Members StoneBuiltKnives Posted October 13, 2022 Author Members Report Posted October 13, 2022 1 hour ago, CowboyBob said: Have you tried increasing the foot pressure? I did not but it's already leaving marks in my leather. I have however finally achieved some success with my sewing woes. I didn't realize I had lighter thread in the box of stuff I got with my machine. I dropped down to a 207 thread with the 25 needles and my breakage problems disappeared. Thank you for all the assistance. Now I can focus on learning to actually use the machine instead of troubleshooting. Quote
Members StoneBuiltKnives Posted October 14, 2022 Author Members Report Posted October 14, 2022 Finally! Quote
RockyAussie Posted October 14, 2022 Report Posted October 14, 2022 Looks good to me. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members StoneBuiltKnives Posted October 14, 2022 Author Members Report Posted October 14, 2022 7 hours ago, RockyAussie said: Looks good to me. Thank you! Quote
Doc Reaper Posted October 14, 2022 Report Posted October 14, 2022 (edited) I had a problem of thread breaking on 3 different machines (not the same make) and I was missing stitches. I checked to make sure it was threaded properly, the tension was slightly adjusted to make sure that wasn’t a problem. So I got to thinking about what would fray the thread? i checked for burrs and sharp edges everywhere around the needle and plate areas, all was good. I eliminated everything but the needle! So I changed the needle , still using the same size - still the same problem, UGHH! So I watched the operation of the needle closely, and the thread was not even, like it was cut by scissors, but even enough to be happening at one spot - the eye of the needle (where the thread goes thru). Not all at once but the thread was bunching on the feed side of the needle and the fibers of the thread kept popping one at a time! So I got a needle with a larger hole and my problem vanished! needle size charts were made when materials for thread and needle were different. I ALWAYS go to the next size up in needles, it helps cut down on frustration! I even made that comment to Cowboy Bob when I made an order about 3 weeks ago. So if you are fraying right at the needle, increase to the next needle size up Edited October 14, 2022 by Doc Reaper Quote Doc Reaper
Moderator Wizcrafts Posted October 14, 2022 Moderator Report Posted October 14, 2022 4 hours ago, Doc Reaper said: So I watched the operation of the needle closely, and the thread was not even, like it was cut by scissors, but even enough to be happening at one spot - the eye of the needle (where the thread goes thru). Not all at once but the thread was bunching on the feed side of the needle and the fibers of the thread kept popping one at a time! So I got a needle with a larger hole and my problem vanished! The throw and tension of the check spring also affects the quality of the loop. A longer throw and tighter action can overcome the tendency of poorly bonded thread to unravel. Furthermore, if the unraveling is due to excessive twistiness in the spool, wrapping in the opposite direction around the top post may offest the twist problem and keep the loop at the needle intact. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
