Zonepack Leather Splitter with Replaceable Blades - thoughts?
The price is right with these but they do have some issues in use. . I've got one coming in on a trade so Ill have one in my hands to try in a week or so.
 Pretty much the experience of a few guys who bought them was universal.
With most splitters you want the edge of the blade to be top center of the roller or a hair behind. With this design the roller-blade edge relationship changes with the thickness. It can make for some uneven splits especially the thicker you go. The 3 person consensus was "OK/surprisingly - pretty good/worth it" for splitting lace and saddle strings. For belts from skirting or heavier leather - two thumbs down, one "it was OK for a couple belts but wouldn't want to do a bunch, please send me the next Osborne #86 you have ready".
Bruce Johnson
Malachi 4:2
For me, I'm hoping to use this for thinning watch straps at the folds and thinning leather for the keepers.  I can see what you mean about the roller - edge of the blade relationship.  If I was doing high volume, I'd step up for a better splitter, or go right to a bell skiver.    Looking forward to your thoughts Bruce.
Neil
Following up - I got two of these in yesterday. Here are my thoughts. They are pretty solid and I didn't have the issue with loose pivot bolts as mentioned previously. As-is blades were as expected - not quite sharp enough like most utility blades. A bit of time on a few different buffing wheel/compound combinations and they performed much better but...(read below).
The adjustments were pretty straight forward. You set the thickness you'd like with the two independent set screws, Push the handle forward, insert the leather, and pull. Simple enough.
As I mentioned above I like my splitters so the edge of the blade is at the top dead center of the roller or just a minute touch behind it. Too far in front and the leather rolls under the blade edge. Too far behind and the leather tends to right up the blade chop off. This is true of several types of splitters. There is some forward and back leeway with the blade to position it for different thickness setting. I got pretty good hold down ability of the splitter to hold blade position even with the blade extending pretty far forward. (as an aside, I got a regular utility knife blade to work also)
Issues -
1. You can put a really fine edge on the snap off utility blade.  Out of the box I thought the snap off blades were OK for narrower work, but on a belt width they drug a bunch. Buffed up and they did one belt, then the edge curled halfway through the second. The bimetal regular utility knife blades hold an edge much longer and are more durable, but narrower. The snapoff blades were good for several 1/2 inch and 3/4 straps. as were the regular utility blades
2. Even through the springs are pretty strong I had a problem or two crop up. On thicker firm veg tan I tried to push forward, put the leather in, let go and pull.  A couple straps split unevenly because the spring allowed the roller to push away from the set position. A few the roller never pulled back under the leather and it just skidded through.  I pulled up on the handle while I pulled a few more straps from that leather and it worked. Not ideal but sort of workable.
Upside - these are inexpensive and relatively well made.
My takeaway -  These are going to eat up some blades so there is that future cost. These are actually pretty good for narrow straps (3/4 and under), latigo ties and saddle strings - no issues. A couple people have reported them to work well for leveling rawhide lace for braiding.  Belts - these would not be my first, second, or third pick even if I was doing one every so often. I've got some $150 Amazon versions that are better in my hands than these and worth the difference. Even those still aren't a good Osborne but fit a price and performance point better for meatier work.
Bruce Johnson
Malachi 4:2
Thanks
A good review.
Not that I'm likely to buy one tho. I'm happy with my hand held splitter
I have splitters and I wouldn't bother pulling them out the drawer/setting them up to do the turnbacks and keepers on a watch strap, I'd just got at it with a knife and be done in no time. Granted hand skiving is a skill and a perishable skill at that but it's a fundamental skill in leatherwork and the minimal investment in a decent knife, blade maintenance, a pile of scrap/offcut and a bit of swearing is well worth it. Lisa Sorrell is the queen of skiving and gives decent tuition for free on her Youtube channel:
Think you may be missing the point Matt, he is looking from hat he says to split the whole strap not skive the top or bottom or edges
Mi omputer is ot ood at speeling , it's not me
[my bold]
:shrug: Maybe, but that's not my interpretation of what he typed.
Damn it all ! I just bought one of these last night. £63.56 inc delivery and 10 spare blades. UK Seller. Delivery by the weekend or so. I could have got it a heck of a lot cheaper if I could wait 30 to 50 days for delivery but I have some projects on hand now that I can use it on
My hand-held splitter will do to about 45-50mm width but the other day I realised I would like to split down some leather that will be 9 - 9.5 cm wide. Enter the bigger splitter
On 4/25/2022 at 10:00 AM, Matt S said:
[my bold]
Hi Matt.
I appreciate the link and clarification.  Ideally, this splitter would be used enough it'd warrant being out all the time.  Right now, 95% of what I do is watch straps, so making keepers would be a common thing.  I also use leather that is typically 2mm or thicker,  too thick for a keeper in my opinion.
I am at first thinking this might be a quicker way to thin the leather I use for keepers.  While almost everything I do is by hand, having a way to thin the leather I use, quickly and consistently is what I'm after.  It's not like I can't do it by hand, but in theory this would be quicker and free up some time.  I might also be able to (if necessary) thin out some thicker leather as well.  I have some bison that has a very messy flesh side that I may use the splitter to remove.  Any saved time = tiem for other straps and projects, or gleaning info from this amazing forum.
Best,
Neil
Delivered this morning, a short time ago. Now to go play with it, and find a space on my cluttered work bench to bolt it to. There is no room on my lesser cluttered work benches for it
