Members HavnerDesign Posted September 20, 2022 Members Report Posted September 20, 2022 Hi, I am new to the forum, but have done leather work for a hobby for some years. Among other things, I make leather gun slings for hunters, and I want to find something to add as anti slip on the part of the sling that is in contact with the shoulder. A hunting rifle is quite heavy and it is annoying when the sling and rifle starts to slip down your shoulder and you need to constantly adjust the sling to get back up on your shoulder. Can anyone recommend liquid latex? Will it stick properly to leather? Will it last over time? Or is there a better solution? I have found self adhesive anti slip-labels or stickers that are made for handbags and other smaller shoulder bags, but I don't reckon they will last very long on a rifle sling... Is there any kind of rubbery band or patch I can sew on to the back of the sling? Quote
Members Gezzer Posted September 20, 2022 Members Report Posted September 20, 2022 Look at router pads or maybe even shelve liner , might be something you could use . Hope you find something !! Quote
CFM tsunkasapa Posted September 20, 2022 CFM Report Posted September 20, 2022 Neoprene. We use it on harnesses for sled dogs. It is the same stuff 'mouse pads' are made of and comes with or without the fabric facing. Quote Hoka Hey! Today, tomorrow, next week, what does it matter?
Members Cumberland Highpower Posted September 20, 2022 Members Report Posted September 20, 2022 (edited) Tons of stuff you can use. Some rifle slings come with a non slip rubber finish. cotton webbing is often woven from cotton with latex woven in. Mouse Pad Neoprene mentioned above is often used and bound around the edges. Sometimes a granulated rubber sheet is used. (backed up with a knit cloth). That's harder to find, I used to order mine from Finland. Edited September 20, 2022 by Cumberland Highpower Quote
CFM chuck123wapati Posted September 20, 2022 CFM Report Posted September 20, 2022 a lot of folks put a thumb hole through or a loop on the inside to hang their thumb in so the sling wont slip around. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members TomE Posted September 20, 2022 Members Report Posted September 20, 2022 7 hours ago, HavnerDesign said: Can anyone recommend liquid latex? Will it stick properly to leather? Will it last over time? Or is there a better solution? This product is a synthetic rubber (butadiene) for sealing the flesh side of leather. I use it mixed 50:50 with water and work the first coat into the leather with a glass slicker then apply a thin second coat. However, it dries as a smooth nontacky finish (like the label says). It seals out moisture and seems to be durable. I use it on bridle pieces that are split thickness as a replacement for the mossback finish of full thickness bridle leather. The BT639 might not suit your purposes. What about sewing on a liner of rough out chaps leather? https://www.hidehouse.com/Leather/Pearl-Split-Cow-Split-Grain-Suede-Finish-PE10-P.asp Quote
Members GatoGordo Posted September 21, 2022 Members Report Posted September 21, 2022 I line the back of the sling with suede. It provides grip and a padding for the shoulder. Quote
CFM chuck123wapati Posted September 21, 2022 CFM Report Posted September 21, 2022 7 hours ago, GatoGordo said: I line the back of the sling with suede. It provides grip and a padding for the shoulder. so do i , trouble with adding sticky stuff is a sling isnt just for carrying the weapon, if you actually use your sling as it should be to shoot with your going to have problems. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members HavnerDesign Posted September 22, 2022 Author Members Report Posted September 22, 2022 On 9/20/2022 at 4:28 PM, Gezzer said: Look at router pads or maybe even shelve liner , might be something you could use . Hope you find something !! Very clever, would never have found those. Thanks! Quote
Members HavnerDesign Posted September 22, 2022 Author Members Report Posted September 22, 2022 On 9/20/2022 at 6:33 PM, tsunkasapa said: Neoprene. We use it on harnesses for sled dogs. It is the same stuff 'mouse pads' are made of and comes with or without the fabric facing. Nice tip, thanks! That will also serve as padding for the shoulder. Quote
