  • CFM
32 minutes ago, Wizcrafts said:
You probably won't find the S point needles at TE, Wk or most other tailor supplies sellers. The needles I am referring to are Schmetz "Pfaff" System 134-35 in S points. Those are inline chisel points. That system is about 1/16" shorter than a System 135x16 walking foot needle. If you can adjust the needle bar height and accept 2mm shanks, they will fit your machine and give a nice submerged looking stitch line. I got some from Bob Kovar and they time well on my walking foot machines that don't have reverse.
thanks i will check that out.
  • Replies 66
  • Created
  • Last Reply
Top Posters In This Topic
  • CFM
I found the lever to raise the foot on the backside of the machine a total pita
my patcher came with 2 thread tension disc assemblies, I removed the one for the bobbin winder and drilled the hole out 1/8”
Handle modification
Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
D.C.F.M
  • CFM
Handle modification
great idea !!!!
11 hours ago, chuck123wapati said:
here is my first try aside form the turkey tracks what do you think? the thread looks small for the hole but i haven't pounded it down.  I used a shmetz 110/18 leather needle with tex 90 thread.
It's a lot easier to go one crank at a time then by hand stitching. I think it looks good. I'll look tomorrow I got a whole bunch of different points in the 135x16s and 17s since I'd figure I'd go through a bunch and I used like 3 needles and I have like 10 different packs.
  • CFM
after finishing i think they look like any other machine stitches. the turkey tracks are virtually unnoticeable also all i have done to the foot is smooth them off so they don't tear the leather, they were as sharp as sharks teeth lol.  i will be fixing the foot more however.
Caution! Use heat shrink or tight fit tubing if you must. DO NOT grind the teeth! You will need them down the road to pull some difficult work through. Ask me how I know.
Posted IMHO, by Wiz
  • CFM
i was going that route but i also have in mind making a better foot with shallower teeth. The biggest problem i see with them is they are so rough they tear the top layer of leather all i have done so far is finish them better so they arent rough and sharp. the tension is at the very minimum
  • CFM
I sent you a right and left foot  both have heat shrink on them
D.C.F.M
  • CFM
Dang I haven't tried them yet that will be todays tinker lol.
  • CFM
D.C.F.M
