yuma
Everything posted by yuma
  1. yuma
    Sheaths
    Finished the last of this lot... Roger
  2. yuma
    Sheaths
    Just finished this lot, not completely happy with them but improving... Roger
  3. Nice work....your knives ? Roger
  4. yuma
    Last ones..
    No, I always put in a 2 or 3 mm thick, 10 to 12 mm wide welt on the outside edge. It protects the stitching from the blade and the blade from the rivets. A bit hard to see in the pics..... Roger
  5. yuma
    Last ones..
    Finished the last two sheaths for this bloke...top one is a small of the back sheath for a camp knife, the other is a second sheath for his " Lion Killer " knife. Here are all four ready to go... Roger
  6. yuma
    Finished...
    Working on it Chuck, working on it ...
  7. yuma
    Finished...
    Finally getting some gear finished... Roger
  8. yuma
    Sheath
    Just finished a couple knife sheaths for a bloke...
  9. Cheers, all my leather is veg tanned. Roger
  10. Thanks, I'm making some sheaths for a bloke who makes these fancy handmade knives and I was a bit concerned about the possible effect on the blades. Roger
  11. What do you use inside a knife sheath, other than a lining, to protect the knife blade from leather...rust wise, etc?....wax, dubbin ? Roger
  12. yuma
    Bowie sheath
    MW, yes, once I removed the brass base from the plastic case I knocked the primer out, ground away some of the brass to make it thinner and used a 6mm eyelet to attach to the leather and then pushed a used large rifle primer back into the hole. Roger
  13. yuma
    Bowie sheath
    Western style skirt sheath for a bowie, can be worn left or right hand... Roger
  14. yuma
    Ammo pouch
    A bit over 4" square and an inch deep not including belt loops... Roger
  15. yuma
    Ammo pouch
    Just finished an ammo pouch for a blokes 458 Lott... Roger
  16. yuma
    Ammo pouch
    I accept the praise and I welcome criticism...constructive criticism Roger
  17. yuma
    Ammo pouch
    Made an ammo pouch for a mate of mine, for either 22's or air rifle slugs. First of this type of pouch I have made so there was a few mistakes....should have used a magnetic catch instead of the Sam Brown stud, wet molded the ends which was good but found that my fingernails scratched the soft leather when I was sewing..a few other things I would do differently but thats for the next one... Roger
  18. I have a question that's a bit like hotdogs and buns...why is it that stitching punches are spaced in a metric size and stitching wheels are measured in spaces per inch ?? I cannot find a stitching wheel that matches any stitching punch.....or is it just me ?? Roger
  19. yuma
    Key clips ?
    From an Australian mob....Makers Leather Supply... Roger
  20. yuma
    Key clips ?
    Cheers, looks like I've found some ! In steel. Roger
  21. yuma
    Key clips ?
    Thanks anyway...item no longer available.... Roger
  22. yuma
    Key clips ?
    Does anyone know what these are called and where I can get some ?? Can't find anywhere in Oz that sells them !! Roger
  23. yuma
    Elastic
    That striped elastic that is used to under a horse to hold the saddle on.....girth strap.... Roger
  24. ...you'd be surprised how handy it is !! Roger
  25. yuma
    Elastic
    Thanks to all for your help. Frodo, I would agree with you but the customer specified elastic....I'm using girth elastic so it should last fairly well, and at the very least I'll learn something new. Roger
