avoid discoloration or damage to the leather during the staining process?
  7. I'm currently listening to "Head Above Water" by Avril Lavigne.
