Thescandall Report post Posted June 20, 2022 I found one of these used and it needs a new nylon roller. Does anyone know if replacements are available. https://www.ebay.com/itm/255554934023?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A16a3Pld1zRfq5YHIknSv2aw54&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=255554934023&targetid=1587268788857&device=m&mktype=&googleloc=9027816&poi=&campaignid=15275224983&mkgroupid=131097072938&rlsatarget=pla-1587268788857&abcId=9300697&merchantid=137749860&gbraid=0AAAAAD_QDh81l1NLbgU0G40vGye4fY_S6&gclid=EAIaIQobChMIvcro37C8-AIVkSc4Ch2fUwV-EAQYByABEgKkhfD_BwE Quote Share this post Link to post Share on other sites
AlamoJoe2002 Report post Posted June 20, 2022 I have a friend who is a machinist. He uses computer assisted machines and also fabricates plastic parts for industry. If you know the dimensions you may be able to find a local machinist to make one for you. Also try looking at McMaster Carr: https://www.mcmaster.com/ This site has more hardware then you will every need. Joe Quote Share this post Link to post Share on other sites
kgg Report post Posted June 20, 2022 6 hours ago, Thescandall said: I found one of these used and it needs a new nylon roller. An alternative would be to find someone close to you with a 3 D printer and they should be able to make one for you pretty quickly. kgg Quote Share this post Link to post Share on other sites
Matt S Report post Posted June 21, 2022 You may be able to buy spares for these machines from one of the several sellers. Or if you strip it down and measure the piece (which I suspect may be a simple nylon tube) you may be able to buy a short length of standardish tubing to replace it. Failing that, as others have suggested, it's a simple job for someone with a lathe to turn from a piece of nylon or acetal rod. Even a wood lathe may be able to be used. Quote Share this post Link to post Share on other sites
Dantan Report post Posted December 19, 2022 Did you ever get it working? Dantan Quote Share this post Link to post Share on other sites
