8 hours ago, Wizcrafts said:
Hmm. We’re having trouble finding that site.
We can’t connect to the server at www.estcarpet.com.
I recommend getting a Consew 206rb-5 which sews up to 3/8 inch. It has a larger M size bobbin and easily handles #138 thread. The bobbins are horizontal axis, inside the left end, instead of dropping in vertically from the top on the right.
i have the consew cp206rl and 255 and don't need another machine...i take your response as the foot height on the cp206rl cannot be changed
www.estycarpet.com
  • Replies 35
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Esty, nice work! I would like to learn to do carpet eventually. Enjoyed seeing pics on your site! I'm thinking learning to thread and operate a carpet serger will be something to add to my list. Always something new and interesting to learn with Auto Interiors!
www.estycarpet.com
It is unlikely that the lift while sewing can be increased without some custom modification. You might ask dealers who sell the machine. One of those is an advertiser here. Check and refresh the banners on top for mention of industrial sewing machines.
Your mini walking foot machine has dual feed, with the outside presser foot and feed dog driven. Your needle and inside foot remain in place, but move up and down. From my experience with various types of walking foot machines, any change to the height of one of the feet affects the lift of the other. They alternate up and down. I know that I can increase to maximum lift of the feet on my triple feed machines by about 1/16 inch. But, with the feet mechanically lifted all the way, the needle bar hits the inside foot. So, when I did that I had to be careful not to use the hand lift lever to hold the feet up and then rotate the balance wheel too far. There is that tradeoff. I simply don't know if your driven presser and alternating foot can be lifted higher without hitting the needle bar when it moves down. You don't want to damage the machine for a small increase in sewing thickness.
Posted IMHO, by Wiz
14 hours ago, esty said:
finally does any know how to or can it even be done, raise the presser foot height... the factory 1/4 inch setting is not quite high enough for a lot of work i do...
The link to "Change Presser Foot Lift On Rex 607z Sewing Machine" which are the same as all the other portable walking foot clones ( https://www.youtube.com/watch?v=pqk1OUR72Ig ) may help in getting a higher lift then the normal 1/4". According to the video in about the 1/2" range. There maybe other problems doing this?????
Another solution for belt replacement is to use Rough Surface Polyurethane Belting like the green colored ones made for drives. It's cheap, comes in various diameters, you get about 33 feet in a coil, easy to join and get the exact length needed for about $25 USD off Amazon ( https://www.amazon.ca/gp/product/B07W4HKK7H/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 ). If nothing else to get you out of a jam you should have a coil just in case you break a belt and can't really get the proper one like on a Sunday.
kgg
i don't use a serger or binding machine, mine are all hand cut & sewn...which makes my work unique...everyone that resell or make carpet sets use a binding machine which makes them all alike...
believe it or not, i do 99% of the carpet binding with a singer heavy and or a cheap brother LX3817 or similar in the cheap machine line...i get about 6 months to a year out of one, throw it away and buy a new one for approx $75
12 hours ago, Wizcrafts said:
You can avoid all these hassles by simply finding the closest length between the pulleys and ordering a Type 3L v-belt from an industrial sewing machine dealer. Your motor should allow for plus or minus 1/2 inch of adjustment.
The reason your measurement showed 1/2 inch is because these are V shaped belts, with a cut off on the small side. The top may well be 1/2 inch, but the inside taper will fit the 3/8 inch inside the tapered pulley groove.
That was the belt I kept getting. Each place I went to all the belts in their computers started with the 3L for 3/8ths belts. And all of them were 1/2 wide and wouldn't fit half way into the pulley. Before I deep dove into O'Reily's site I looked for sewing machine belts but all I could at 55 inches long were 3Ls. Or are you saying that much of the belt should be sticking out?
When we used to sell these little machines we tried getting these to lift higher & found out it can't be done.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
On 10/26/2022 at 8:05 PM, esty said:
among other machines, i have a consew 255 and i just bought this machine for lighter work and want to do the exact things you did...the belt that you linked to baffles me...it appears that it is just a straight piece of material from the picture...i ordered the table, servo motor and pulley but held up on the belt until i can get some clarification
also what is the difference in the presser foot you listed and the one that came with the machine
BTW, i'm in northern mississippi, just across the road from memphis, i'm a legal secretary, at my job for 28 years and have a 18 years old internet business, making interior carpet sets and other stuff for BMW 2002's, 320's and several other early models...if interested see www.estcarpet.com
So I nixed the poly belt and got a V belt with cog groves in it as the poly belt stretched too much and didn't want to stay on the cogged pully on the machine. The presser foot is a cross hatched kinda knurled on the bottom foot. Sailright has them.
Edited by DanaStanley
In the end although it would have cost twice as much, I should have gone with something like the Consew 206rb-5. I only wanted a walking foot that could do thinner thread for wallets, so I could have left my machine alone too! But it will do!
  • 1 year later...
Uhoh, rookie here, why a servo motor? Will the standard delivered work well? Can y'all suggest a good place to begin? Good book? Good tutorial site? I am planning on covering the seats on my BMW Z4, wish me luck, Mike
