I did have a couple of comments that my first articulating table top attachment was shall we be honest and say a little overly complicated, the mounting hardware took away from the look of the machine and looked clumsy. So I think I have corrected those concerns while still allowing it to be swing away and be stored underneath the cylinder arm.
The twist to the original table top attachment is that is now modular and I have added two drop down straight edge sewing guides. The surfaces of the table top and edge guides that any material will touch are really smooth / slick to prevent catching and reduce tension. The straight edge guides can be used together (one on each side of the needle) or individually (to the left or right of the needle). The front and back drop down sections have measurement marks in their surfaces with half moon marks indicating "inch" marks from the center of the needle so getting accurate and straight alignment of the straight guides is pretty easy.
Also in the photo's is a adapter that I made that attaches to the existing vertical lifting rod for raising the presser foot up by hand. This is a rough working prototype as the original knuckle buster round black ball on the end of the vertical rod was a royal pain to get too with my chubby fingers. By extending it out towards the front of the machine it is much easier get to and more accurate to operate.
The last two photo's are of the original vertical attachment and the new horizontal attachment. I know my welding skills are in need of improvement so for those who know how to weld have a chuckle and bear with me.
There is another addition to this table top attachment that will extend it's size to about 10" x 16" that I will probably complete a little later on.
I would like to thank @MtlBiker for his input throughout this project.
All comments and or suggestions are always welcomed.
kgg
The table looks great!
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
The lifter is even worse to use if you fit a drop-down edge guide! As for your welding, you obviously haven't seen mine.
Your next project - make a sewing machine using the 3D printer.:lol:
Edited by dikman
Expand
Thank you, I appreciate the compliment.
Expand
I haven't tried a drop-down edge guide on the 441. I know when I did the installation of one on the Sailrite LSZ-1 clone it wasn't as convenient as I thought it would be and wound up in a spare parts bin somewhere in the basement. I can see that it could get a bit crowded in that section and with my chubby hands I would probably skin a couple knuckles.
Expand
HaHa
Expand
That would be a nice winters project. Maybe something like a one armed bandit.
kgg
You really do amazing work!  Design and implementation.  Kudos!  I love the carbon-fibre look of your table.  Very cool.
The only thing I don't care for is the velcro strap you have for swinging the table away/down.  Makes it look kinda cheap in opinion.  I'd rather simply remove the table and store it elsewhere when not in use.
I can see that for your purposes such a small table attachment (you'd use it mostly for bindings I guess) is fine, but for me I'd prefer a much larger table.  The purchased aluminum flatbed table attachment I bought for my 2750 Pro is really the minimum size I'd want.  Otherwise I don't think it could replace a dedicated flatbed machine like my Consew 206RB-5.  Do you have any plans/needs to make a larger table?  I could actually see a use for two sizes of table... one for small things where you really only need a small tabletop and another for larger items.
But my opinions are only worth two cents (Canadian!).  :)
Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
Expand
Thank you.
Expand
I'm working on getting rid of the velcro strap.
Expand
Working on a 10" X 16". Just got to finish the presser foot lift and a swing away roller edge guide.
Expand
All opinions and comments are invaluable regardless of currency.
kgg
