Thadrick
Everything posted by Thadrick
Thanks, I guess I'll have to give it a try.
Has anyone thought about using formica construction glue for leather projects? https://www.amazon.com/00271-Weldwood-Original-Contact-Cement/dp/B0006MXRY8/ref=pd_sim_d_sccl_3_1/147-4836112-0706438?pd_rd_w=2UpNv&content-id=amzn1.sym.3a852a98-d65f-4301-9bd0-9b589b14d1ef&pf_rd_p=3a852a98-d65f-4301-9bd0-9b589b14d1ef&pf_rd_r=WJZQ74S5S0KPDW4F7P4X&pd_rd_wg=EB4bj&pd_rd_r=362984e1-6bb4-4088-b07b-c23adb755617&pd_rd_i=B0006MXRY8&th=1 It sure is a lot less expensive than what Ive been buying now that infation is effecting my leather glue prices.
I like it! I especially like the finish.
Thats pretty cool
Thank you. Should be able to improve the looks with a little more time than an hour also? Winters coming so maybe lots of time to expand on the idea.
Me neither, I have however had luck carrying them open on a sling (two side by side lengthwise). Its also something that might be able to incorporate into a scabbard. Putting them on a butt stock causes a lot of snagging.
Not exactly the same but kinda the same idea. I have a couple other projects going on and then Ill see if I can figure out something like this for my 7 SAUM.
So I was waiting for leather to dry a little and thought I would fiddle with this. The removed material at the bottom needs to be the diameter of the cartridge (in this case .429" -44 mag) The oval punch should be close to that plus the thickness of the leather doubled (.429 + leather doubled) The stitching down the case wall needs to be measured with a couple strait edges holding the leather and bullet down to a flat surface. In my attempt, my punched hole is a little too long. The stitching holes I just eyeballed the radious going under the bullet. Knowing these measurements I think I could build a pattern. Then the stitching on the back piece I think would be like a normal piece except the radioused part under the bullet might need to be punched during assembly? On a bottle neck case, Ill probably have to work that out but I think the oval hole might need to be higher?
As I was fiddling with paper trying to work out a pattern, I think it will require an oval punch? I'm in the middle of another project right now or I would get right after doing one of these, starting with strait wall cartridge first and then working my way to a bottle neck . My theory would be that the punched hole would be where the bullet and neck could poke through for bottle neck cartridges ? Museums are awesome for ideas. Those Ole timers were brilliant.
Definitely wet formed to an extent but the bottom part of the loops are nicely designed and sewn down to the end of the cartridge. Sometimes that kinda stuff floors me with our ancestors designs. They were brilliant.
Yeah, I just tried paper and it won't form properly. It kinda looks like piano keys when laid flat though. Obviously wet formed to an extent?
Ive seen many ammo holders on here in the past but this one stumps me. I found this in a museum and couldnt help think that this design would work perfectly for bottle neck rimless ammo. My question is how the heck did they cut the outher loops like that to get things to fit ammo and yet look so clean? How can a person reproduce this to fit bottle neck ammo? Just use a bunch of leather and try till its right? Where are the measurements taken from? Anyhow? anyone know of any writeups on this design?
So was I right?
My boss likes to break needles off at the top. Took me a while to figure out the problem until I realized that the top of the broken needle was stuck inside of the needle holder not allowing the new needles to set correctly (too long). Check to be you don't have a broken needle inside the carrier.
Before you know it, youll be on you 10th attempt and still going till it becomes a fever. I think I have about 20 holsters laying around my house. I guess its obvious why Im single?
Nice job, I wouldn't even consider showing my first holster.
New pistol, new holster
Thadrick replied to Thadrick's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Thanks, I like it better. Always something to learn in leather working. -
Maybe thats what my eye is catching? Too big. Ill look at it more after I get off work. Might look better with a couple smaller conchos with the tassels. The tassels would get in the way of drawing the pistol though? Might just be stuck with rivets? Thanks for the fresh eye. -
Thanks guys, I'm curious if ya'll think the conchos should have been tucked a little closer to the bullet loops? -
Thanks guys. It went faster than I usually get them done but I had fun with it. I got the holster done before I even sighted the pistol in. -
