12 hours ago, AdamDavis said:
@MtlBiker  thanks for the help! I’m using size 138 thread and whatever size needles they sent with it. I’m pretty sure you are right about the thread tension because  I’m getting “knots” on the bottom stitches.I’m not really sure what you mean about about the top and bottom threads meeting in the middle of the material assembly though. As far as what I’m sewing, just scrap pieces of veg tan. Not ready to try a real project.
There have been lots of threads here about thread tension... maybe try a search and see what you find.  I don't have a drawing handy, but the idea is that the top and bottom stitches need to meet in the middle of your material assembly... if you look at the result from the top side, you should not see the bottom thread coming up to the top (if it does, your top tension is too tight or your bottom too loose), and likewise if you look at the stitch from the bottom, you should not see  the top thread coming through.  If you do, the bottom tension is too tight or the top too loose.  And remember that different threads and different types of material usually require different thread tension adjustments.  Which is why you should always run a test piece of the SAME material and thread as you plan to use.
In the beginning it helps with understanding this if you use different thread colors on the top and bottom... that makes it real easy to identify if the tension is correct.  But bear in mind that adjusting thread tension for a white thread does NOT mean the tension will be the same with a black thread.  Black (at least to me) is the most problematic thread because even for the same weight (v138 for example) it is usually stiffer than the other colors.
And you really should know exactly what the needle is that you're using... both the size of the needle as well as the type, such as round point (general use) or diamond point (for leather).  It's important to know that.  Probably marked on your little package of needles.  What's the thickness of the leather scraps you're using and how many layers?
Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
@MtlBiker the package says 135x16. I was practicing on single layers of varying thicknesses though mostly 4-5 oz.  I found that the sewing machine store closest to me has free beginner's classes. I think thats probably my best bet.
On 5/28/2022 at 10:33 AM, AdamDavis said:
Hey guys, I went ahead and got myself a new sewing machine ( Cobra class 26) and realized I have absolutely no clue what I’m doing! I’ve been watching tutorials on the youtube but was hoping someone would be able to give me a lesson in person. I would be happy to compensate someone for there time.  If not are there any other resources that you could recommend? Thanks.
Adam
Adam, Congrats on the new Cobra Class 26! That's pretty cool!
On 5/28/2022 at 6:51 PM, MtlBiker said:
The "birds nest" is often caused by your not holding the bobbin thread tightly enough as you start your stitches.  If it gets pulled in, that's what will happen.
You need to hold the top thread back at the start or it will get pulled and wrapped around the shuttle and/or bobbin case race and jam the hook. If possible, hold both threads back equally. But, at least keep the top thread under hand tension until you sew 2 or 3 stitches. If it is inconvenient to hold the thread back, at least capture it under the outside presser foot and make sure the take-up lever is either at the top, or just moving down before you start to sew. This gives you a fighting chance.
1 hour ago, AdamDavis said:
I found that the sewing machine store closest to me has free beginner's classes. I think that's probably my best bet.
Ask that sewing machine store if they deal with industrial sewing machines. There is a world of difference between industrial and domestic (household) sewing machines. People versed in domestics may or may not Grok the intricacies of operating or even threading an industrial machine.
Posted IMHO, by Wiz
Here is a thread -Needle size chart, for your 138 thread you should be using a 135x16 needle size either 22 or 23
https://www.tolindsewmach.com/thread-chart.html
Edited by chrisash
Mi omputer is ot ood at speeling , it's not me
Industrial sewing machine needles are typically sold in a single pack of 10 needles, 10 packages of 10 needles (100 total) and a box containing 5 - 10 packages (500 needles).
Just some quick info on how to read the labeling on the packets of industrial sewing machine needles:
I am going to assume the machine came with the New labeling for Groz-Beckert needles in small plastic packages: They have the QR code on the bottom right hand side of the label while older production runs don't have this code.
Across the top you will see:
i) Groz-Beckert highlighted in red: Indicates the manufacturer and just under that you will see:
a) On the left top corner: a number something like 763252 which would be Groz-Beckert's needle (NDL) code number
b) In the center a large font number indicating the number of needles in the package: 10
c) On the same line to the left will be the size of the needles in the package: Nm 140 / 22. The first numbers indicate the size using the Metric system and the numbers after the slash is the Imperial size of the needles
The next line under that information on the left is the most important area of information as it gives the needle system which is based around lenght and diameter size of the neddle.
1) For Fabric it would say : 135 x 17 and under that it would also say DP x 17
2) For Leather it would say: 135 x 16 TRI and under that it would also say DP x 16 D
3) At the bottom left hand corner gives information about the needles:
i) The coating of the needle: If nothing is typed just above the needle point type then they would be Chrome-Plated Metal but if it says GEBEDUR it means the needles are Titanium nitride coated.
ii) The type of point on the tip of the needle: R or D/ TRI
iii) The very last number on the bottom left side is the manufacturers  production number.
What size of needle are you using with your V138 thread???
kgg
@kgg I’m unable to post a picture of the needle package but it reads as follows
Schmetz
Canu:37:29kj1
nm:140 size 22
135x16 Dia
Dpx16 Dia.
I assume these are the correct needles for leather, at least I hope they are; I purchased the machine from” leather machine company”.
@Wizcrafts Thanks! I’ve gotten as far a figuring out how to start( holding back the threads) but still not sure about lots of other stuff. Perhaps learning by doing, even if that means learning the hard way is the best course of action. It would be helpful if the machine had useable directions. Sadly………..
@suzelle Thanks! I’ve heard lots of good things about them. When I get it figured out I’ll post some pictures of the finished projects.
Edited by AdamDavis
Yes they are the correct needle system for leather for your machine. However the needle size nm:140 size 22 for the V138 thread is on the lower side for sewing leather it is more for sewing V92 thread in thicker items. The size 23 needle, I think would have been a better choice. Sewing in thicker leather you may find you will have to move up to even a size 24 should you have problems like skipped stitches. I prefer Schmetz needles to all the other brands but that maybe just a personal preference but they have never given me a problem in any of my machines. A good source for needles is Wawak.com (https://www.wawak.com/Sewing/Needles/Industrial-Machine/Schmetz-Leather-Industrial-Machine-Needles-135X16-TRI-Dpx16-D-10Pack/#sku=SMNL135118 )
kgg
