1 hour ago, fredk said:
You don't 'need' to buy a new tool for making a groove; your ruler and an old used up ball-point pen. A used up pen, no ink, press it hard and it will leave a fine groove for you to follow
Fred is right -- and you most likely have those things already!
As many have done, I bought a stitch groover tool years ago, which cut a stitching groove. I haven't used it for at least the past 5 years, though. I found it a bit hard to control and get good straight lines.
Now, like many,  I just use an inexpensive wing divider. I find I get better results (as long as my edge cuts are straight!), and I can control the distance of the line from the edge a lot better.
The stitching groover now just sits in a box somewhere...I'm not even sure where it is at the moment! ;-)
Edited by DJole
51 minutes ago, DJole said:
I think I wasn't clear in my description. Let me try again!
The "diamond" or Japanese stitching chisels, as you know, make slanted lines as in (A) in the diagram below
The usual stitching follows the direction indicated by the red "stitches" in line (B).
I think your lines on the right side of the plastic window are doing the opposite, as shown by line (C).
That's what I mean by "reverse." It seems like all the other stitching on your wallet is done the usual way, but that one line appears to be backwards, and doesn't match the other ones. But perhaps I am just seeing it wrong?
The 1 mm thread you used in this project looks okay -- it has a robust look to it which matches the design.
Thank you for clarifying and also for the feedback! You're right that I did 'reverse slanted' for the stitching beside the plastic slot. Initially, it was only to secure the plastic more. I used gold thread at first, but after sewing, I wasn't happy with the look because there were gaps in the stitch holes (I think my sewing was just too tight that it pulled apart the holes and made them bigger). So I just thought to make it some kind of a design and stitch two different color threads over each other. First time I've done this stitching-- it looks like it uses up more thread than the usual stitching but I like it as a decorative.
Ah I might've misunderstood the suggestion. This is good to know-- I'd choose tools with multiple and practical functions over those with only specific uses (unless they're essential) any day. I used a scratch awl to make grooves for the wallets but obviously I really need more practice with symmetrical grooving and punching holes properly on the lines. A wing divider sounds like a multi-functional tool as well-- I'm thinking I can use a compass as an alternative if I ever need to do circular stitching. Thank you again for both your feedback and guidance.
What you have accomplished to do is make your stitching look very tidy (in general) and consistent.  Going around corners is a learning curve and with practice you will get better.  Are you using a 2-prong iron to work the curves?  If not, that will help.
There are areas for improvement, but you are showing progress, and that's key.
I'm sure he's thrilled, and that's worth a lot in itself.
I would also slick down the rough inside of the wallet.Otherwise nice job
On 6/18/2022 at 2:34 AM, Criticles said:
Do you just sand and burnish it with gum, or do you also put paint over it?
I sand, then burnish either with gum or tokonole using the burnisher, then rub with a small piece of canvas as needed.  No edge coating otherwise.
In God's Grace,
Pastor Bob
"While we were yet sinners, Christ died for us." - Romans 5:8
www.PastorBobLeather.com
YouTube Channel
