Members ScottEnglish Posted August 24, 2022 Members Report Posted August 24, 2022 Hi. I am considering buying a C. S. Osborne one-prong thonging chisel for making stitching holes. The chisel is available in a width of 3/32". Or 2.4mm if you prefer. Has anyone tried this? Thanks. Scott Quote
Members PastorBob Posted August 24, 2022 Members Report Posted August 24, 2022 (edited) Chisels make easy work to make holes in leather. A single prong does just that ...1 hole at a time. If you can afford to add a 2 and a 4 prong, it will help you keep your line a little straighter and your hole spacing much more consistent. I use all three. 4 prong for long straight sections, 2 prong for bends and round edges, and the 1 punch when I have a gap between 2 holes that is just too wide to leave without a hole. 1 hour ago, ScottEnglish said: I am considering buying a C. S. Osborne one-prong thonging chisel for making stitching holes. The chisel is available in a width of 3/32". Or 2.4mm if you prefer. Has anyone tried this? Someone just recently shared this link. It may be helpful. Edited August 24, 2022 by PastorBob Quote
CFM tsunkasapa Posted August 25, 2022 CFM Report Posted August 25, 2022 A THONGING chisel will make holes that are far too large. A thonging chisel and a stitching chisel are two different critters. Quote
Members ScottEnglish Posted August 25, 2022 Author Members Report Posted August 25, 2022 Thanks PastorBob. tsunkasapa: At 3/32" wide at the prong the hole will be small. My 2 1/4" saddler's awl makes a larger hole. Am I mistaken? Quote
CFM tsunkasapa Posted August 25, 2022 CFM Report Posted August 25, 2022 I don't know what awl you have, but none of mine make a hole that size. 3/32 is a HUGE hole. Quote
CFM chuck123wapati Posted August 25, 2022 CFM Report Posted August 25, 2022 10 hours ago, ScottEnglish said: Thanks PastorBob. tsunkasapa: At 3/32" wide at the prong the hole will be small. My 2 1/4" saddler's awl makes a larger hole. Am I mistaken? you need a stitching chisel or pricking chisel for use with sewing awls. believe Tsunkasapa. Also consider this, using a one prong stitching chisel wont be any different than just using an awl in the first place except it will take you twice as long. Quote
Contributing Member fredk Posted August 25, 2022 Contributing Member Report Posted August 25, 2022 A stitching chisel will make a diamond shaped hole, about 2mm across the points of the rhombus, it will be 1mm or less wide. A lacing chisel will make a 2.5 / 3mm rectangular hole about 2 to 2.5 mm wide. The wider hole is necessary to pull the lace, typically nominally 1mm thick but closer to 1.5 mm thick. It will take very thick thread to fill that hole neatly whereas 0.5mm thread (x2 in s/s) will fill the stitching hole Quote
Doc Reaper Posted August 25, 2022 Report Posted August 25, 2022 Y’all should post close up pictures of these items, I only have stitching chisels also do not use what Tandy has, Tandy employees will tell you that it’s only for marking the holes Quote
CFM chuck123wapati Posted August 25, 2022 CFM Report Posted August 25, 2022 15 minutes ago, Doc Reaper said: Y’all should post close up pictures of these items, I only have stitching chisels also do not use what Tandy has, Tandy employees will tell you that it’s only for marking the holes lacing chisel left stitching chisel right. both from Tandy and both work as well as any. Quote
Doc Reaper Posted August 25, 2022 Report Posted August 25, 2022 (edited) 6 minutes ago, chuck123wapati said: lacing chisel left stitching chisel right. both from Tandy and both work as well as any. Lately Tandy has put warnings with their chisels that they are not for punching holes, I believe that you can read it on their web pages. There has been tongs breaking off Edited August 25, 2022 by Doc Reaper Add on Quote
CFM chuck123wapati Posted August 25, 2022 CFM Report Posted August 25, 2022 Just now, Doc Reaper said: Lately Tandy has put warnings with their chisels that they are not for punching holes, I believe that you can read it on their web pages Interesting i haven't noticed that but maybe they are trying to explain that they are not hole punches, chisels aren't for punching holes they are for cutting slots. hole punches are round and for punching holes. lol Most of what we do on the forum is answer questions about tools that the tool companies don't . in our high tech world there has been a real disconnect with modern man and his understanding of hand tools. Quote
Members ScottEnglish Posted August 29, 2022 Author Members Report Posted August 29, 2022 From what I learned in this topic I decided to buy two Japanese stitching awls by Kyoshin Elle. Thanks to everyone for your contributions. Scott Quote
Members Tugadude Posted August 29, 2022 Members Report Posted August 29, 2022 Tandy’s website does not say anything about not using their stitching chisels to punch through leather, not that I could find. In fact, just the opposite. I have two sets of their Craftool Pro Diamond chisels and use them regularly. They look brand new. The black ones they sell will bend if you abuse them, striking them off-center for example. Even still, they last for years. Quote
