Members BDAZ Posted January 25, 2023 Members Report Posted January 25, 2023 I have to produce a decorative line of lacing on a project which will be around 60 inches and needs to have a tight "wrap" as shown below. All my lacing chisels leave gaps between stitches. Are there any punches for 1/8" lace that could produce these results. I suppose I could hand punch but that would be really time consuming and not in the budget. I have the possibility of either marking punch holes or even cutting them with my laser, which I will use to "trace" the pattern on the leather but again, a lot of extra work when it seems the right punch may do the trick? Thanks! Bob Quote
Moderator immiketoo Posted January 25, 2023 Moderator Report Posted January 25, 2023 Use thicker lace with your standard chisels. Or make a custom punch. The spacing is the issue. I use 1/4 lace with a 1/8 punch. Sometimes I have to trim the lace down a little. Depends on your lace. Quote
Members BDAZ Posted January 25, 2023 Author Members Report Posted January 25, 2023 (edited) 1 hour ago, immiketoo said: Use thicker lace with your standard chisels. Or make a custom punch. The spacing is the issue. I use 1/4 lace with a 1/8 punch. Sometimes I have to trim the lace down a little. Depends on your lace. Not sure if a wider lace is an option but good suggestion and I'll check. Update: I checked and it has to be 1/8th" lace. Thanks! Another Update: Searched for 2mm punches but none available. I was able to laser cut these 2mm holes spaced at 2mmin 3.3mm veg tan. For the actual project I'll may have to clean the char out before lacing but it will be the final stage and the project will already be sealed with resolene. In addition, I'm going to make the holes 2mm x 1.5 or even rectangular slots of that dimension and spaced 1.75mm. A punch would be an easier solution but this is Plan A if no one has a better suggestion. Edited January 25, 2023 by BDAZ Quote
Michael Sheldon Posted January 25, 2023 Report Posted January 25, 2023 Does it have to be that specific style of lacing? There are varying styles of edge lacing that completely cover the edge, without needing to punch so closely. Trying to get a simple whip stitch that close is seriously weakening the edge of the leather. Spanish edge lacing of three loops, and two loops. For really tight coverage, you can do a round braid over the edge. It's intricate and time-consuming, but it looks awesome. Quote
Members BDAZ Posted January 25, 2023 Author Members Report Posted January 25, 2023 (edited) 19 minutes ago, Michael Sheldon said: Does it have to be that specific style of lacing? There are varying styles of edge lacing that completely cover the edge, without needing to punch so closely. Trying to get a simple whip stitch that close is seriously weakening the edge of the leather. Spanish edge lacing of three loops, and two loops. For really tight coverage, you can do a round braid over the edge. It's intricate and time-consuming, but it looks awesome. Thanks! That's what I would use for an edge but it has to be a single stitch.. Edited January 25, 2023 by BDAZ Quote
Contributing Member fredk Posted January 25, 2023 Contributing Member Report Posted January 25, 2023 (edited) Either, use a single punch or, and I'm thinking on the quick here; get a larger spacing chisel which also has wider teeth, say 5mm teeth at 5mm gap. File down each tooth to 3mm, that then gives a gap of about 6 or 7mm between teeth. Then use it to punch holes, After these holes, go again, but putting the teeth in the space between each of the first holes edit; normal 5 x 5 chisel ----- ----- ------ reduced size tooth --- --- --- double punched --- --- --- --- --- --- Edited January 25, 2023 by fredk Quote
Moderator immiketoo Posted January 25, 2023 Moderator Report Posted January 25, 2023 3 hours ago, BDAZ said: Not sure if a wider lace is an option but good suggestion and I'll check. Update: I checked and it has to be 1/8th" lace. Thanks! Another Update: Searched for 2mm punches but none available. I was able to laser cut these 2mm holes spaced at 2mmin 3.3mm veg tan. For the actual project I'll may have to clean the char out before lacing but it will be the final stage and the project will already be sealed with resolene. In addition, I'm going to make the holes 2mm x 1.5 or even rectangular slots of that dimension and spaced 1.75mm. A punch would be an easier solution but this is Plan A if no one has a better suggestion. If you’re looking for 2mm round punches, they are available on eBay. I have a set from .5 up to 12 mm https://www.ebay.com/itm/132674687856?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=hZSG3GTuRlm&sssrc=2349624&ssuid=Nv0ezVr4Su-&var=432001119726&widget_ver=artemis&media=COPY Quote
Members BDAZ Posted January 25, 2023 Author Members Report Posted January 25, 2023 2 hours ago, fredk said: Either, use a single punch or, and I'm thinking on the quick here; get a larger spacing chisel which also has wider teeth, say 5mm teeth at 5mm gap. File down each tooth to 3mm, that then gives a gap of about 6 or 7mm between teeth. Then use it to punch holes, After these holes, go again, but putting the teeth in the space between each of the first holes edit; normal 5 x 5 chisel ----- ----- ------ reduced size tooth --- --- --- double punched --- --- --- --- --- --- Brilliant! I'll give it a go... Bob 3 minutes ago, immiketoo said: If you’re looking for 2mm round punches, they are available on eBay. I have a set from .5 up to 12 mm I looked on Amazon, didn't check Ebay. Thanks! Bob Quote
Members BDAZ Posted January 25, 2023 Author Members Report Posted January 25, 2023 This is the same laser cut holes with a different lacing pattern and I think it does the trick though the 2mm punches sound like a good option if I can find them. Thanks! Bob Quote
Members GrampaJoel Posted January 30, 2023 Members Report Posted January 30, 2023 (edited) I just took a cheap screwdriver in the right width to match my lace and ground it until it matched perfectly. Then used it for a punch. I prefer flat punch holes for lace. As apposed to round holes for flat lace. btw, the holster is what the customer wanted. He brought me a photo and I duplicated it. With minor changes so as not to be an actual copy. Joel Edited January 30, 2023 by GrampaJoel Quote
CFM chuck123wapati Posted January 30, 2023 CFM Report Posted January 30, 2023 On 1/25/2023 at 2:34 PM, BDAZ said: Brilliant! I'll give it a go... Bob I looked on Amazon, didn't check Ebay. Thanks! Bob they make lacing chisels. https://tandyleather.com/products/pro-line-lacing-chisels-532?_pos=1&_sid=7f29206c3&_ss=r Quote
Members BDAZ Posted January 30, 2023 Author Members Report Posted January 30, 2023 (edited) 31 minutes ago, GrampaJoel said: I just took a cheap screwdriver in the right width to match my lace and ground it until it matched perfectly. Then used it for a punch. I prefer flat punch holes for lace. As apposed to round holes for flat lace. btw, the holster is what the customer wanted. He brought me a photo and I duplicated it. With minor changes so as not to be an actual copy. Joel Thanks, Currently in Chatsworth CA but when I get home I'll test cutting 2mm x 1 mm rectangles at 1mm. I have to punch around 90 running inches so a single blade isn't going to cut it (no pun intended) Bob Edited January 30, 2023 by BDAZ Quote
Members BDAZ Posted January 30, 2023 Author Members Report Posted January 30, 2023 29 minutes ago, chuck123wapati said: they make lacing chisels. https://tandyleather.com/products/pro-line-lacing-chisels-532?_pos=1&_sid=7f29206c3&_ss=r I know, I have a few sets. Thanks, Bob Quote
CFM chuck123wapati Posted January 30, 2023 CFM Report Posted January 30, 2023 On 1/25/2023 at 9:05 AM, BDAZ said: I have to produce a decorative line of lacing on a project which will be around 60 inches and needs to have a tight "wrap" as shown below. All my lacing chisels leave gaps between stitches. Are there any punches for 1/8" lace that could produce these results. I suppose I could hand punch but that would be really time consuming and not in the budget. I have the possibility of either marking punch holes or even cutting them with my laser, which I will use to "trace" the pattern on the leather but again, a lot of extra work when it seems the right punch may do the trick? Thanks! Bob then i cant help you much i can do this stitch with mine.. Quote
Members Docado Posted January 30, 2023 Members Report Posted January 30, 2023 Deeter Custom Saddlery makes a buckstitch lacing needle that fits in a cobra 3/4 sewing machine. They also have a video on how to get it set up in machine. Others also make similar needle. No affiliation with any of manufacturers. Quote
Members BDAZ Posted January 30, 2023 Author Members Report Posted January 30, 2023 2 hours ago, Docado said: Deeter Custom Saddlery makes a buckstitch lacing needle that fits in a cobra 3/4 sewing machine. They also have a video on how to get it set up in machine. Others also make similar needle. No affiliation with any of manufacturers. Great information. I'll check it out!! Bob Quote
Members BDAZ Posted February 6, 2024 Author Members Report Posted February 6, 2024 Customer gave me some lame excuses why he wants to "wait" on the belt... Never trust any music producers from Nashville. Ask me how I know! Bob (former WEA recording artist) Quote
