nejcek74
Everything posted by nejcek74
I use the second pedal for reverse, but I really don't see a reason why wouldn't you use it for a foot lift. Just connect the pedal and the lifting rod either with a chain or a wire.
What would your ultimate needle positioner/synchroniser do.
nejcek74 replied to beefy's topic in Leather Sewing Machines
Great project, Beefy! I really like elevated DIY projects, and I hope you succeed. I find the needle positioner extremely useful. What are your plans for the controller — will you use an Arduino or something else that can be programmed? In my opinion, you describe the basic functions well. What I would find useful is: - the ability to check and auto-apply signals from different types of needle positioner, as you already described. - the ability to easily define the up and down positions by turning the wheel by hand and pressing a button. Currently, on my controller, I can do this either by typing numbers into the controller or by moving the three metal discs inside the positioner mechanically. I always spend too much time fiddling with that. A more advanced function would be to perform automatic backtacking ((three forwards, three backwards, three forwards, or something programmable) as you are describing, that would be great.!!!!! -
How to ease when sewing leather on a 1341?
nejcek74 replied to joetroba's topic in Leather Sewing Machines
most of my machines have additional small pedal for reverse as I have simple setups with cheap servos or old clutch motors without control. Reverse is anyway the sewing machine function and it is just chain/rod connecting to the reverse lever. That's number 4 on the image. -
my solution for low speeds is a needle positioner, going from up to down and back up with as much time in between as you want. No problems with low speed/power ration and the needle always finish the cycle (locks). For a cheap servo is usually also a cheap needle positioner, sometimes they come included. All you need is half an hour to instal it, even if you get the instructions they are often just for something else :)))))
Union Special machine setup installation and modifications
nejcek74 replied to DMH's topic in Leather Sewing Machines
yes, that's right, both machines were only fixed/sitting on those rubber feet. -
I have few old US machines, like 52900 and 53100. They are not in use at the time, as of lack of space :)))) Here is a pictures of the original table. At least for those two machines the tables are the same. They are very finely engineered, with pre-made holes for rubber fits, hinged access for the machine etc, lower board that can be fine tuned into the position etc. For sure made with a rig in a factory. For a single use I would do it much simpler. Ok, I would have to do it much simpler, as I don't have necessary machines :)))) -
I think the machine was produced till late fifties. Similar knob was also used in 238 but not in later 438. Such parts are not available any more, if you are lucky you can find sometimes something on ebay. Otherwise, just glue it together. I did this with the one I stupidly broke when cleaning the machine.
On my machine (Pfaff) you set the needle into the centre of needle hole in the feed dog by moving the needle bar frame. This is the upper assembly that includes needle bar and upper feed mechanism. By my machines is always annoying to get some movements. How is this solved by Juki I rerally don't know. check on which axe the needle bar is hanging, is there and screw that you can loose, and than by rocking the wheel you push the whole assembly slightly to the left.
In my opinion 1000$ for a machine that is so old is way too much. I own old pfaffs and Adlers, but I am using them as hobbiest and with a lot of love for old iron. It's great machine with some limitations (small bobbin), but with limited documentation and limited access to parts which are often very expensive. The worth of the head is max 300$, 500 if you really want this machine. Tables and old motors are practically not worth much.
Pfaff 545-H3 missing parts!!! Help please 🙏
nejcek74 replied to darkhornsleather's topic in Leather Sewing Machines
Google for parts diagram of the pfaff 545. Find the other post here for pfaff 545 and also 1245. Others, including me we already wrote and linked a lot of info how to time it. Feet will be the same as for 1245. Same is for hook and bobbin case, but you need to choose the right one according to your subclass (H3). 0) check this forum, 99% is already here 1) get parts diagram and find missing parts 2) compare it to 1245 to find some equivalents. 3) go to ebay/amazon /Aliexpress and get what you can 4) if something is still missing you will have to do more research 5) use pfaff 1245 engineering manual for timing it 6) ask here for what is missing -
Your timing is a little bit off (hook should be at the needle scarf when already on the way up, distance is defined in the manual) and probably the needle is too far from the hook (it should almost touch the needle, but not exactly, ca 0.1mm). I suggest you to find the engineering manual and follow it to time your machine.
I bought it here, it's both needle bar clamp and gauge: https://www.diamondneedle.com/timing-gauge-set-p:11618.html
I have few pfaffs in the range of 142 to 1245 and I always adjust needle bar height regarding to the hook. - get the needle bar into the lowest position - advance so the needle bar rises to the necessary height regarding the model (between 1.6 - 2.5 mm)* * first I was doing this with making a black mark on the needle bar, later I bough the clamps for that - in this position the top of the needle hole must be 1 mm bellow the hook point see pages 9-10 here in the attached manual. Whenever I had serious problems I followed the manual from the beginning to the end and it always helped. p.s. manuals sold on the internet are usual exactly the same as the free one. Pfaff 1245 Adjustment 89_09.pdf
Anyone Heard of a "Bind-All" binding machine?
nejcek74 replied to hemiyota's topic in Leather Sewing Machines
To me there are a lot of visual similarities with Pfaff 461 (or 463, 467, or 483 etc) or something from that era and source. But they were all fast straight stitch sewing machines for light to medium fabric. -
DIY servo motor with wide speed range
nejcek74 replied to Gymnast's topic in Leather Sewing Machines
At extremely low speeds the power of the motor is extremely low, so there is no point to engineer a motor that would be extremely powerful to overcome that. It's better to use a different gear ratio. In the production operators are skilled, and speeds are high. With a combination of needle positioner and other automatic controls low speeds are even less needed. Outside of repairing stuff and hobby users there is not much need for such motors, we should be lucky for that what we have :)))) -
My moderately priced servo has 100 rpm minimum speed has some shaping on the case, but not exactly cooling fans. Efka DC 1600 that I had to remove because of dead control box is completely different beast, 2 the size and weight, cooling fan etc.
I guess the problem is with the minimum speed to start. Which is I guess an engineering characteristic of the motor, but this is beyond my limited knowledge of electric motors Regarding torque of different types of motor I found this:
of course they have, this is from Efka site: which shows that torque is more or less flat in the lower part of the rpm. It also shows that they have two different servos, one built for speed and the other built for torque. The power is function of speed and torque: P [kW] = (T [Nm] · ω [rad/s]) / 1000 in lower speeds where torque curve is flat the power is increasing constantly with speed. Later it can decrease slightly (depends on the turning curve of torque). Of course when the speed is 0, power is also 0. And because of engineering reasons the motors have minimum speed at which they work.
here is the old adjustment manual Pfaff 1245 Adjustment 89_09.pdf and parts list Pfaff 1245 Parts 85_07.pdf actually I gave you up the relevant information for the old 1245. If you are unsure which subclass you have please make a photo of the shield with class / subclass and share it here. It's kind of hard guessing things with so little information from your side :))))
Just for info, certain old casting Pfaff 1245 are using needle system 190. OP will have to check his machine, which subtype is and if it was maybe adapted for something else. My Pfaff 1245/48 that I bought used came with needles of the system 134. At that time the needle bar in the lowest position was pressing down on the presser foot if it was raised. I changed it to 134-35 as I had them at the time and it is just barely long enough that the parts are not touching.
Typical gc2605 conversion to non-binding machine
nejcek74 replied to TakashiOkada's topic in Leather Sewing Machines
If he is using Pfaff parts, maybe this is a copy of Pfaff 335? Which was often sold as a binding machine. Regarding 2-way (only horizontal) vs 4-way (horizontal and vertical) feed dog movement there was already written a lot about it on this forum. Conversion is possible but it's a mayor work because you need to connect the upper shaft with the lower one that moves the feed dog. You also need parts which are often more expensive than an used machine. My Pfaff 1245 has only 2-way feed dog and it works for me perfectly fine, but I am using it mostly for heavy fabric or combination of heavy fabric and leather. I guess certain, very fine surfaces could be scratched by a feed dog dragging back. -
I learnt sewing with modern servo motor with needle positioner. I am buying them in Europe from a big reseller, Strima, they are around 300 euros. They start at 100 rpm minimumspeed I think, 750 we. Thanks to needle positioner I don't miss lower speeds. I do needle up, needle down and I can go step by step when I want. And the needle is always in the right position (locked stitch or open tensioner etc) so working is easy and precise. I don't need and don't want a speed reducer under the table. A jog dial would be useful to limit upper speed which I need to do on the controller. I also miss more robust needle positioner with better and easier fixing to different types of machines. For me a middle priced servos with good documentation and support would be interesting. Efkas prices are too steep, the cheapest Chinese imports are undocumented and have often strange quirks that are difficult to solve
Yes, it looks like there is no positioner. One of my similar low cost servos didn't operate without positioner, even when the function was switched off in the menu :))) I checked his video again and actually it looks that the white pin operates as intended. Or so I guess.
