Members Shenandoah Posted September 4, 2022 Members Report Posted September 4, 2022 Is there a "dye" in the color white that will work well on leather? I am working on making some leather feathers. I do have white/neutral Angelus acrylic leather paint, but the stain appears to leave a nicer/cleaner finish. Shenandoah Quote
Members Leescustomleather Posted September 4, 2022 Members Report Posted September 4, 2022 I understand your problem, What I did was thinned the paint with water, 3 parts water and one part paint. Then added several coats to get the desired look. Quote
Members sbrownn Posted September 4, 2022 Members Report Posted September 4, 2022 I looked just the other day for white dye and couldn't really find any so I used white paint without thinning. In retrospect I think thinning it would be a good idea. Some of the dyes, turquoise comes to mind, are so non opaque that they are difficult to use short of dipping as it takes so many applications to get it to cover. Obviously dipping for small colored areas is a non starter. Quote
Members billybopp Posted September 4, 2022 Members Report Posted September 4, 2022 White dye exists .. or used to. It sucks. Not worth the money nor the effort. - Bill Quote
Members Dwight Posted September 4, 2022 Members Report Posted September 4, 2022 For my white leather projects . . . I buy white leather off Ebay . . . Has worked very well so far. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Handstitched Posted September 5, 2022 Members Report Posted September 5, 2022 4 hours ago, billybopp said: White dye exists .. or used to. It sucks. Not worth the money nor the effort. I second that. I have some in a old bottle that someone gave me. To get a good finish on a belt, I had to use a lot of white dye . HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Shenandoah Posted September 6, 2022 Author Members Report Posted September 6, 2022 Thanks for the information. I also want to do a black crow feather, but they have a blue/green iridescence. I am having problems coming up with this color. I plan on laying a black dye down first then applying a coat of Dragonfly violet-blue-green color changing paint. Tried a test strip, but to much. Will watering down to thin it out also work, or does someone have a better idea to get the iridescence i am looking for. Quote
CFM chuck123wapati Posted September 6, 2022 CFM Report Posted September 6, 2022 2 minutes ago, Shenandoah said: Thanks for the information. I also want to do a black crow feather, but they have a blue/green iridescence. I am having problems coming up with this color. I plan on laying a black dye down first then applying a coat of Dragonfly violet-blue-green color changing paint. Tried a test strip, but to much. Will watering down to thin it out also work, or does someone have a better idea to get the iridescence i am looking for. vinegaroon then Angelus pearlescents paints in greens, blue, and purple very lightly brushed on Just now, chuck123wapati said: vinegaroon then Angelus pearlescents paints in greens, blue, and purple very lightly brushed on brush it on very lightly and wipe immediately Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
