Members Burkhardt Posted August 27, 2022 Members Report Posted August 27, 2022 Can any of you tell what model this machine is? Quote
Members Constabulary Posted August 27, 2022 Members Report Posted August 27, 2022 a singer 111w - subclass unknown but since it has no revere it may be 111w155 Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted August 27, 2022 Moderator Report Posted August 27, 2022 I can't see the bed of the machine because the power cord is on it. If there is just one push button is is not a 111w155, but a previous model, probably a 111w153. The one pushbutton is used to change the stitch length. The 111w155 has this button, plus a second one that re-engages a popped safety clutch after thread jams in the hook. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted August 27, 2022 Members Report Posted August 27, 2022 (edited) it has the hole in the casting from where you see the stitch length dial so it should a model with 2 push buttons. The 111 with stitch length knob near the hand wheel have 1 button in the bed but no hole. @Burkhardt here is a PDF of an old 111w brochure maybe it helps to figure the subclass (see box below picture). Looks like your machine is from 1940. Singer 111w Class Machine Brochure.PDF Edited August 27, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members trash treasure Posted August 27, 2022 Members Report Posted August 27, 2022 (edited) 2 buttons, so probably 111w155 - A good machine, if you don't mind no reverse. Edited August 27, 2022 by trash treasure Quote The model number giveth, and the subclass taketh away ......... Sometimes
Members SARK9 Posted August 27, 2022 Members Report Posted August 27, 2022 The 111w152-155 were all pretty similar....if it matters, you can probably narrow down the model from the max stitch length & foot lift. -DC Quote Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562, Mitsubishi LS2-180, Seiko SK-6, Juki LG-158-1
Members Burkhardt Posted August 27, 2022 Author Members Report Posted August 27, 2022 Thanks for the info. It's at a local auction so without knowing what model it is was tough to figure if it was worth looking at. Quote
Members dikman Posted August 27, 2022 Members Report Posted August 27, 2022 10 hours ago, SARK9 said: The 111w152-155 were all pretty similar....if it matters, you can probably narrow down the model from the max stitch length & foot lift. -DC From memory they all had 3/8" lift except the 155 at 1/2". The 155 was the model with the "major" differences in that sub-class grouping, the rest were similar, as you say. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
