Just bought a cowboy outlaw.
I am begining to think me and sewing machines aren't compatible.
I have the length and tension pretty close to right but It keeps missing  stitch every 2 to 3 inches. Any ideas or help.
I am from Central WA. and am sewing 2- 3 layers of 8 ounce for knife sheaths.
Edited by Northmount
fixed title typo
Not sure how much you already know but it does get easier. Skipping stitches should be fairly easy to put right. Start with the hook. Is it meeting the scarf in the needle roughly in the middle? If not it needs timing. Is the hook as close to the needle as possible without touching it? Is there a loop of thread that the hook can go through? This would be my bet. The tension must be completely off the thread when the hook gets to it. If not there will be no loop. Reasons could be too much top tension or a badly adjusted check spring. Get that lot sorted before looking to the bobbin tension to "balance" the thread. Good luck.
Make sure you have enough presser foot pressure to hold down all of that dense leather so that it doesn’t rise with the needle on the upward stroke.  If the work even rises just a smidgen, the top thread loop that the hook needs can collapse and the hook won’t catch it.
CD in Oklahoma
"I sew, I sew, so it's off to work I go....."
My sewing machines:
Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Wow thank you guys.
If i had known there was so much to this sewing machine stuff I would have just kept on hand stitching.
I just finished a 4 inch stitch that looks pretty good. having a little difference with stitch length. But can live with that.
Thanks again for your answers
TJ Smith
The first thing I would have looked at is the needle.  That rascal cannot be "off kilter" or it and the bobbin will not make that stitch.
And the fact that you were hitting  . . . then missing . . . would sound like it was close to being installed correctly . . . but just maybe off a tad.
Check your needle if you have any more trouble.
May God bless,
Dwight
www.dwightsgunleather.com
Thanks Dwight I think the needle was the problem. I sewed 6 3-4 inches without any skipped stitches.
The needle was about 1/8 turn off the 9 0clock position.Seems like it would miss every so often.
