Members sojourner999 Posted December 19, 2022 Members Report Posted December 19, 2022 Hello again, Thanks for all the help on the Consew 206-RB4 I acquired previously. Since then, I have added a speed reducer and am very pleased with that machine. That said, I ran across a deal on a Juki LU-563 clone or re-badge. A Chandler Chandsew / CU563. It sewed fwd and reverse. There is a minor hiccup with the button for stitch length selection. It might need replaced or just some oiling. It won't catch in the detent to allow changing stitch length. And it is missing the nose cone? / side plate. Both should be easy fixes. Anyway, after I clean it up, fix the selector and time/setup I am considering using it for purely binding or leather or maybe both. I started looking at Uwe's videos and will work with them when setting up. Does anyone have information on this chandler? meaning is it a re-badge of a juki or a clone made by someone else? Also, can anyone point me to pdf downloads of owners manual, service manual and parts manual? Much appreciated! Tom Quote
CowboyBob Posted December 19, 2022 Report Posted December 19, 2022 Here's a parts & operators manual for the Juki 563 & all the parts should interchange. Juki_LU_562_563_Manual.pdf Juki_LU-562,_-563-1.pdf Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members sojourner999 Posted December 19, 2022 Author Members Report Posted December 19, 2022 3 minutes ago, CowboyBob said: Here's a parts & operators manual for the Juki 563 & all the parts should interchange. Juki_LU_562_563_Manual.pdf 7.15 MB · 0 downloads Juki_LU-562,_-563-1.pdf 12.82 MB · 0 downloads Thanks! PDFs downloaded. Quote
Members shoepatcher Posted December 19, 2022 Members Report Posted December 19, 2022 Looks like a rebadged early Juki. glenn Quote
Members sojourner999 Posted December 19, 2022 Author Members Report Posted December 19, 2022 (edited) 16 minutes ago, shoepatcher said: Looks like a rebadged early Juki. glenn Thanks. Are you familiar with any differences with rebadged (assumed Juki produced and chandler put it’s name on the machine) versus clone (where I assume it was made in China to same specs as the original Juki)? Edited December 19, 2022 by sojourner999 Quote
Members SARK9 Posted December 19, 2022 Members Report Posted December 19, 2022 (edited) I've had/have several "real" Juki LU-563s and an older Chandler badged "CU-563" which as far as I could tell, was identical to the Juki machines. I also have a Chandler badged 562 which is printed "Made in Japan" under the badge, rather than stamped ON the badge, as is seen on my Jukis. The quality of these older chandler marked machines was on par with my genuine Juki products as far as I could tell. The Chandler "562" shows 200R on the badge, and could possibly be a rebadged Consew 226R for all I know, rather than a Juki, except I don't see SEIKO cast on the underside of the bed as I think was done on most of the early Consew contract machines. The Chandler badge might ding the resale a bit, and that was the only downside I saw, as they are fine users, and the 563 actually had the BA0 hook assembly installed, though who knows if it was original to the build. I never felt handicapped in the slightest with any of them. -DC Edited December 19, 2022 by SARK9 Quote Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562, Mitsubishi LS2-180, Seiko SK-6, Juki LG-158-1
Members Quade Posted December 19, 2022 Members Report Posted December 19, 2022 (edited) I have the stitch length button out on my Singer. It's just a button with a spring and a C clip to hold it in place. When you press it down, it engages with a disk on the shaft. It holds the disk in place. When you turn the hand wheel, the shaft turns, this changes the "gear ratio" by lengthening and shortening the stroke of an arm. I'd flip her over, then look at the center shaft which is either belt driven or gear driven. Press the button down, turn the hand wheel forward and see if the center shaft turns. You should see the eccentric mechanism and arm and you should see the disk which has a cut-out the button is supposed to engage. I'd see if the button seems aligned with the cut-out. You can hold the disk in place with a screwdriver or pliers and try turning the hand wheel to make sure it actually adjusts and isn't stuck. You can see it on page 3 of the parts manual posted above. Edited December 19, 2022 by Quade Quote
Members sojourner999 Posted December 19, 2022 Author Members Report Posted December 19, 2022 2 hours ago, SARK9 said: I've had/have several "real" Juki LU-563s and an older Chandler badged "CU-563" which as far as I could tell, was identical to the Juki machines. I also have a Chandler badged 562 which is printed "Made in Japan" under the badge, rather than stamped ON the badge, as is seen on my Jukis. The quality of these older chandler marked machines was on par with my genuine Juki products as far as I could tell. The Chandler "562" shows 200R on the badge, and could possibly be a rebadged Consew 226R for all I know, rather than a Juki, except I don't see SEIKO cast on the underside of the bed as I think was done on most of the early Consew contract machines. The Chandler badge might ding the resale a bit, and that was the only downside I saw, as they are fine users, and the 563 actually had the BA0 hook assembly installed, though who knows if it was original to the build. I never felt handicapped in the slightest with any of them. -DC Thanks for the info. I didn’t see anything stamped that would make me think it was an original Juki. But as long as it is Juki level quality, I should be good. Quote
Members sojourner999 Posted December 19, 2022 Author Members Report Posted December 19, 2022 1 hour ago, Quade said: I have the stitch length button out on my Singer. It's just a button with a spring and a C clip to hold it in place. When you press it down, it engages with a disk on the shaft. It holds the disk in place. When you turn the hand wheel, the shaft turns, this changes the "gear ratio" by lengthening and shortening the stroke of an arm. I'd flip her over, then look at the center shaft which is either belt driven or gear driven. Press the button down, turn the hand wheel forward and see if the center shaft turns. You should see the eccentric mechanism and arm and you should see the disk which has a cut-out the button is supposed to engage. I'd see if the button seems aligned with the cut-out. You can hold the disk in place with a screwdriver or pliers and try turning the hand wheel to make sure it actually adjusts and isn't stuck. You can see it on page 3 of the parts manual posted above. Thank you. @Jhunter13 walked me through this when I was at the sellers property. It is belt drive. I can see the cutout. I line it up with the disk, but it doesn’t appear to catch. I tried holding a screw driver on the disk and was able to turn the hand wheel, so it appears it is not stuck. I just can’t get the stitch length button to catch the indent. Looking at it, from a weird angle, it appears to not be centered in the cutout. Maybe it could also be the button was ground down from improper use? How would you remove and re-install the stitch length button? And if it is not the button being too short, can you recommend how I would adjust the “left/right” of the disk so the button is in line with it? much appreciated, Quote
Members Jhunter13 Posted December 19, 2022 Members Report Posted December 19, 2022 3 minutes ago, sojourner999 said: Thank you. @Jhunter13 walked me through this when I was at the sellers property. It is belt drive. I can see the cutout. I line it up with the disk, but it doesn’t appear to catch. I tried holding a screw driver on the disk and was able to turn the hand wheel, so it appears it is not stuck. I just can’t get the stitch length button to catch the indent. Looking at it, from a weird angle, it appears to not be centered in the cutout. Maybe it could also be the button was ground down from improper use? How would you remove and re-install the stitch length button? And if it is not the button being too short, can you recommend how I would adjust the “left/right” of the disk so the button is in line with it? much appreciated, Simply remove the e-clip from the underside of the feed eccentric adjustment knob (the stitch length adjustment button) and it will come out from the top side along with the spring. Quote
