CalgaryJim
Everything posted by CalgaryJim
Thanks. I figured since individual hole punches are supposed to have the leather backed by a pounding board or HDPE that the same would apply to the rotary tool. I'll try without the leather backing though. I noticed today what KS Blade sells punching tools that have no taper. Kind of expensive for me to take a chance on them. Another problem might be, I found out after my post, is twisting the strap on the punch. I've read that can cause tearing. I thought it would help the hole cutting. So, two things to try now.
I'm having trouble getting a clean cut on the lining side of my straps. I use 1.0mm Zermatt calf waterproof leather, making the hole with a rotary hole punch tool. I use a 1mm piece of veg tan leather underneath the strap so I don't damage the punch tip. Maybe the punch is wearing down. I've tried using single punch tools but even my 1mm makes holes that are much larger than that due to the tapering of the tips. Anyone able to suggest why my holes don't come out more clean on the Zermatt lining? Very nice work!
Interesting, thank you. What is the things I love about leatherwork is the amazing variety of tools and processes, not just leathers. And the helpfulness of this community.
- 9 replies
- tandy
- since tools
(and 1 more)
I have a number of their Pro tools, purchased within the last two years. The Since pricking irons are good quality in my opinion. The creaser is too, except it's not good as an edge creaser (even though Since on their own website describe it as such) because both lips are the same length, no overhang on the edge side like you'd expect.
- 9 replies
- tandy
- since tools
(and 1 more)
Thanks! Sorry for the late response, I should go on to this site more often. The colour is gold. I use inverse pricking irons on the same side of the strap, the top layer, but opposite from the regular pricking irons. That way the slants and therefore stitching can run the opposite direction instead of one side slanting out and the other side slanting in. It just looks better in my opinion rather than this: ////////// ///////// It will look like this: ////// \\\\\\ Or I can use regular and inverse to achieve a slanted in look: \\\\\\\ /////// Now, having said this, I made a mistake on my straps because I have the long strap stitch lines slanted in on both sides, but on the short strap I have them slanted outward.
I hadn’t used this leather before so I ordered some from Rocky Mountain Leather Supply. It’s harder to skive than I’m used to with veg tanned leather. I also for the first time used inverse pricking irons as well as regular ones, also from RMLS. Those leave holes that are more oblong than the rectangular holes I get with my Tandy Pro pricking irons. I prefer the latter shape but Tandy doesn’t sell inverse ones. Happy with the results though except that I just noticed the stitching on the shirt strap is angled outward, on the long strap it’s angled inwards, lol. 2.7mm pricking irons, 1mm Degermann Baranil Leather, Velodon reinforcement fabric, 1mm Haas’s Zermatt leather for the liner, Tandy Eco Flex Edge Coat edge paint, 0.45mm RMLS waxed linen thread, Barge All Purpose cement. Unfortunately I only have this photo of the straps ready to be given to a watchmaker friend as a thank you gift.
You are mistaken, quick release springs bars are not universal sized, and even Seiko watches don’t all use the same spring bar size. Same with Marathon, for example, my 34mm General Purpose Quartz Marathon has a fixed bar. Quick release spring bars are easy to remove by the way, no need to break the handle off. No strap makers will give you such a guarantee.
Good to know about the dog collars, thanks. The Cordovan calf is more expensive than other leathers I’ve bought but not nearly as expensive as shell cordovan. I have straps made from Shinki Shell Cordovan, I quite like their finish. The Cordovan calf so far looks very similar. I don’t use much leather to make watch straps so the price is fine for me…even with my two failures using it so far. Hopefully my current attempt, gluing the Velodon with two layers of Barge cement, holds. And I’m skipping the padding too.
In order to have the strap conform properly to then stitch, from every video I’ve seen, you need to press the leather down with a bone first. But maybe clamping the sides would work also. I just realized what you are see is Salpa, it’s on top of the Microfibra, I added it because the latter didn’t provide enough thickness. I could try Salpa only though, or use natural veg tan leather which I tried once before with some success. I also bought some Saba but it’s very soft, I don’t think it would have the body I would like. The leathers I use are 1.0mm thick, not sure what that translates to in ounces. The Cordovan calf leather is quite strong, that’s likely why I couldn’t get it to form, maybe I should try making the straps much wider, then form and stitch, then trim to shape. Or just make padded straps with softer veg tan leathers. I don’t want to have it thinner than 1.0mm though for concern about strength.
I am having a heck of a time trying to make padded watch straps. I’ve used natural veg tan as padding, and just now I received some Luigi Carnevali - Microfibra Reinforcement from RMLS, I made it narrower than the straps but can’t get the leather to conform (flatten) enough at the sides in order to stitch the top layer and lining together. I’m using a stainless steel bone too. Maybe I need to use a thinner leather on top, or softer leather than the Minerva or Cordovan calf that I’ve tried. Any and all tips are welcomed.
Thank you so much! This wick has no weave at all. Now where to source one. Google is bringing up lots for oil lamps, fibreglass weaved, cotton weaved too. Is one material better than the other?
When I use my alcohol lamp, it gives off smoke which blackens the creaser. The wick that came with it from WUTA is some synthetic fabric. What am I doing wrong?
printing cow camp saddlery patterns
CalgaryJim replied to maggielj's topic in Patterns and Templates
“..saddery@ gmail”, or “saddlery”? -
I hadn’t been able to find anyone selling acrylic templates in a 20/16mm taper so contacted Buzzard Brain Leather on Etsy and the owner Will was kind enough to design a one off for me in that taper and length of 105 and 65mm. Same cost as his ready made sizes too. They arrived within a week from Louisiana to Alberta and they are very well made, unlike some Ali Express ones I received in the past (20/18 and 18/16 regular length.There is enough overhang for the spring bar and buckle flaps that I’ll be able to cut 110 and 70mm lengths as well.
Brown watch strap with orange stitching and lining
CalgaryJim replied to Danne's topic in Show Off!!
Thank you, -
I found someone who was willing to make me an acrylic template set for 20/16 taper, 105mm and 65mm long, Buzzard Brain Leather on Etsy. He had to make them from scratch as he didn’t have a set of drawings he could use. I’m happy to report they turned out quite well and he only charged me the same price as his regular templates.
Thanks for the info. I’ve been using Zermatt leather for lining but I’ll have to order some Alran sully next. Did you colour it yourself? -
Here's one of the negative reviews, with a lot of details: "Abraham B 2.0 out of 5 stars Ruined fabric, failed to hold plastic to plastic, drying slowly--disappointed shopper Reviewed in the United States on July 12, 2018 Number of Items: 1Verified Purchase We bought this to try out in our community theater--sticking fabric to plastic and plastic to plastic. Before I ordered, I called Aleene's using the CS number their rep shared in several of the questions posted here. The young woman who answered the phone was surprisingly curt. Maybe their CS center, which answers the line under another company and then tells you they handle Aleene's, too, is a large generic center. Anyway, I told the rep what I was looking for a glue for and she seemed disinterested in what I was saying. Desperate for a glue that would work, I still ordered the product. It arrived today & we rushed over to the center to try it out. First, when wet it's a white Elmer-like glue. I thought it dried quickly. I was wrong. We left the glue to "dry" for over 3 hours, but it remained white and liquid. We tried using it as it is on pieces we want to stay together indefinitely. It "bled" though our fabrics, staining them but not holding pieces together. And it made our plastics sticky without holding plastic to plastic. As I write this, nearly 11:30PM, I'm still waiting for the glue to dry (turn clear...). All in all, I'll continue looking for a better product. We don't have time to wait half a day or longer for this glue to solidify/dry. And it turned out to be as messy as the old-fashioned Elmer's glue we stopped using millennia ago. When I was in school and we put on a show, we used "liquid cement" that was thick but clear and gelled very quickly (under half an hour) into a stable matrix. I wish I could find that product here on Amazon. I guess we'll keep the Aleene's for paper-on-paper glue needs, but other than that, we're very disappointed in this product. We had such high hopes. UPDATE NEXT MORNING The glue STILL hasn't set. It's still white and liquid. It's puddled along the base of the set pieces we used it on, creating a sticky, ugly mess. We tried vegetable oil then 85% alcohol to get the mess off. Then we tried extra-strength detergent. We finally got rid of most of the white liquid mess, but now our set pieces are ruined--fabric and plastic. And our hands are, of course, sticky and messy. This product didn't work for us at all. The only things it stuck to was our hands and the outside of surfaces it slobbered down. 6 people found this helpful."
Beautiful strap including colour combinations. What type of leather is the orange leather? -
Thank you for this level of detail! And I see the most important supply item of all, coffee
Excellent stitch work!
I'm 6 months into making my own leather watch straps. Before that, 18 months buying straps from various sources. Cheap straps (ie, under $20 US) feel cheap and will stay feeling cheap, because poor quality leather such as 'genuine leather' or even no leather at all. If you buy straps made with high quality leather, for example: Buttero, Minerva, Pueblo, these are all made by Italian tanneries; Zermatt leather by french tannery Haas, it's likely to feel comfortable right away or within a few wears. Firmer leathers will feel stiffer as mentioned above, ie, Buttero. Also, the thickness of these leathers affects their stiffness and break-in time. Many straps will have a layer(s) of reinforcement to reduce or prevent the leather from stretching over time, this could be Velodon (very thing synthetic fiber) or bonded leather such as brand names Salamander or Salpa. Bonded leather reinforcement will keep the leather feeling stiffer than Velodon because it's a lot thicker (ie, 0.4mm versus 0.05mm). I own a strap by Colareb in Italy, it's about 2mm thick, single layer, smooth on the backside. It's quite supple. I don't wear it regularly but it's definitely stretching out in a way lined straps don't. High quality supple leather lined with Zermatt and using Velodon will feel the most comfortable from the start. I use Salpa when I need the added thickness between my top leather and Zermatt lining. Otherwise it's Velodon.
