2 minutes ago, chuck123wapati said:
they work fine for straight cuts, i have been using one slightly larger but with a straight blade for a year or so and haven't picked up my round knife since.
Thanks for the info.  Looks like a very handy tool.  Nicely finished too.
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
  • CFM
1 hour ago, DHauser said:
First off, love the chuck123wapati! May have to have one just for the hell of it. I appreciate everyones input. I have looked at the knives you have suggested but still feel that a round knife is what I am looking for. I know these others are sharp as hell (see attached pic of a mod I did) I just like that a round knife , when rotated vertically, slices the multiple layers of leather similar to a paper cutter or a rotary knife. I may try one of these suggested and see how it does. Frictionless is the key (although impossible I know). I normally use a number 11 surgical xacto blade for most of my fine cutting but that even still has a bit too much friction for me. I wish I could find a good, thick blade, round knife with only one sharpened/beveled edge. I may have to buy a good thick bladed one and grind/sharpen/polish it myself.
Anyway, the pic below is of a fairly decent Diudus that I got off of Amazon. It was originally a perfectly straight edge but I find that its easier to skive and finely trim with the blade slightly curved on the one side. Please, keep the suggestions coming!
if your still looking after hunting season(November) let me know, i can make what ever you dream up. I'm strapped until then I have a few projects on the bench i have to finish lol.
This knife is called a "crease" on the English version of Vergez-Blanchard's website.
That’s one I want.
Hmmm, much to think about, thanks all! Ive been considering the custom route (used to run a high end knife shop) so thats always an option. To chuck123wapati: I'll keep that in mind. I most certainly get the "few projects on the bench"! Man, some folks just dont understand the time involved in this stuff. I may buy a cheaper round knife I can modify to get my idea right then Ill look at some "pretty stuff". You guys are the bomb. Thanks.
C. David Hauser
Leathersmith
Dragonthorn Leatherworks
http://dragonleather.net
336-655-6233
On 10/3/2022 at 1:46 PM, DHauser said:
Ive been a leathersmith for a while and do pure custom (one off) pieces. Due to my process and techniques I am looking for a round knife sharpened on one side and purely flat on the other, I wish to be able to place it against a straight edge to cut laminated oil tanned leathers for varying distances. I currently am using a Olfa 60mm rotary knife but just not what I am looking for. As I am finishing the laminated edges with Italian Edge Paint I need to get a perfect flat flush cut. Beleive me, I have tried every technique possible and have arrived at what I do. I have good skiving knives and a single Osborne round knife (along with the Olfa). Anybody have any suggestions?  Thanks, Dave
If you can get by without a round knife there are lot's of single bevel knives out there in both left and right hand configurations.
13 hours ago, TomE said:
I really like @chuck123wapati's knife but I'm confused about using it for long straight cuts.  Based on my experience with a single bevel plough knife I'd expect the blade to track away from the bevel.  I use a traditional round knife for long straight cuts when squaring up hides.  This looks like a pattern knife or skiving knife for fine work.  Interested in learning more about this.
The blade is all of a 1/8th thick and that's the reason I went with @chuck123wapati because I am much more comfortable pushing rather than pulling and on a straight edge there's so much control with the overall low profile I'm happier I went with this vs a round knife.
Actually...I read on one of the tool websites that the bevel goes towards the straight edge to compensate for the angle of the wrist when cutting.  When I experimented I found the statement to be true for me.
While this is a kitchen knife it  might could be modified to  serve your use .  The steel in this one will sharpen up nicely and holds an edge in " kitchen " use , I don't have a clue how well it would fair in leather . It is kind of round  and bevel on one side other side flat ...... just a thought .
Good luck on finding what you need .
I have a cheap version of this - which I know in English as head knife - (without an edge on the inside od the point) and it has a double bevel (like the one in the video,  IMHO). The blade is just relatively thin, so the double bevel (or would you simply call it edge?) doesn't show a lot. But I sharpen the edge at an angle on both sides.
That said, I don't see any need for a round knife - if I ever want to upgrade I'll buy a better head knife...
